A setting for ClassBreakMarkerStyle that contains APIs to set properties of ClassBreakMarkerStyleSetting using in MVC view.
A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view.
A setting for FeatureOverlayStyle that contains APIs to set properties of FeatureOverlayStyleSetting using in MVC view.
A setting for MarkerStyle that contains APIs to set properties of MarkerStyleSetting using in MVC view.
A setting for PointMarkerStyle that contains APIs to set properties of PointMarkerStyleSetting using in MVC view.
A setting for ValueMarkerStyle that contains APIs to set properties of ValueMarkerStyleSetting using in MVC view.
HtmlHelper extension for providing access to the Mvc controls inherited from MvcControlBase
A setting for WmsOverlay that contains APIs to set properties of WmsOverlaySetting using in MVC view.
A setting for WorldMapKitWmsWebOverlay that contains APIs to set properties of WorldMapKitWmsWebOverlaySetting using in MVC view.
In a class break style, this enumeration determines whether the break includes or excludes the value entered in the break.
Represents an overlay object that gets map images from the WMS servers.
This is an asynchronous HTTP handler which is used to handle web map services.
This class is the abstract base-class for defining the fluent interface of classes which are not inherited from MvcControlBase, but used in a Mvc control.
This class indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “True”, otherwise, you need to copy images to the directory.
This class is used to indicate whether the application allows map to register the Web.config on the fly in runtime.
A setting for ContextMenuItem that contains APIs to set properties of ContextMenuItem using in MVC view.
A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view.
A setting for KeyboardMapTool that contains APIs to set properties of KeyboardMapTool using in MVC view.
A setting for LoadingImageMapTool that contains APIs to set properties of LoadingImageMapToolSetting using in MVC view.
A setting for MapTool that contains APIs to set properties of MapToolSetting using in MVC view.
A setting for MeasureMapTool that contains APIs to set properties of MeasureMapToolSetting using in MVC view.
A setting for MiniMapMapTool that contains APIs to set properties of MiniMapMapToolSetting using in MVC view.
A setting for MouseCoordinateMapTool that contains APIs to set properties of MouseCoordinateMapToolSetting using in MVC view.
A setting for MouseMapTool that contains APIs to set properties of MouseMapToolSetting using in MVC view.
A setting for OverlaySwitcherMapTool that contains APIs to set properties of OverlaySwitcherMapToolSetting using in MVC view.
A setting for PanZoomBarMapTool that contains APIs to set properties of PanZoomBarMapToolSetting using in MVC view.
A setting for PanZoomMapTool that contains APIs to set properties of PanZoomMapToolSetting using in MVC view.
A setting for ScaleLineMapTool that contains APIs to set properties of ScaleLineMapToolSetting using in MVC view.
A setting for TouchMapTool that contains APIs to set properties of TouchMapToolSetting using in MVC view.
This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
A setting for CloudPopup that contains APIs to set properties of CloudPopupSetting using in MVC view.
A setting for CustomPopup that contains APIs to set properties of CustomPopupSetting using in MVC view.
A setting for Popup that contains APIs to set properties of PopupSetting using in MVC view.
A setting for AdornmentOverlay that contains APIs to set properties of AdornmentOverlaySetting using in MVC view.
A setting for ArcGISServerRestOverlay that contains APIs to set properties of ArcGISServerRestOverlaySetting using in MVC view.
A setting for BingMapsOverlay that contains APIs to set properties of BingMapsOverlaySetting using in MVC view.
A setting for FeatureSourceMarkerOverlay that contains APIs to set properties of FeatureSourceMarkerOverlaySetting using in MVC view.
A setting for InMemoryMarkerOverlay that contains APIs to set properties of InMemoryMarkerOverlaySetting using in MVC view.
A setting for LayerOverlay that contains APIs to set properties of LayerOverlaySetting using in MVC view.
A setting for MarkerOverlay that contains APIs to set properties of MarkerOverlaySetting using in MVC view.
A setting for SimpleMarkerOverlay that contains APIs to set properties of SimpleMarkerOverlaySetting using in MVC view.
A setting for EditFeatureOverlay that contains APIs to set properties of EditFeatureOverlaySetting using in MVC view.
A setting for FeatureOverlay that contains APIs to set properties of FeatureOverlaySetting using in MVC view.
A setting for GoogleOverlay that contains APIs to set properties of GoogleOverlaySetting using in MVC view.
A setting for HighlightFeatureOverlay that contains APIs to set properties of HighlightFeatureOverlaySetting using in MVC view.
A setting for OpenStreetMapOverlay that contains APIs to set properties of OpenStreetMapOverlaySetting using in MVC view.
A setting for Overlay that contains APIs to set properties of OverlaySetting using in MVC view.
Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
Represents a FeatureOverlay that can easily apply a highlight style or hook event to the features in it.
Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
This class is the base class for all classes that define the styles applied to the markers.
Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
This class represents a collection of MarkerZoomLevels that determines the appearance of markers at different zoomlevels.
Serves as the base class that defines the methods and properties common to all types of popups.
This class allows you to match a value with data in the feature to determine how to draw the feature.
Represents a strong-typed collection that can be accessed by index or by the identifier of an item.
Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
This Class defines the utility for managing, registering or adding the client script libraries and script files of Mvc application to the page.
This Class defines the utility for managing, registering or adding the Css files to the page which included the specified control.
This class provides a abstract base class to defines the fluent interface for configuring the Mvc control.
Represents an animation pan tool which allows map pans to the position which users click using the transition effect.
Represents a small image that displays at the center of the map when the map is loading.
Represents a company logo or other logo-type image that displays in the lower right corner of the map.
Contains the different map tools as properties and acts as an entrance for setting these map controls.
The display system units for output measurements. Supported values are ‘english’, ‘metric’, and ‘geographic’. Default is ‘metric’.
Represents the coordinates of the mouse pointer, displayed in the lower right corner of the map.
This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
Represents a panel in the upper right corner of the map, containing a list of overlays in the map.
Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html ;specifically, the URL provided to this layer should be an export service URL: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/export.html
Represents an overlay object that gets images from Microsoft's Virtual Earth server.
Represents a FeatureOverlay whose features can be added or edited at the client side.
Serves as the base class for the overlays that contain features and paint the features at client side.
This enumeration specifies the picture formats when getting images back to client from Google Maps.
This enumeration represents which projection will use for world map kit.
