map_suite_wms_server_edition
Map Suite WMS Server Edition
Map Suite WMS Server Edition is the fastest and easiest way to set up a high-performance, scalable and standards compliant Web Map Service (WMS). With Map Suite WMS Server, you can create a cloud-based, load-balanced map service that can be consumed by any client application that supports WMS, including clients built with Map Suite GIS components.
Product Guides
This guide helps you get you up to speed with integrating the Map Suite WMS Server Edition map control into your GIS software.
This guide explains how to use styles in Map Suite to beautifully represent your GIS mapping data. The guide includes an overview of styles, a detailed explanation of the various styles that ship with Map Suite, as well as a step by step guide of creating your own custom styles.
This guide explains how to use our custom serialization class to render your Map Suite objects to XML, or other format etc. This allows your GIS application to easily save things such as Layers, Styles, or even whole maps to XML to be recalled at a later time. The guide includes an overview of serialization system, and detailed explanation of the various classes, as well as information on creating your own serializer.
This guide walks you through installing the map control on your system and creating a simple GIS application.
This guide walks you through deploying your GIS software using the map control into a production environment.
This guide introduces the dependencies Map Suite WMS Server Edition needs with their features, versions and source websites.
This guide walks you through various ways you can increase performance in your .Net GIS application.
This guide walks you through using SQLite as a storage format.
API Documentation
  • ThinkGeo.MapSuite.Core
    The Core API documentation covers the ThinkGeo.MapSuite.Core namespace which resides in the MapSuiteCore.dll assembly. It contains all of the core GIS classes that are shared between the different Map Suite edition map controls and servers. It includes such classes as Style, FeatureSource, Layer, Projection etc. This is where the bulk of the classes are for most of the Map Suite products.
  • ThinkGeo.MapSuite.WmsServerEdition
    The WMS Server Edition API documentation covers the ThinkGeo.MapSuite.WMS ServerEdition namespace which resides in the WMS ServerEditon.dll assembly. It contains all of the WMS Server Edition specific classes such as the map control itself, Overlays, and supported map classes.
Code Samples
We have provided hundreds of .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself.
All Samples
All samples about Map Suite Services Edition.
Project Templates
These projects show various study cases based on Wms Server Edition.
Demos
You can view an interactive sample of Map Suite World Map Kit here.
Change Logs
  • API Change Log
Frequently Asked Questions
  • General Questions
    These frequently asked questions cover GIS and map control topics that are not categorized in other areas.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_wms_server_edition.1441953490.txt.gz · Last modified: 2015/09/11 06:38 by admin
