map_suite_web_for_webapi
Map Suite Web for WebAPI
Map Suite Web for WebAPI allows you to easily build REST based web services to do the server side rendering, querying and geometric functions in your HTML5/Javascript application utilizing any JavaScript mapping client library (Leaflet, OpenLayers3 & KendoUI).
Getting Started
Map Suite Web for WebAPI Quickstart On Windows
Map SuiteWeb for WebAPI Quickstart on Linux
Run GitHub Sample on Linux (3'06”)
Map Suite Web for WebAPI Hello World
Hello World on Windows (3'09“)
Helps you get started building your first application with the Map Suite Web for WebAPI.
Product Guides & Appendices
Introduces the dependencies Map Suite Web for WebAPI needs with their features, versions and source websites.
Walks you through deploying your project using the map control into a windows azure cloud service and register the map control.
Show Map Suite features doverage of different product and different platfoms
Learning Samples
Learn More
Browse the demo applications to see the power of Map Suite Web for WebAPI and how it can be utilized to build professional grade mapping applications using both the Leaflet and OpenLayers JavaScript mapping libraries.
Package
Standard
Compare with Barebone
Barebone
Compare with Standard
API Documentation
  • ThinkGeo.MapSuite.WebApi
    The Map Suite Web for WebAPI API documentation covers the ThinkGeo.MapSuite.WebApi namespace which resides in the ThinkGeo.MapSuite.WebApi.dll assembly. It contains all of the Map Suite Web for WebAPI specific classes such as the map control itself, Overlays, and supported map classes.
Change Logs
  • API Change Log
    The Map Suite Web for WebAPI change log details the changes made to the product for each major release cycle.
Videos
Map Suite Web for WebAPI Sample App Walkthrough Video Series
Step through the Map Suite Web for WebAPI sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
Screenshot
Getting Started
Screenshot
Overlays
Screenshot
Layers
Screenshot
Styles
Screenshot
Visualizing Data
Screenshot
Labeling
Screenshot
Markers & Pop Ups
Screenshot
Drawing & Editing
Screenshot
Querying
Screenshot
Projection
Screenshot
Geometric Functions
Screenshot
Project Templates
Screenshot
WebAPI Webinar November 19, 2015
Screenshot
Adornments
Screenshot
Topology
Screenshot
Printing
Creating Custom Styles
Exploring Layers
Exploring Layers
FDO, OGR and GDAL Extension
Printing System Introduction
Tile Cache Generator
Topology Validation
Topology Validation
Screenshots
Screen Shots of the Map Suite Web for WebAPI on different types of devices.
Traditional Browsers
Getting Started with Map
Visualization
Visualization
LabelStyling
LabelStyling
GeoFunctions
GeoFunctions
DrawEditFeatures
DrawEditFeatures
SiteSelection
SiteSelection
Visualization-weather
Tablets
GettingStarted
GettingStarted
Visualization
Visualization
LabelStyling
LabelStyling
GeoFunctions
GeoFunctions
DrawEditFeatures
DrawEditFeatures
SiteSelection
SiteSelection
Phones
GettingStarted
GettingStarted
Visualization
Visualization
LabelStyling
LabelStyling
GeoFunctions
GeoFunctions
DrawEditFeatures
DrawEditFeatures
SiteSelection
SiteSelection
Frequently Asked Questions
  • General Questions
    All the frequently asked questions about Map Suite Web for WebAPI.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_web_for_webapi.1490601031.txt.gz · Last modified: 2017/03/27 07:50 by kevinlaw
