map_suite_web_for_mvc_features_bug_fixes_change_log
Map Suite Web For MVC Edition Features & Bug Fixes Change Log
Version 10.0.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
ThinkGeo.MapSuite.Mvc Namespace:
  • Fixed a bug when highlight the selected feature.
  • Enhanced file license.
  • Fixed a bug where it's unable to click the close button of popup if AdornmentOverlay is added.
  • Fixed a bug that Draggable Markers throw an exception.
  • Fixed a bug that sets projection for ArcGISServerRestOverlay.
  • Fixed marker visible issue.
  • Reduced the markers' size when there is no rotation.
ThinkGeo.MapSuite Namespace:
  • Added style sheets support.
The following was created before Map Suite 10. Map Suite 10 organized many classes into new namespaces and assemblies as well as had a few minor breaks in compatibility. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code check out this wiki article. http://wiki.thinkgeo.com/wiki/map_suite_10_update_guide
Version 9.0.0.0
Release date: 06/24/2015
ThinkGeo.MapSuite.MvcEdition Namespace:
  • Fixed a bug where the backgroud color is missed when calling PrintMap() method.
  • Fixed a bug where it's unable to zoom in/out with IE8 if an AdormentOverlay is added to the map.
  • Fixed a bug where some configurations of HighlightOverlay on server side is not passed to client side.
  • Fixed a bug where it's unable to disable the Google or any other third part JavaScript libraries.
  • Created a single JS file “thinkgeo.mvc.min.js” for client JavaScript library to improve loading performance.
  • Changed loading strategy of SimpleMarkerOverlay and Popups from once initialization to dynamically request.
  • Added support of ModelBinding on map control.
  • Changed the strategy of popups loading from first load initialization to ajax loading.
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
  • Fixed a bug where some properties are not configured correctly on client side for HightlightOverlay.
  • Fixed a bug where the property of “IsDefaultJavascriptLibraryDisabled” doesn't take effect.
  • Fixed a bug where it's unable to zoom In/Out in IE8 if adornment layer is added.
Version 8.0.0.0
Release date: 06/06/2014
  • Fixed a bug where it's unable to create markeroverlay in controller.
  • Added supported to hide the default Markeroverlay in OverlaySwitcher.
  • Fixed a bug where the db connection is never closed in oraclefeaturelayer.
  • Fixed a bug where the attribution control covers the other elements in map.
  • Upgraded the Openlayers used in MvcEdition from 2.11 to 2.13.1.
  • Fixed a bug where client function Map1.getMarkerOverlay returns null.
Version 7.0.0.0
Release date: 06/03/2013
  • Added the documentation for new APIs
  • Added GeoCanvas as map's control property
  • Added the Wiki page on wiki.thinkgeo.com
  • Fixed a bug that the tiles are not displayed when connected to WMS Servers
  • Fixed a bug that there was a loading image location offset which is on map’s left bottom
  • Fixed a bug that it would cause memory leak in Internet Explorer 9
  • Fixed a bug that ClassBreak is not used when ColumnValue matches BreakValue and BreakValueInclusion = IncludeValue
Version 6.0.0.0
Release date: 05/14/2012
  • Added Google Map's StreetView to GoogleMapOverlay
Version 5.5.109.0
Beta Release date: 29/02/2012
Beta Release - No Changes
map_suite_web_for_mvc_features_bug_fixes_change_log.1488363715.txt.gz · Last modified: 2017/03/01 10:21 by tgwikiupdate
