map_suite_web_for_mvc_api
ThinkGeo.MapSuite.Mvc
  • CursorType WindowsLinuxMac
    This enumeration determines the cursor that appears when the pointer moves over the map.
  • TileType WindowsLinuxMac
    This enumeration specifies whether the overlay uses tiling.
  • IJsonSerialization WindowsLinuxMac
    Define an interface to allow class that implement Json conversion.
  • IEntity WindowsLinuxMac
    The corresponding to achieve the entity object and url string between the conversion.
  • ClassBreakMarkerStyleSetting WindowsLinuxMac
    A setting for ClassBreakMarkerStyle that contains APIs to set properties of ClassBreakMarkerStyleSetting using in MVC view.
  • ClusterMarkerStyleSetting WindowsLinuxMac
    A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view.
  • FeatureOverlayStyleSetting WindowsLinuxMac
    A setting for FeatureOverlayStyle that contains APIs to set properties of FeatureOverlayStyleSetting using in MVC view.
  • MarkerStyleSetting`2 WindowsLinuxMac
    A setting for MarkerStyle that contains APIs to set properties of MarkerStyleSetting using in MVC view.
  • PointMarkerStyleSetting WindowsLinuxMac
    A setting for PointMarkerStyle that contains APIs to set properties of PointMarkerStyleSetting using in MVC view.
  • ValueMarkerStyleSetting WindowsLinuxMac
    A setting for ValueMarkerStyle that contains APIs to set properties of ValueMarkerStyleSetting using in MVC view.
  • HtmlHelperExtension WindowsLinuxMac
    HtmlHelper extension for providing access to the Mvc controls inherited from MvcControlBase
  • WmtsOverlaySetting WindowsLinuxMac
    A setting for WmsOverlay that contains APIs to set properties of WmsOverlaySetting using in MVC view.
  • WorldStreetsAndImageryOverlaySetting WindowsLinuxMac
    A setting for WorldMapKitWmsWebOverlay that contains APIs to set properties of WorldMapKitWmsWebOverlaySetting using in MVC view.
  • MarkerBreakValueInclusion WindowsLinuxMac
    In a class break style, this enumeration determines whether the break includes or excludes the value entered in the break.
  • WmtsSeverEncodingType WindowsLinuxMac
    WMTS System.
  • WorldStreetsAndImageryOverlay WindowsLinuxMac
    Represents an overlay object that gets map images from the WMS servers.
  • MapHelper WindowsLinuxMac
    This static class exposes a number of helpful methods when dealing with map.
  • MultiThreadTileResource WindowsLinuxMac
    This is an asynchronous HTTP handler which is used to handle web map services.
  • SingleThreadTileResource WindowsLinuxMac
  • MvcElementSettingBase`2 WindowsLinuxMac
    This class is the abstract base-class for defining the fluent interface of classes which are not inherited from MvcControlBase, but used in a Mvc control.
  • ResourceDeploymentMode WindowsLinuxMac
    This class indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “True”, otherwise, you need to copy images to the directory.
  • WebConfigRegistrationMode WindowsLinuxMac
    This class is used to indicate whether the application allows map to register the Web.config on the fly in runtime.
  • ContextMenuItemCollection WindowsLinuxMac
    A collection of ThinkGeo.MapSuite.Mvc.ContextMenuItem objects.
  • ContextMenuItemSetting WindowsLinuxMac
    A setting for ContextMenuItem that contains APIs to set properties of ContextMenuItem using in MVC view.
  • ContextMenuSetting WindowsLinuxMac
    A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view.
  • AnimationPanMapToolSetting WindowsLinuxMac
  • KeyboardMapToolSetting WindowsLinuxMac
    A setting for KeyboardMapTool that contains APIs to set properties of KeyboardMapTool using in MVC view.
  • LoadingImageMapToolSetting WindowsLinuxMac
    A setting for LoadingImageMapTool that contains APIs to set properties of LoadingImageMapToolSetting using in MVC view.
