This sample demonstrates how to save the features in a shape file (.shp) into a Sqlite file (.sqlite) for a higher query performance. This takes the built-in functionalities of recent daily builds after 9.0.0.1/9.0.1.0 or later, which you can download from the ThinkGeo Customer Portal or Map Suite Product Center.
This sample shows how to create indexed raster layer. The sample supports rTree index file and create it if not exist. It is high performance for multiple raster layers.
This sample shows how you can do a redisence search via Geocoder, you can build the custom index based on your data, then do a custom search based on the index. In this sample, you can search a House Number and Street Name, the result shows low & high Cross Streets and low & high House Number, then highlight them on map.
