map_suite_wpf_desktop_edition_printing_samples
Map Suite Wpf Desktop Edition Printing Samples
Large Scale Map Printing
This WPF project is the second in our series of samples on printing. The first introductory sample served as a presentation of the different printing concepts such as page layout, the map element, legends, titles, data grids, logos and the user's interaction with them. Using all of the printing tools we introduced in the first sample, here we will demonstrate a real-world print scenario at a large scale with data for parcels at a county level. By reading the descriptive comments within the sample code itself, you will better understand how to handle your printing needs and follow cartographic standards for map presentation.
Map Printing With High Quality
This WPF project is the 3rd sample on the printing series. It demonstrates how to print your maps in high quality. This new feature for Map Suite is available in version 9.0.483.0 or later. From the sample you will better understand how to use DPI for handling print quality. The sample is based on raster images, but could also be used with vector data.
screenshot
map_suite_wpf_desktop_edition_printing_samples.txt · Last modified: 2017/03/17 02:11 by tgwikiupdate
