The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples. Available in both C# and VB.NET, these samples are designed to hit all the highlights of Map Suite, from simply adding a layer to a map to performing spatial queries and applying a thematic style. Consider this collection your “encyclopedia” of all the Map Suite basics and a great starting place for new users.
Today we have the Desktop version of the Web project “GPS to Google”. In this project, we show how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
Map Suite Samples Applies To: Desktop \ Web \ Silverlight \ Services \ Wpf
Need it in another language?
In this wpf-based project, we'll demonstrate the new ArcGISServerRestLayer released with Map Suite 9.0. This layer gives developers a simple and powerful tool to access their maps that reside on ArcGIS Server. This new layer utilizes the ArcGIS Server REST API. Now, the latest version of Map Suite Core can support that. In order to run this project, you will need the Development Build 9.0.443.0 or later.
In this wpf-based project, it illustrates how to get the features from the ArcGIS Restful Server. On the left side of the screenshot shows the raster data from ArcGIS Server and on the other side shows the features from ArcGIS Restful Server. In order to run this project, you will need the Development Build 9.0.482.0 or later.
As with Dynamic Info on TrackShape project, it shows how TrackOverlay can be extended to add some custom functionalities.
You will see how to handle some events of the map such as KeyDown and how to manipulate TrackOverlay.
With EditInteractiveOverlay, we know how to drag a feature such as polygon as a whole. We also know how to drag an individual vertex by setting the appropriate properties. Here we go a little further and we show how to create an inherited class from EditInteractiveOverlay to implement the logic for selecting vertices and dragging them as a group. See how the protected methods MouseDownCore, MouseUpCore, MouseClickCore and MouseMoveCore were overridden for that purpose. This is a Desktop app that also applies to Wpf.
This project is another example of how extendible EditInteractiveOverlay is for the editing needs of the user. You can see how to change the styles of the vertex being dragged based on the Shift key and have the vertex snap to any feature. Thanks to the protected override functions such as KeyDownCore, KeyUpCore, MouseUpCore and DrawCore, these functionalities can be easily implemented by inheriting from EditInteractiveOverlay.
In our series of projects dedicated to EditInteractiveOverlay, today you will see how easy it is to add some labeling to your dragged control point showing dynamic information. Here we show how to display the distance from the dragged control point to the closest point of a reference shape. Also, to augment the experience of the user, the closest point of the reference shape is also shown varying as the control point is dragged around.
In the GIS field, enterprises have different needs on how they edit there data and on how smooth the editing should be allowing the maximum control and precision to the technician editing the data. This example on how to use the EditInteractiveOverlay demonstrates how powerful and flexible editing is with Map Suite map control.
The purpose of today’s project is not so much as show a new technology as to show an improvement in an existing one. We are already familiar with EditInteractiveOverlay with projects such as “Dragged PointStyle with Label”, “Snap To Layer” and “Snapping to Vertex”. But those projects showed EditInteractiveOverlay on small shapes. Using EditIntercticeOverlay on complex shapes became not very responsive. We improved that and now you can drag, resize, rotate and drag individual vertex of a complex polygon made of thousand of vertices with good responsiveness as you can see in this example.
To run this Desktop project, you will need the version 4.0.66.0 or later of the development daily build for MapSuiteCore and DesktopEdition dlls. And do not forget to add a reference to WindowsBase.dll.
This improvement is currently only in the development branch, it will be added to the production branch at the next major release in November.
This sample shows how to extend the EditInteractiveOverlay rectangles as shapes rather than polygon shapes by setting special column values. For features (Well Known Text and Binary), the concept of a rectangle is not supported and typically rectangles are handled as polygons. This feature allows users to modify the rectangle but requires that the modification keep a rectangular form. The rectangle doesn't need to be straight as long as all of the corner angles are at 90 degrees relative to each other.