  • LogoMapToolSetting WindowsLinuxMac
  • MapToolSetting`2 WindowsLinuxMac
    A setting for MapTool that contains APIs to set properties of MapToolSetting using in MVC view.
  • MeasureMapToolSetting WindowsLinuxMac
    A setting for MeasureMapTool that contains APIs to set properties of MeasureMapToolSetting using in MVC view.
  • MiniMapMapToolSetting WindowsLinuxMac
    A setting for MiniMapMapTool that contains APIs to set properties of MiniMapMapToolSetting using in MVC view.
  • MouseCoordinateMapToolSetting WindowsLinuxMac
    A setting for MouseCoordinateMapTool that contains APIs to set properties of MouseCoordinateMapToolSetting using in MVC view.
  • MouseMapToolSetting WindowsLinuxMac
    A setting for MouseMapTool that contains APIs to set properties of MouseMapToolSetting using in MVC view.
  • OverlaySwitcherMapToolSetting WindowsLinuxMac
    A setting for OverlaySwitcherMapTool that contains APIs to set properties of OverlaySwitcherMapToolSetting using in MVC view.
  • PanZoomBarMapToolSetting WindowsLinuxMac
    A setting for PanZoomBarMapTool that contains APIs to set properties of PanZoomBarMapToolSetting using in MVC view.
  • PanZoomMapToolSetting WindowsLinuxMac
    A setting for PanZoomMapTool that contains APIs to set properties of PanZoomMapToolSetting using in MVC view.
  • ScaleLineMapToolSetting WindowsLinuxMac
    A setting for ScaleLineMapTool that contains APIs to set properties of ScaleLineMapToolSetting using in MVC view.
  • TouchMapToolSetting WindowsLinuxMac
    A setting for TouchMapTool that contains APIs to set properties of TouchMapToolSetting using in MVC view.
  • AdornmentOverlay WindowsLinuxMac
    This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
  • CloudPopup WindowsLinuxMac
    Represents the popups that appear in a cloud (a.k.a. balloon) shape.
  • CloudPopupSetting WindowsLinuxMac
    A setting for CloudPopup that contains APIs to set properties of CloudPopupSetting using in MVC view.
  • CustomPopupSetting WindowsLinuxMac
    A setting for CustomPopup that contains APIs to set properties of CustomPopupSetting using in MVC view.
  • PopupSetting`2 WindowsLinuxMac
    A setting for Popup that contains APIs to set properties of PopupSetting using in MVC view.
  • ClassBreakMarkerStyle WindowsLinuxMac
    This class represents a style based on class break values.
  • ClientCache WindowsLinuxMac
    This class controls how the map images are cached by the browser.
  • ClusterMarkerStyle WindowsLinuxMac
    A kind of MarkerStyle to filter the markers.
  • ContextMenu WindowsLinuxMac
    This class represents a right-click shortcut menu used in the map control.
  • ContextMenuItem WindowsLinuxMac
    This class represents a menu item of the ContextMenu control.
  • CustomPopup WindowsLinuxMac
    Represents a pop up window whose style and background can be customized.
  • AdornmentOverlaySetting WindowsLinuxMac
    A setting for AdornmentOverlay that contains APIs to set properties of AdornmentOverlaySetting using in MVC view.
  • ArcGISServerRestOverlaySetting WindowsLinuxMac
    A setting for ArcGISServerRestOverlay that contains APIs to set properties of ArcGISServerRestOverlaySetting using in MVC view.
  • BingMapsOverlaySetting WindowsLinuxMac
    A setting for BingMapsOverlay that contains APIs to set properties of BingMapsOverlaySetting using in MVC view.
  • FeatureSourceMarkerOverlaySetting WindowsLinuxMac
    A setting for FeatureSourceMarkerOverlay that contains APIs to set properties of FeatureSourceMarkerOverlaySetting using in MVC view.
  • InMemoryMarkerOverlaySetting WindowsLinuxMac
    A setting for InMemoryMarkerOverlay that contains APIs to set properties of InMemoryMarkerOverlaySetting using in MVC view.
