map_suite_windows_phone_edition_all_samples
Table of Contents
Map Suite Windows Phone Edition All Samples
GPS to Google Map(Web)
Great Circle with Google Map
OpenStreetMap
Shapefile to Google Map
Custom Track Line
Custom Track Polygon
Dragged Point Style
Dynamic Info On TrackShapes
EditOverlay Styles
Select with Track Shape
Tracked Shapes to WKT
Vertex Tolerance
Labeling based on size
MultiLine Labeling
Multiple Labels
Decimal Degrees Formatting
LEAD Technologies Inc. V1.01
Label to Show Location
Labeling Based On Columns
Multi Column Labeling
Best Practices - Silverlight Edition
You can also check outPart 1 and Part 2 of the video which provides a brief summary of this sample.
Custom Scale Bar
Draw Custom Exception
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
<div sample_otherlinks> [
Custom Scale Bar
MDI Form
Use Map with MVC Framework
Use Progress Bar
Datum Transformation
Geodetic to State Plane
Geodetic to UTM on the fly
GeoRaster Projection
Measurements Decimal Degrees
Pacific Rim
Polygon across Meridian
Projection Distortion
Projection in Feet
Routing with Projections
Save To Projection
Street Intersection
World Coordinates
Clipping On Line Layer
Create Inner Ring
FeatureIdsToExclude
Get Feature Clicked On(Web)
Get Feature Clicked On(Web)2
Intersect Line
Polygon Shapes To Multipolygon Shapes
Sweep Angle Desktop
Clipping
Convex Hull
Correcting Nodes
Create Polygon Programatically
Dissolve on Shapefile
Draw a Pie shape
Dynamic Segmentation
Get Feature Clicked On With Projection
Identify Point with Icon
Inner Ring Containment
Intersecting Multi Polygon
Intersecting Two Layers
Merge Line Layers
Merge Point Layers
Merging Layers
Multi Ring Buffering
Negative Buffering
Offset Point at Right Angle
Register Shape
Remove LineShape
Spatial Join
Split Polygon
Split Polygon Based On Grid
From the Performance Guide:
Split Polygon Dynamically into Grids based on the Area
Sweep Angle
Splitting Polygons with a Line
Adjusted Scaling Image Style
Cached Value Style
ClusterPointStyle
Default ValueStyle
Displaying One-Way Streets
Distance Line Style
Doughnut Point Style
EditOverlay Styles
Feature Centric Style
Flashing Point Style
Hybrid TextStyle
This project is a follow up to the Discussion Forum post at here
In this project, we create a new Text Style combining word wrapping that we saw in the project
http://code.thinkgeo.com/projects/show/wordwrapped and text rotation. You can see the labels word wrapping and rotating in harmony with the resizing and rotating of the shapes.
Line Style With Increment
Multiple Dot Density Styles
MultiLine Labeling
Projection Distance LineStyle
Rotate Icon
Routing Styles
Scaling Image Style
Scaling TextStyle
Scaling TextStyle for Polygon
Side View Icon
Sized Point Style
Smooth Transparent Route
Start End LineStyle
TextStyle for Multi Line
Time Based Point Style
Time Line
ValueStyle with Countries
Weather Line Style
WordWrapped TextStyle
World Sized Image Style
World Sized Text Style
Cached Value Style
ClusterPointStyle
Hybrid TextStyle
Image Style
Isolines
Rotate Icon
Routing Styles
Scaling Image Style
Scaling TextStyle
Sized Point Style
Start End LineStyle
Time Line
Label Point with Circle Symbol and Mask Description
Center Map Based On Lat/Long
Centering Map with Tolerance
GetZoomLevel
Map Scales
Raster Layer with extent
Restricting Extent
Zoom In To Feature
Zoom In To Point
Zoom Levels Partitioning
Zoom to Full extent
map_suite_windows_phone_edition_all_samples.1441940623.txt.gz · Last modified: 2015/09/11 03:03 by admin
