map_suite_web_for_mvc_api
ThinkGeo.MapSuite.Mvc
  • CursorType
    WindowsLinuxMac
    This enumeration determines the cursor that appears when the pointer moves over the map.
  • TileType
    WindowsLinuxMac
    This enumeration specifies whether the overlay uses tiling.
  • IJsonSerialization
    WindowsLinuxMac
    Define an interface to allow class that implement Json conversion.
  • IEntity
    WindowsLinuxMac
    The corresponding to achieve the entity object and url string between the conversion.
  • ClassBreakMarkerStyleSetting
    WindowsLinuxMac
    A setting for ClassBreakMarkerStyle that contains APIs to set properties of ClassBreakMarkerStyleSetting using in MVC view.
  • ClusterMarkerStyleSetting
    WindowsLinuxMac
    A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view.
  • FeatureOverlayStyleSetting
    WindowsLinuxMac
    A setting for FeatureOverlayStyle that contains APIs to set properties of FeatureOverlayStyleSetting using in MVC view.
  • MarkerStyleSetting`2
    WindowsLinuxMac
    A setting for MarkerStyle that contains APIs to set properties of MarkerStyleSetting using in MVC view.
  • PointMarkerStyleSetting
    WindowsLinuxMac
    A setting for PointMarkerStyle that contains APIs to set properties of PointMarkerStyleSetting using in MVC view.
  • ValueMarkerStyleSetting
    WindowsLinuxMac
    A setting for ValueMarkerStyle that contains APIs to set properties of ValueMarkerStyleSetting using in MVC view.
  • HtmlHelperExtension
    WindowsLinuxMac
    HtmlHelper extension for providing access to the Mvc controls inherited from MvcControlBase
  • WmtsOverlaySetting
    WindowsLinuxMac
    A setting for WmsOverlay that contains APIs to set properties of WmsOverlaySetting using in MVC view.
  • WorldStreetsAndImageryOverlaySetting
    WindowsLinuxMac
    A setting for WorldMapKitWmsWebOverlay that contains APIs to set properties of WorldMapKitWmsWebOverlaySetting using in MVC view.
  • MarkerBreakValueInclusion
    WindowsLinuxMac
    In a class break style, this enumeration determines whether the break includes or excludes the value entered in the break.
  • WmtsSeverEncodingType
    WindowsLinuxMac
    WMTS System.
    WindowsLinuxMac
    Represents an overlay object that gets map images from the WMS servers.
  • MapHelper
    WindowsLinuxMac
    This static class exposes a number of helpful methods when dealing with map.
  • MultiThreadTileResource
    WindowsLinuxMac
    This is an asynchronous HTTP handler which is used to handle web map services.
  • SingleThreadTileResource
    WindowsLinuxMac
  • MvcElementSettingBase`2
    WindowsLinuxMac
    This class is the abstract base-class for defining the fluent interface of classes which are not inherited from MvcControlBase, but used in a Mvc control.
  • ResourceDeploymentMode
    WindowsLinuxMac
    This class indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “True”, otherwise, you need to copy images to the directory.
  • WebConfigRegistrationMode
    WindowsLinuxMac
    This class is used to indicate whether the application allows map to register the Web.config on the fly in runtime.
  • ContextMenuItemCollection
    WindowsLinuxMac
    A collection of ThinkGeo.MapSuite.Mvc.ContextMenuItem objects.
  • ContextMenuItemSetting
    WindowsLinuxMac
    A setting for ContextMenuItem that contains APIs to set properties of ContextMenuItem using in MVC view.
  • ContextMenuSetting
    WindowsLinuxMac
    A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view.
  • AnimationPanMapToolSetting
    WindowsLinuxMac
  • KeyboardMapToolSetting
    WindowsLinuxMac
    A setting for KeyboardMapTool that contains APIs to set properties of KeyboardMapTool using in MVC view.
  • LoadingImageMapToolSetting
    WindowsLinuxMac
    A setting for LoadingImageMapTool that contains APIs to set properties of LoadingImageMapToolSetting using in MVC view.
  • LogoMapToolSetting
    WindowsLinuxMac
  • MapToolSetting`2
    WindowsLinuxMac
    A setting for MapTool that contains APIs to set properties of MapToolSetting using in MVC view.