  • LayerOverlaySetting WindowsLinuxMac
    A setting for LayerOverlay that contains APIs to set properties of LayerOverlaySetting using in MVC view.
  • MarkerOverlaySetting`2 WindowsLinuxMac
    A setting for MarkerOverlay that contains APIs to set properties of MarkerOverlaySetting using in MVC view.
  • SimpleMarkerOverlaySetting WindowsLinuxMac
    A setting for SimpleMarkerOverlay that contains APIs to set properties of SimpleMarkerOverlaySetting using in MVC view.
  • EditFeatureOverlaySetting WindowsLinuxMac
    A setting for EditFeatureOverlay that contains APIs to set properties of EditFeatureOverlaySetting using in MVC view.
  • FeatureOverlaySetting`2 WindowsLinuxMac
    A setting for FeatureOverlay that contains APIs to set properties of FeatureOverlaySetting using in MVC view.
  • GoogleOverlaySetting WindowsLinuxMac
    A setting for GoogleOverlay that contains APIs to set properties of GoogleOverlaySetting using in MVC view.
  • HighlightFeatureOverlaySetting WindowsLinuxMac
    A setting for HighlightFeatureOverlay that contains APIs to set properties of HighlightFeatureOverlaySetting using in MVC view.
  • OpenStreetMapOverlaySetting WindowsLinuxMac
    A setting for OpenStreetMapOverlay that contains APIs to set properties of OpenStreetMapOverlaySetting using in MVC view.
  • OverlaySetting`2 WindowsLinuxMac
    A setting for Overlay that contains APIs to set properties of OverlaySetting using in MVC view.
  • WmsOverlaySetting WindowsLinuxMac
  • WorldMapKitWmsWebOverlaySetting WindowsLinuxMac
  • FeatureSourceMarkerOverlay WindowsLinuxMac
    Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
  • GoogleMapType WindowsLinuxMac
    This enumeration specifies the map types available from Google Maps.
  • GoogleOverlay WindowsLinuxMac
    Represents an overlay object that gets images from the Google Maps server.
  • HighlightFeatureOverlay WindowsLinuxMac
    Represents a FeatureOverlay that can easily apply a highlight style or hook event to the features in it.
  • InMemoryMarkerOverlay WindowsLinuxMac
    Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
  • LayerOverlay WindowsLinuxMac
    Represents an Overlay that contains layers.
  • Marker WindowsLinuxMac
    Represents a small icon on the map that is used for marking a point.
  • MarkerClassBreak WindowsLinuxMac
    Represents a break with a value and style defined.
  • MarkerDragMode WindowsLinuxMac
    This enumeration specifies how the map markers can be dragged.
  • MarkerOverlay WindowsLinuxMac
    Serves as the base class for the overlay that generates and manages markers.
  • MarkerStyle WindowsLinuxMac
    This class is the base class for all classes that define the styles applied to the markers.
  • MarkerValueItem WindowsLinuxMac
    This class represents one value in a ValueMarkerStyle.
  • MarkerZoomLevel WindowsLinuxMac
    Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
  • MarkerZoomLevelSet WindowsLinuxMac
    This class represents a collection of MarkerZoomLevels that determines the appearance of markers at different zoomlevels.
  • PointMarkerStyle WindowsLinuxMac
    Represents the ordinary marker style.
  • Popup WindowsLinuxMac
    Serves as the base class that defines the methods and properties common to all types of popups.
  • ServerCache WindowsLinuxMac
    This class controls the cachablity of the map control at the server side.
  • SimpleMarkerOverlay WindowsLinuxMac
    Represents a MarkerOverlay object to which you can add markers directly.
  • ValueMarkerStyle WindowsLinuxMac
    This class allows you to match a value with data in the feature to determine how to draw the feature.
  • WebImage WindowsLinuxMac
    Represents a small image that displays on the map.
  • WebImageFormat WindowsLinuxMac
  • GeoKeyedCollection`1 WindowsLinuxMac
    Represents a strong-typed collection that can be accessed by index or by the identifier of an item.
