map_suite_wpf_desktop_edition_miscellaneous_samples
Map Suite Wpf Desktop Edition Miscellaneous Samples
Custom Scale Bar
Draw Custom Exception
MDI Form
Topology Validation
Use Map with MVC Framework
ShapeFile to SQLite Convertion Tool
This sample demonstrates how to save the features in a shape file (.shp) into a Sqlite file (.sqlite) for a higher query performance. This takes the built-in functionalities of recent daily builds after 9.0.0.1/9.0.1.0 or later, which you can download from the ThinkGeo Customer Portal or Map Suite Product Center.
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
<div sample_otherlinks> [
map_suite_wpf_desktop_edition_miscellaneous_samples.1444462269.txt.gz · Last modified: 2015/11/05 05:18 (external edit)