  • MeasureMapToolSetting
    WindowsLinuxMac
    A setting for MeasureMapTool that contains APIs to set properties of MeasureMapToolSetting using in MVC view.
  • MiniMapMapToolSetting
    WindowsLinuxMac
    A setting for MiniMapMapTool that contains APIs to set properties of MiniMapMapToolSetting using in MVC view.
  • MouseCoordinateMapToolSetting
    WindowsLinuxMac
    A setting for MouseCoordinateMapTool that contains APIs to set properties of MouseCoordinateMapToolSetting using in MVC view.
  • MouseMapToolSetting
    WindowsLinuxMac
    A setting for MouseMapTool that contains APIs to set properties of MouseMapToolSetting using in MVC view.
  • OverlaySwitcherMapToolSetting
    WindowsLinuxMac
    A setting for OverlaySwitcherMapTool that contains APIs to set properties of OverlaySwitcherMapToolSetting using in MVC view.
  • PanZoomBarMapToolSetting
    WindowsLinuxMac
    A setting for PanZoomBarMapTool that contains APIs to set properties of PanZoomBarMapToolSetting using in MVC view.
  • PanZoomMapToolSetting
    WindowsLinuxMac
    A setting for PanZoomMapTool that contains APIs to set properties of PanZoomMapToolSetting using in MVC view.
  • ScaleLineMapToolSetting
    WindowsLinuxMac
    A setting for ScaleLineMapTool that contains APIs to set properties of ScaleLineMapToolSetting using in MVC view.
  • TouchMapToolSetting
    WindowsLinuxMac
    A setting for TouchMapTool that contains APIs to set properties of TouchMapToolSetting using in MVC view.
  • AdornmentOverlay
    WindowsLinuxMac
    This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
  • CloudPopup
    WindowsLinuxMac
    Represents the popups that appear in a cloud (a.k.a. balloon) shape.
  • CloudPopupSetting
    WindowsLinuxMac
    A setting for CloudPopup that contains APIs to set properties of CloudPopupSetting using in MVC view.
  • CustomPopupSetting
    WindowsLinuxMac
    A setting for CustomPopup that contains APIs to set properties of CustomPopupSetting using in MVC view.
  • PopupSetting`2
    WindowsLinuxMac
    A setting for Popup that contains APIs to set properties of PopupSetting using in MVC view.
    WindowsLinuxMac
    This class represents a style based on class break values.
  • ClientCache
    WindowsLinuxMac
    This class controls how the map images are cached by the browser.
    WindowsLinuxMac
    A kind of MarkerStyle to filter the markers.
  • ContextMenu
    WindowsLinuxMac
    This class represents a right-click shortcut menu used in the map control.
  • ContextMenuItem
    WindowsLinuxMac
    This class represents a menu item of the ContextMenu control.
  • CustomPopup
    WindowsLinuxMac
    Represents a pop up window whose style and background can be customized.
  • AdornmentOverlaySetting
    WindowsLinuxMac
    A setting for AdornmentOverlay that contains APIs to set properties of AdornmentOverlaySetting using in MVC view.
  • ArcGISServerRestOverlaySetting
    WindowsLinuxMac
    A setting for ArcGISServerRestOverlay that contains APIs to set properties of ArcGISServerRestOverlaySetting using in MVC view.
  • BingMapsOverlaySetting
    WindowsLinuxMac
    A setting for BingMapsOverlay that contains APIs to set properties of BingMapsOverlaySetting using in MVC view.
  • FeatureSourceMarkerOverlaySetting
    WindowsLinuxMac
    A setting for FeatureSourceMarkerOverlay that contains APIs to set properties of FeatureSourceMarkerOverlaySetting using in MVC view.
  • InMemoryMarkerOverlaySetting
    WindowsLinuxMac
    A setting for InMemoryMarkerOverlay that contains APIs to set properties of InMemoryMarkerOverlaySetting using in MVC view.
  • LayerOverlaySetting
    WindowsLinuxMac
    A setting for LayerOverlay that contains APIs to set properties of LayerOverlaySetting using in MVC view.
  • MarkerOverlaySetting`2
    WindowsLinuxMac
    A setting for MarkerOverlay that contains APIs to set properties of MarkerOverlaySetting using in MVC view.