  • IRequireId WindowsLinuxMac
    This interface defines an Id property that is used by the GeoKeyedCollection.
  • JsonMemberAttribute WindowsLinuxMac
    Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
  • MapBuilder WindowsLinuxMac
    Defines the fluent interface for configuring the Map control.
  • Map WindowsLinuxMac
    This class represents the map control.
  • MvcClientScriptManager WindowsLinuxMac
    This Class defines the utility for managing, registering or adding the client script libraries and script files of Mvc application to the page.
  • MvcClientStyleSheetManager WindowsLinuxMac
    This Class defines the utility for managing, registering or adding the Css files to the page which included the specified control.
  • MvcControlBuilderBase`2 WindowsLinuxMac
    This class provides a abstract base class to defines the fluent interface for configuring the Mvc control.
  • MvcControlBase WindowsLinuxMac
    This class defines the base abstract class for creating MVC control.
  • MapTool WindowsLinuxMac
    Defines the properties and methods that are shared by all controls on the map.
  • AnimationPanMapTool WindowsLinuxMac
    Represents an animation pan tool which allows map pans to the position which users click using the transition effect.
  • KeyboardMapTool WindowsLinuxMac
    Determines whether the map can be operated by keyboard.
  • LoadingImageMapTool WindowsLinuxMac
    Represents a small image that displays at the center of the map when the map is loading.
  • LogoMapTool WindowsLinuxMac
    Represents a company logo or other logo-type image that displays in the lower right corner of the map.
  • MapTools WindowsLinuxMac
    Contains the different map tools as properties and acts as an entrance for setting these map controls.
  • MeasureMapTool WindowsLinuxMac
    Represents the measure map tool which allows measurements for features.
  • MeasureType WindowsLinuxMac
    Defines the different types of the MeasureMapTool.
  • MeasureUnitType WindowsLinuxMac
    The display system units for output measurements. Supported values are ‘english’, ‘metric’, and ‘geographic’. Default is ‘metric’.
  • MiniMapMapTool WindowsLinuxMac
    Represents a mini map panel in the lower right corner of the map.
  • MouseCoordinateMapTool WindowsLinuxMac
    Represents the coordinates of the mouse pointer, displayed in the lower right corner of the map.
  • MouseCoordinateType WindowsLinuxMac
    This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
  • MouseMapTool WindowsLinuxMac
    Determines whether the map can be operated by mouse.
  • OverlaySwitcherMapTool WindowsLinuxMac
    Represents a panel in the upper right corner of the map, containing a list of overlays in the map.
  • PanZoomBarMapTool WindowsLinuxMac
    Represents the panning and zooming panel in the upper left corner of the map.
  • PanZoomMapTool WindowsLinuxMac
    Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
  • ScaleLineMapTool WindowsLinuxMac
    Represents a graphic line marked with numbers indicating the map's current scale.
  • TrackZoomMaskType WindowsLinuxMac
    Defines the different zoom box key code of key for the MouseMapTool.
  • EditSettings WindowsLinuxMac
    Provides editing options when the EditOverlay is in EditShape mode.
  • FeatureOverlayStyle WindowsLinuxMac
    Specifies how the features in a FeatureOverlay are drawn at the client side.
  • TrackMode WindowsLinuxMac
    Defines the different modes of the EditFeatureOverlay.
  • TransitionEffect WindowsLinuxMac
    This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
  • WrapDatelineMode WindowsLinuxMac
    Indicates whether the overlay wraps at the date line.
  • ArcGISServerRestOverlay WindowsLinuxMac
    This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html ;specifically, the URL provided to this layer should be an export service URL: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/export.html
  • BingMapsOverlay WindowsLinuxMac
    Represents an overlay object that gets images from Microsoft's Virtual Earth server.
  • BingMapsStyle WindowsLinuxMac
    This enumeration specifies the map types available from Bing maps.
