map_suite_web_for_mvc_features_bug_fixes_change_log
Map Suite Web For MVC Edition Features & Bug Fixes Change Log
Version 10.1.0.0
Release date: 06/15/2017
ThinkGeo.MapSuite.Mvc Namespace:
ThinkGeo.MapSuite Namespace:
Version 10.0.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Fixed a bug when highlighting the selected feature.
  • Fixed a bug that the popup close button is unable to click if AdornmentOverlay is added.
  • Fixed an exception when moving a DraggableMarker.
  • Fixed a bug that sets projection for ArcGISServerRestOverlay.
  • Fixed a bug that visible of marker is in inoperative.
  • Reduced the markers' size when there is no rotation.
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.MvcEdition Namespace:
  • Fixed a bug where the backgroud color is missed when calling PrintMap() method.
  • Fixed a bug where it's unable to zoom in/out with IE8 if an AdormentOverlay is added to the map.
  • Fixed a bug where some configurations of HighlightOverlay on server side is not passed to client side.
  • Fixed a bug where it's unable to disable the Google or any other third part JavaScript libraries.
  • Created a single JS file “thinkgeo.mvc.min.js” for client JavaScript library to improve loading performance.
  • Changed loading strategy of SimpleMarkerOverlay and Popups from once initialization to dynamically request.
  • Added support of ModelBinding on map control.
  • Changed the strategy of popups loading from first load initialization to ajax loading.
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
  • Fixed a bug where some properties are not configured correctly on client side for HightlightOverlay.
  • Fixed a bug where the property of “IsDefaultJavascriptLibraryDisabled” doesn't take effect.
  • Fixed a bug where it's unable to zoom In/Out in IE8 if adornment layer is added.
Version 8.0.0.0
Release date: 06/06/2014
  • Fixed a bug where it's unable to create markeroverlay in controller.
  • Added supported to hide the default Markeroverlay in OverlaySwitcher.
  • Fixed a bug where the db connection is never closed in oraclefeaturelayer.
  • Fixed a bug where the attribution control covers the other elements in map.
  • Upgraded the Openlayers used in MvcEdition from 2.11 to 2.13.1.
  • Fixed a bug where client function Map1.getMarkerOverlay returns null.
  • Fixed a bug where NTS doe
map_suite_web_for_mvc_features_bug_fixes_change_log.1498021608.txt.gz · Last modified: 2017/06/21 05:06 by tgwikiupdate
