map_suite_web_for_mvc_features_bug_fixes_change_log
Version 10.0.0.0
Release date: 02/16/2017
ThinkGeo.MapSuite.Mvc Namespace:
  • Fixed a bug that highlight select feature.
  • Enhance file license.
  • Fixed a bug where it's unble to click the closebutton of popup if AdornmentOverlay is added.
  • Fixed a bug that Draggable Markers throw an exception.
  • Fixed a bug that sets projection for ArcGISServerRestOverlay.
  • Fixed marker visible issue.
  • Fixed a issue that Reduce the markers' size when there is no rotation.
ThinkGeo.MapSuite Namespace:
  • Added style sheets support.
map_suite_web_for_mvc_features_bug_fixes_change_log.1487577124.txt.gz · Last modified: 2017/02/20 07:52 by tgwikiupdate