  • Overlay WindowsLinuxMac
  • EditFeatureOverlay WindowsLinuxMac
    Represents a FeatureOverlay whose features can be added or edited at the client side.
  • FeatureOverlay WindowsLinuxMac
    Serves as the base class for the overlays that contain features and paint the features at client side.
  • OpenStreetMapOverlay WindowsLinuxMac
    This class is used to display data from OpenStreetMap server.
  • WmsOverlay WindowsLinuxMac
    Represents an overlay object that gets map images from the WMS server you specify.
  • WorldMapKitWmsWebOverlay WindowsLinuxMac
  • MvcControlCollection WindowsLinuxMac
    Represents the Mvc control's factory.
  • GoogleMapsMapType WindowsLinuxMac
  • GoogleMapsPictureFormat WindowsLinuxMac
    This enumeration specifies the picture formats when getting images back to client from Google Maps.
  • WorldMapKitProjection WindowsLinuxMac
    This enumeration represents which projection will use for world map kit.
  • WorldStreetsAndImageryProjection WindowsLinuxMac
ThinkGeo.MapSuite.Cogo
ThinkGeo.MapSuite.Drawing
  • DrawingFontStyles WindowsLinuxAndroidiOSMac
    This enumeration specifies the type of font style for drawing text.
  • DrawingGraphicsUnit WindowsLinuxAndroidiOSMac
    This enumeration represents the graphics unit.
  • DrawingLevel WindowsLinuxAndroidiOSMac
    This enumeration represents the drawing level used in the GeoCanvas.
  • DrawingLineCap WindowsLinuxAndroidiOSMac
  • DrawingLineJoin WindowsLinuxAndroidiOSMac
    This enumeration specifies how to join consecutive line or curve segments.
  • DrawingPenAlignment WindowsLinuxAndroidiOSMac
  • DrawingQuality WindowsLinuxAndroidiOSMac
    This enumeration specifies the drawing quality of the GeoCanvas.
  • GeoBrush WindowsLinuxAndroidiOSMac
  • GeoBrushes WindowsLinuxAndroidiOSMac
    Provides a collection of predefined GeoBrushes
  • GeoCanvas WindowsLinuxAndroidiOSMac
  • GeoColor WindowsLinuxAndroidiOSMac
  • GeoColors WindowsLinuxAndroidiOSMac
    This class is a collection of predefined colors
  • GeoDashCap WindowsLinuxAndroidiOSMac
  • GeoFont WindowsLinuxAndroidiOSMac
    This class represents a font that is used to label features on a GeoCanvas.
  • GeographicColors WindowsLinuxAndroidiOSMac
    This class is a convenient way to access a predefined set of geographic colors.
  • GeoHatchBrush WindowsLinuxAndroidiOSMac
    This class represents a brush that fills with various patterns.
  • GeoHatchStyle WindowsLinuxAndroidiOSMac
  • GeoLinearGradientBrush WindowsLinuxAndroidiOSMac
  • GeoLinearGradientDirection WindowsLinuxAndroidiOSMac
    Specifies the direction of a linear gradient.
  • GeoPen WindowsLinuxAndroidiOSMac
    This class represents a GeoPen, which is used to draw lines on a GeoCanvas.
  • GeoPens WindowsLinuxAndroidiOSMac
    Provides a collection of predefined GeoPens
  • GeoSolidBrush WindowsLinuxAndroidiOSMac
  • GeoTextureBrush WindowsLinuxAndroidiOSMac
  • GeoWrapMode WindowsLinuxAndroidiOSMac
  • LineDashStyle WindowsLinuxAndroidiOSMac
    This enumeration specifies the style of dashed lines drawn with a GeoPen object.
  • PenBrushDrawingOrder WindowsLinuxAndroidiOSMac
    This enumeration determines whether the brush or the pen draws first.
  • PlatformGeoCanvas WindowsLinuxAndroidiOSMac
    This class represents a canvas that is used to draw geographic shapes with GDI+.
  • RandomColorType WindowsLinuxAndroidiOSMac
    Defines values represent which kind of color will use for randomly.
