View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
Applies To:
ShapeFile to SQLite Convertion Tool====^ Screenshot ^ width=78|Sample ^ width=66|Product ^ Description ^|
| View Source
C# Download
Need it in another language? | Desktop \\ \\
| This sample demonstrates how to save the features in a shape file (.shp) into a Sqlite file (.sqlite) for a higher query performance. This takes the built-in functionalities of recent daily builds after 9.0.0.1/9.0.1.0 or later, which you can download from the ThinkGeo Customer Portal or Map Suite Product Center.
</div>
