This sample demonstrates how to save the features in a shape file (.shp) into a Sqlite file (.sqlite) for a higher query performance. This takes the built-in functionalities of recent daily builds after 9.0.0.1/9.0.1.0 or later, which you can download from the ThinkGeo Customer Portal or Map Suite Product Center.
This sample shows how to create indexed raster layer. The sample supports rTree index file and create it if not exist. It is high performance for multiple raster layers.
