This sample demonstrates how to save the features in a shape file (.shp) into a Sqlite file (.sqlite) for a higher query performance. This takes the built-in functionalities of recent daily builds after 9.0.0.1/9.0.1.0 or later, which you can download from the ThinkGeo Customer Portal or Map Suite Product Center.
This sample show how to create index raster layer. The sample support Rtree and create index file when it does not exist. The Rtree makes application run faster.
