This WPF project is the second in our series of samples on printing. The first introductory sample served as a presentation of the different printing concepts such as page layout, the map element, legends, titles, data grids, logos and the user's interaction with them. Using all of the printing tools we introduced in the first sample, here we will demonstrate a real-world print scenario at a large scale with data for parcels at a county level. By reading the descriptive comments within the sample code itself, you will better understand how to handle your printing needs and follow cartographic standards for map presentation.
This WPF project is the 3rd in our series of samples on printing. Here we will demonstrate how to print the map with the high quality. This is a new feature for Map Suite, it should be available in version 9.0.483.0. From the sample you will better understand how to get the different printing quality with the different DPI. The sample just shows how to print the raster image, it also can works well with the vector data.