  • SimpleColors WindowsLinuxAndroidiOSMac
    This class is a convenient way to access a predefined set of simple colors.
  • StandardColors WindowsLinuxAndroidiOSMac
    This class is a convenient way to access a predefined set of standard colors.
ThinkGeo.MapSuite.Jeffersonian
ThinkGeo.MapSuite.Layers
ThinkGeo.MapSuite.Portable
ThinkGeo.MapSuite.Serialize
ThinkGeo.MapSuite.Shapes
  • AreaBaseShape WindowsLinuxAndroidiOSMac
  • AreaUnit WindowsLinuxAndroidiOSMac
    Units describing various ways you can measure areas.
  • BaseShape WindowsLinuxAndroidiOSMac
    The abstract class from which area shapes, line shapes, and point shapes inherit from.
  • BufferCapType WindowsLinuxAndroidiOSMac
  • Conversion WindowsLinuxAndroidiOSMac
    This static class provides a conversion method to go to and from different units.
  • DecimalDegreesHelper WindowsLinuxAndroidiOSMac
  • DegreesMinutesSeconds WindowsLinuxAndroidiOSMac
    This structure represents a degrees, minutes and seconds value.
  • DistanceUnit WindowsLinuxAndroidiOSMac
    Units describing various ways you can measure lengths.
  • DrawingRectangle WindowsLinuxAndroidiOSMac
    This structure represents the drawing of a rectangle in screen coordinates.
  • DrawingRectangleF WindowsLinuxAndroidiOSMac
  • EllipseShape WindowsLinuxAndroidiOSMac
  • ExtentHelper WindowsLinuxAndroidiOSMac
    This static class exposes a number of helpful methods when dealing with extents.
  • Feature WindowsLinuxAndroidiOSMac
  • LineBaseShape WindowsLinuxAndroidiOSMac
  • LineShape WindowsLinuxAndroidiOSMac
  • MapResizeMode WindowsLinuxAndroidiOSMac
    The enumeration represents which mode will use for map resize.
  • MultilineShape WindowsLinuxAndroidiOSMac
  • MultipointShape WindowsLinuxAndroidiOSMac
    This class represents one or more point shapes.
  • MultipolygonShape WindowsLinuxAndroidiOSMac
  • PanDirection WindowsLinuxAndroidiOSMac
    This enumeration defines panning directions.
  • PointBaseShape WindowsLinuxAndroidiOSMac
  • PointShape WindowsLinuxAndroidiOSMac
  • PolygonShape WindowsLinuxAndroidiOSMac
  • Proj4Projection WindowsLinuxAndroidiOSMac
  • Projection WindowsLinuxAndroidiOSMac
  • RectangleShape WindowsLinuxAndroidiOSMac
  • ReturningColumnsType WindowsLinuxAndroidiOSMac
    This enumeration provides some options when querying a feature.
  • RingShape WindowsLinuxAndroidiOSMac
    This class represents a closed ring of points.
  • ScreenPoint WindowsLinuxAndroidiOSMac
  • ScreenPointF WindowsLinuxAndroidiOSMac
  • ShapeValidationMode WindowsLinuxAndroidiOSMac
    This enumeration describes the type of validation test to run on shapes.
  • ShapeValidationResult WindowsLinuxAndroidiOSMac
  • SimplificationType WindowsLinuxAndroidiOSMac
    Specifies which algorthm will be use to simplify.
  • StartingPoint WindowsLinuxAndroidiOSMac
    An enumeration describing the place to start on a line when doing certain operations.
  • Vertex WindowsLinuxAndroidiOSMac
  • WellKnownType WindowsLinuxAndroidiOSMac
    This describes a set of enumerations that list the valid types of geometries.
  • WkbByteOrder WindowsLinuxAndroidiOSMac
    This enumeration represents the byte order that well-known binary will be written in.
ThinkGeo.MapSuite.Styles
map_suite_web_for_mvc_api.1483506098.txt.gz · Last modified: 2017/01/04 05:01 by marklee