To activate the feature, you need to assign the value of the column called “Edit” to “rectangle”. The resize function will keep the ratio of width and height of the rectangle, otherwise it will use the original method.
http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5822/afv/topic/Default.aspx
This project is meant to respond to a limitation with aborting tracking a shape in the project TrackOverlay with Esc. Now we can abort the tracked shape from the first vertex being added. Notice how we used a new class CustomTrackInteractiveOverlay inheriting from TrackInteractiveOverlay for this purpose.
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “[ColumnName1][ColumnName2]…“ and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
To make sure this sample work, you will need to use the latest Development daily build of “MapSuiteCore.dll” and “WpfDesktopEdition.dll”, version 9.0.477.0 or higher.
In today's WPF project, we show you how to take advantage of Map Suite to load the Keyhole Markup Language (KML) file, which is an XML notation for expressing geographic annotation and visualization within Internet-based brwosers. With the latest KML support in Map Suite, you can eaisily display such files on a Map Suite control, including adorment pictures, placemarks etc. Also you can do the conversion between KML and any other vector formats supported by Map Suite componenets.
In today's WPF project, we show you how to apply the quick filters to a FeatureSource with the help of LinkSource and LinkExpressions. With the LinkExpreesion, we can specify the query string to determine which features will be displayed. This feature can be applied in all Map Suite products.
In today's WPF project, we show you how to query and display real time NOAA wather station data directly as a Layer, which allows you to display up-to-date weather station data from around the world on top of your maps. The weather station data is sourced from NOAA and is refreshed every 15 minutes in the background. As these classes are inherited from the FeatureSource and FeatureLayer, many properties are querable and can be used to create a variety of maps or analysis of current weather patterns. This feature can be applied in all Map Suite products.
In today's WPF project, we show you how to add the Magnetic Declination or Magnetic variation to the map, it's designed as an AdormentLayer, which is used for showing the angle on the horizontal plane between magnetic north (the direction in which the north end of a compass needle, corresponding to the direction of the Earth's magnetic field lines) and true north (the direction along a meridian towards the geographic North Pole). This angle varies depending on one's position on the Earth's surface, and over time. See http://en.wikipedia.org/wiki/Magnetic_declination for more details. This feature can be applied in all Map Suite products.
In this WPF project, we show you how to use the Delay Map Drawing feature to control whether or not redraw the layer after a specified delay. This option is very helpful for anyone wanting to do something before actually refresh the map, such as editing the elements, adding an animation etc. This effect can be avaible in all Map Suite products.
In this Wpf project, we explore more capabilities of the PopupOverlay and its collection of Popups. With the Content property, we can add a TextBox or any other control to a Popup. For example, here we show how to have the column value of a selected feature appear in a Popup on the user MapClick event. Notice how that column value can be easily changed by typing in the TextBox of the Popup and committing the edit.
The purpose of this Wpf project is to show how to use the new SaveState and LoadState of the SimpleMarkerOverlay. We show how you can simply drag the icons to change their location, save their state to a file and then reload the state from that file. For this sample to work, you will need to use the latest production daily build of “MapSuiteCore.dll” and “WpfDesktopEdition.dll”, version 4.0.40.87 or higher. This project applies to Map Suite Wpf Desktop Edition only.
This project shows how to consume data from a WMTS Server using WmtsOverlay. You would find the code pretty straightforward, while behind the scenes we request tiles from the server asynchronously and efficiently, and stitch them into a proper map.
This class is introduced from version 6.0.187.0, besides this WmtsOverlay, we also have WmtsLayer available. Here is the WMTSLayer Sample.
Video Overview
Notes from the developer:
Rotating the map:
Displaying the North Arrow:
The purpose of this sample is to show you a quick and easy way to read data from a SQL data source and display it on the map using an InMemoryFeatureLayer
. Since geometric feature data can be stored in a number of different formats such as X and Y coordinates, WKT (Well Known Text), and Geometry data types, this sample shows you how to load, edit and save data to a SQL data source for each different type of format. The sample includes a SQL script you need to run first, in order to create and populate a SQL Server table with sample data. You will also need to change the connection information in the code on lines 71 and 204 so that it points to your SQL Server.
