map_suite_wms_server_edition
Map Suite WMS Server Edition
Map Suite WMS Server Edition is the fastest and easiest way to set up a high-performance, scalable and standards compliant Web Map Service (WMS). With Map Suite WMS Server, you can create a cloud-based, load-balanced map service that can be consumed by any client application that supports WMS, including clients built with Map Suite GIS components.
Product Guides
This guide helps you get you up to speed with integrating the Map Suite WMS Server Edition map control into your GIS software.
This guide walks you through installing the map control on your system and creating a simple GIS application.
This guide walks you through deploying your GIS software using the map control into a production environment.
This guide introduces the dependencies Map Suite WMS Server Edition needs with their features, versions and source websites.
This guide walks you through various ways you can increase performance in your .Net GIS application.
This guide walks you through using SQLite as a storage format.
API Documentation
  • ThinkGeo.MapSuite.Core
    The Core API documentation covers the ThinkGeo.MapSuite.Core namespace which resides in the MapSuiteCore.dll assembly. It contains all of the core GIS classes that are shared between the different Map Suite edition map controls and servers. It includes such classes as Style, FeatureSource, Layer, Projection etc. This is where the bulk of the classes are for most of the Map Suite products.
  • ThinkGeo.MapSuite.WmsServerEdition
    The WMS Server Edition API documentation covers the ThinkGeo.MapSuite.WMS ServerEdition namespace which resides in the WMS ServerEditon.dll assembly. It contains all of the WMS Server Edition specific classes such as the map control itself, Overlays, and supported map classes.
Code Samples
We have provided hundreds of .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself.
All Samples
All samples about Map Suite Services Edition.
Project Templates
These projects show various study cases based on Wms Server Edition.
Demos
You can view an interactive sample of Map Suite World Map Kit here.
Videos
WPF Edition Sample App Walkthrough Video Series
Step through the WMS Server Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Screenshot
Introduction to the WMS Server Edition
Creating Custom Styles
Exploring Layers
Exploring Layers
FDO, OGR and GDAL Extension
Printing System Introduction
Tile Cache Generator
Topology Validation
Topology Validation
Screenshots
The WMS Server Edition screenshots gallery section showcases a wide range of screenshots covering various GIS features of the WMS Server Edition map control.
Automatically detects and loads WMS plugins
Lets you preview your map
Automatically detects and loads WMS plugins Lets you preview your map
Uses ZedGraph classes
Plots points on your map
Point density represents numeric dataer.
Plots points on your map Point density represents numeric dataer.
Puts you in control
Render features specifically based on a theme
Colorize map features
Useful for points & labels
Connect points using the Great Circle model
Show accurate distances
Connect points using the Great Circle model Show accurate distances
Draw an image at a point
Project your spatial data
Change Logs
  • API Change Log
Frequently Asked Questions
  • General Questions
    These frequently asked questions cover GIS and map control topics that are not categorized in other areas.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_wms_server_edition.1442572423.txt.gz · Last modified: 2015/09/18 10:33 by admin
