Render the layer of MapSuite supported data format with Ma Suite WebAPI Edition. This sample contains vector layers, raster layers and web services layers samples. You can build up your own layers within your application.
Video Overview
Notes from the developer:
Rotating the map:
Displaying the North Arrow:
On the web site