  • SimpleMarkerOverlaySetting
    WindowsLinuxMac
    A setting for SimpleMarkerOverlay that contains APIs to set properties of SimpleMarkerOverlaySetting using in MVC view.
  • EditFeatureOverlaySetting
    WindowsLinuxMac
    A setting for EditFeatureOverlay that contains APIs to set properties of EditFeatureOverlaySetting using in MVC view.
  • FeatureOverlaySetting`2
    WindowsLinuxMac
    A setting for FeatureOverlay that contains APIs to set properties of FeatureOverlaySetting using in MVC view.
  • GoogleOverlaySetting
    WindowsLinuxMac
    A setting for GoogleOverlay that contains APIs to set properties of GoogleOverlaySetting using in MVC view.
  • HighlightFeatureOverlaySetting
    WindowsLinuxMac
    A setting for HighlightFeatureOverlay that contains APIs to set properties of HighlightFeatureOverlaySetting using in MVC view.
  • OpenStreetMapOverlaySetting
    WindowsLinuxMac
    A setting for OpenStreetMapOverlay that contains APIs to set properties of OpenStreetMapOverlaySetting using in MVC view.
  • OverlaySetting`2
    WindowsLinuxMac
    A setting for Overlay that contains APIs to set properties of OverlaySetting using in MVC view.
  • WmsOverlaySetting
    WindowsLinuxMac
  • WorldMapKitWmsWebOverlaySetting
    WindowsLinuxMac
    WindowsLinuxMac
    Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
  • GoogleMapType
    WindowsLinuxMac
    This enumeration specifies the map types available from Google Maps.
  • GoogleOverlay
    WindowsLinuxMac
    Represents an overlay object that gets images from the Google Maps server.
    WindowsLinuxMac
    Represents a FeatureOverlay that can easily apply a highlight style or hook event to the features in it.
    WindowsLinuxMac
    Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
  • LayerOverlay
    WindowsLinuxMac
    Represents an Overlay that contains layers.
  • Marker
    WindowsLinuxMac
    Represents a small icon on the map that is used for marking a point.
  • MarkerClassBreak
    WindowsLinuxMac
    Represents a break with a value and style defined.
  • MarkerDragMode
    WindowsLinuxMac
    This enumeration specifies how the map markers can be dragged.
  • MarkerOverlay
    WindowsLinuxMac
    Serves as the base class for the overlay that generates and manages markers.
  • MarkerStyle
    WindowsLinuxMac
    This class is the base class for all classes that define the styles applied to the markers.
  • MarkerValueItem
    WindowsLinuxMac
    This class represents one value in a ValueMarkerStyle.
  • MarkerZoomLevel
    WindowsLinuxMac
    Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
  • MarkerZoomLevelSet
    WindowsLinuxMac
    This class represents a collection of MarkerZoomLevels that determines the appearance of markers at different zoomlevels.
  • PointMarkerStyle
    WindowsLinuxMac
    Represents the ordinary marker style.
  • Popup
    WindowsLinuxMac
    Serves as the base class that defines the methods and properties common to all types of popups.
  • ServerCache
    WindowsLinuxMac
    This class controls the cachablity of the map control at the server side.
    WindowsLinuxMac
    Represents a MarkerOverlay object to which you can add markers directly.
  • ValueMarkerStyle
    WindowsLinuxMac
    This class allows you to match a value with data in the feature to determine how to draw the feature.
  • WebImage
    WindowsLinuxMac
    Represents a small image that displays on the map.
  • WebImageFormat
    WindowsLinuxMac
  • GeoKeyedCollection`1
    WindowsLinuxMac
    Represents a strong-typed collection that can be accessed by index or by the identifier of an item.
  • IRequireId
    WindowsLinuxMac
    This interface defines an Id property that is used by the GeoKeyedCollection.
  • JsonMemberAttribute
    WindowsLinuxMac
    Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
  • MapBuilder
    WindowsLinuxMac
    Defines the fluent interface for configuring the Map control.
  • Map
    WindowsLinuxMac
    This class represents the map control.
  • MvcClientScriptManager
    WindowsLinuxMac
    This Class defines the utility for managing, registering or adding the client script libraries and script files of Mvc application to the page.
  • MvcClientStyleSheetManager
    WindowsLinuxMac
    This Class defines the utility for managing, registering or adding the Css files to the page which included the specified control.