Note: The approach in this sample works best for small amounts of data (less than 10,000 features) since it loads all of the data into memory. For larger datasets, we recommend using the SQL2008FeatureLayer
or the ''OledbFeatureSource'', which only reads the data for the given extent you are working in (much more efficient for larger datasets).
On the web site
This sample demonstrates how to save the features in a shape file (.shp) into a Sqlite file (.sqlite) for a higher query performance. This takes the built-in functionalities of recent daily builds after 9.0.0.1/9.0.1.0 or later, which you can download from the ThinkGeo Customer Portal or Map Suite Product Center.
This sample shows how to create indexed raster layer. The sample supports rTree index file and create it if not exist. It is high performance for multiple raster layers.
This sample shows how to offset arc shaped flight lines so multiple from point to point are visible and then show popup labels providing information on the flights the lines represent.
This WPF project is the second in our series of samples on printing. The first introductory sample served as a presentation of the different printing concepts such as page layout, the map element, legends, titles, data grids, logos and the user's interaction with them. Using all of the printing tools we introduced in the first sample, here we will demonstrate a real-world print scenario at a large scale with data for parcels at a county level. By reading the descriptive comments within the sample code itself, you will better understand how to handle your printing needs and follow cartographic standards for map presentation.
This WPF project is the 3rd sample on the printing series. It demonstrates how to print your maps in high quality. This new feature for Map Suite is available in version 9.0.483.0 or later. From the sample you will better understand how to use DPI for handling print quality. The sample is based on raster images, but could also be used with vector data.
In this Wpf sample is on the same theme as the previous sample WrapDatelineMode. Here we show how to take advantage of the projection class WrapDatelineProjection for doing spatial query when on a “virtual map”. From this spatial query example, the developer should understand how the same principle using the same projection class can be applied for other operations such as Spatial Queries, Identify etc. In order to run this sample, you will need the latest Dev Daily Build for Wpf with references to MapSuiteCore.dll and WpfDesktopEdition.dll.
In this Wpf project, we show a new property of Overlay, WrapDatelineMode. When you set this property to WrapDatelineMode.WrapDateline, the overlay will display to the right or left as you continuously pan west or east. This is very useful when dealing with world maps and you want to display the pacific rim as one extent. You have to be aware that this feature comes with some limitations. For example, on the “virtual” maps, the world coordinates are no longer valid and you need a special projection that we created (WrapDatelineProjection) to have the world coordinates displaying correctly. In order to run this sample, you will need the latest Dev Daily Build for Wpf with references to MapSuiteCore.dll and WpfDesktopEdition.dll.
This WPF project shows how to get a route between 2 adjacent roads even if they don't intersect within an allowable tolerance. It’s based on Map Suite Geometry Topology module and does not require the Map Suite Routing Extension.
Note: This sample requires MapSuiteCore.dll newer than Daily development build version 9.0.178.0 or Daily Production Build version 9.0.0.178.
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinate needs to be set so that the feature get selected within a constant distance in screen coordinate to where the user clicked on regardless on the zoom level. This project will show how to accomplish that task regardless of the layer type (polygon, line or point based) and the zoom level of the current extent of the map. This is a Desktop project.
From the Performance Guide:
ClusterPointStyle is integrated into Map Suite's core. In this project you will see how to use the ClusterPointStyle for clustering various features into one. Sometimes, the map may have too many features which are stacked on top of each other making the map illegible at higher zoom levels. Clustering is a useful technique as it allows you to group together various features into one labeled symbol with the count of all the features. This latest sample also includes recent performance enhancements to the clustering API.
In today's Wpf project, we show you how to apply the FilterStyle to a layer's display. By using this style, the map will filter the features queried from the source file by checking if a specified column value fits the input condition. This effect can be applied to all the Map Suite products.
In today’s project, we learn how to extend InMemoryFeatureLayer to have the ability to display animated gif for each layer in the Desktop edition. You will notice that for now, we are limited to have one animated gif per InMemoryFeatureLayer but in the future, we will show the technique to have a different animated gif for each feature of the InMemoryFeatureLayer.