  • MvcControlBuilderBase`2
    WindowsLinuxMac
    This class provides a abstract base class to defines the fluent interface for configuring the Mvc control.
  • MvcControlBase
    WindowsLinuxMac
    This class defines the base abstract class for creating MVC control.
  • MapTool
    WindowsLinuxMac
    Defines the properties and methods that are shared by all controls on the map.
    WindowsLinuxMac
    Represents an animation pan tool which allows map pans to the position which users click using the transition effect.
  • KeyboardMapTool
    WindowsLinuxMac
    Determines whether the map can be operated by keyboard.
    WindowsLinuxMac
    Represents a small image that displays at the center of the map when the map is loading.
  • LogoMapTool
    WindowsLinuxMac
    Represents a company logo or other logo-type image that displays in the lower right corner of the map.
  • MapTools
    WindowsLinuxMac
    Contains the different map tools as properties and acts as an entrance for setting these map controls.
  • MeasureMapTool
    WindowsLinuxMac
    Represents the measure map tool which allows measurements for features.
  • MeasureType
    WindowsLinuxMac
    Defines the different types of the MeasureMapTool.
  • MeasureUnitType
    WindowsLinuxMac
    The display system units for output measurements. Supported values are ‘english’, ‘metric’, and ‘geographic’. Default is ‘metric’.
  • MiniMapMapTool
    WindowsLinuxMac
    Represents a mini map panel in the lower right corner of the map.
    WindowsLinuxMac
    Represents the coordinates of the mouse pointer, displayed in the lower right corner of the map.
  • MouseCoordinateType
    WindowsLinuxMac
    This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
  • MouseMapTool
    WindowsLinuxMac
    Determines whether the map can be operated by mouse.
    WindowsLinuxMac
    Represents a panel in the upper right corner of the map, containing a list of overlays in the map.
  • PanZoomBarMapTool
    WindowsLinuxMac
    Represents the panning and zooming panel in the upper left corner of the map.
  • PanZoomMapTool
    WindowsLinuxMac
    Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
  • ScaleLineMapTool
    WindowsLinuxMac
    Represents a graphic line marked with numbers indicating the map's current scale.
  • TrackZoomMaskType
    WindowsLinuxMac
    Defines the different zoom box key code of key for the MouseMapTool.
  • EditSettings
    WindowsLinuxMac
    Provides editing options when the EditOverlay is in EditShape mode.
    WindowsLinuxMac
    Specifies how the features in a FeatureOverlay are drawn at the client side.
  • TrackMode
    WindowsLinuxMac
    Defines the different modes of the EditFeatureOverlay.
  • TransitionEffect
    WindowsLinuxMac
    This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
  • WrapDatelineMode
    WindowsLinuxMac
    Indicates whether the overlay wraps at the date line.
    WindowsLinuxMac
    This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html ;specifically, the URL provided to this layer should be an export service URL: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/export.html
  • BingMapsOverlay
    WindowsLinuxMac
    Represents an overlay object that gets images from Microsoft's Virtual Earth server.
  • BingMapsStyle
    WindowsLinuxMac
    This enumeration specifies the map types available from Bing maps.
  • Overlay
    WindowsLinuxMac
    WindowsLinuxMac
    Represents a FeatureOverlay whose features can be added or edited at the client side.
  • FeatureOverlay
    WindowsLinuxMac
    Serves as the base class for the overlays that contain features and paint the features at client side.
    WindowsLinuxMac
    This class is used to display data from OpenStreetMap server.
  • WmsOverlay
    WindowsLinuxMac
    Represents an overlay object that gets map images from the WMS server you specify.
    WindowsLinuxMac
  • MvcControlCollection
    WindowsLinuxMac
    Represents the Mvc control's factory.
  • GoogleMapsMapType
    WindowsLinuxMac
  • GoogleMapsPictureFormat
    WindowsLinuxMac
    This enumeration specifies the picture formats when getting images back to client from Google Maps.
  • WorldMapKitProjection
    WindowsLinuxMac
    This enumeration represents which projection will use for world map kit.
  • WorldStreetsAndImageryProjection
    WindowsLinuxMac
map_suite_web_for_mvc_api.1483067622.txt.gz · Last modified: 2016/12/30 03:13 by marklee
