map_suite_web_for_mvc_api
ThinkGeo.MapSuite.Mvc
  • CursorType
    Windows
    This enumeration determines the cursor that appears when the pointer moves over the map.
  • TileType
    Windows
    This enumeration specifies whether the overlay uses tiling.
  • IJsonSerialization
    Windows
    Define an interface to allow class that implement Json conversion.
  • IEntity
    Windows
    The corresponding to achieve the entity object and url string between the conversion.
  • ClassBreakMarkerStyleSetting
    Windows
    A setting for ClassBreakMarkerStyle that contains APIs to set properties of ClassBreakMarkerStyleSetting using in MVC view.
  • ClusterMarkerStyleSetting
    Windows
    A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view.
  • FeatureOverlayStyleSetting
    Windows
    A setting for FeatureOverlayStyle that contains APIs to set properties of FeatureOverlayStyleSetting using in MVC view.
  • MarkerStyleSetting`2
    Windows
    A setting for MarkerStyle that contains APIs to set properties of MarkerStyleSetting using in MVC view.
  • PointMarkerStyleSetting
    Windows
    A setting for PointMarkerStyle that contains APIs to set properties of PointMarkerStyleSetting using in MVC view.
  • ValueMarkerStyleSetting
    Windows
    A setting for ValueMarkerStyle that contains APIs to set properties of ValueMarkerStyleSetting using in MVC view.
  • HtmlHelperExtension
    Windows
    HtmlHelper extension for providing access to the Mvc controls inherited from MvcControlBase
  • WmtsOverlaySetting
    Windows
    A setting for WmsOverlay that contains APIs to set properties of WmsOverlaySetting using in MVC view.
  • WorldStreetsAndImageryOverlaySetting
    Windows
    A setting for WorldMapKitWmsWebOverlay that contains APIs to set properties of WorldMapKitWmsWebOverlaySetting using in MVC view.
  • MarkerBreakValueInclusion
    Windows
    In a class break style, this enumeration determines whether the break includes or excludes the value entered in the break.
  • WmtsSeverEncodingType
    Windows
    WMTS System.
    Windows
    Represents an overlay object that gets map images from the WMS servers.
  • MapHelper
    Windows
    This static class exposes a number of helpful methods when dealing with map.
  • MultiThreadTileResource
    Windows
    This is an asynchronous HTTP handler which is used to handle web map services.
  • SingleThreadTileResource
    Windows
  • MvcElementSettingBase`2
    Windows
    This class is the abstract base-class for defining the fluent interface of classes which are not inherited from MvcControlBase, but used in a Mvc control.
  • ResourceDeploymentMode
    Windows
    This class indicates whether the application allows map to copy its resource images under “~/theme/default/img/”. The default value is “True”, otherwise, you need to copy images to the directory.
  • WebConfigRegistrationMode
    Windows
    This class is used to indicate whether the application allows map to register the Web.config on the fly in runtime.
  • ContextMenuItemCollection
    Windows
    A collection of ThinkGeo.MapSuite.Mvc.ContextMenuItem objects.
  • ContextMenuItemSetting
    Windows
    A setting for ContextMenuItem that contains APIs to set properties of ContextMenuItem using in MVC view.
  • ContextMenuSetting
    Windows
    A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view.
  • AnimationPanMapToolSetting
    Windows
  • KeyboardMapToolSetting
    Windows
    A setting for KeyboardMapTool that contains APIs to set properties of KeyboardMapTool using in MVC view.
  • LoadingImageMapToolSetting
    Windows
    A setting for LoadingImageMapTool that contains APIs to set properties of LoadingImageMapToolSetting using in MVC view.
  • LogoMapToolSetting
    Windows
  • MapToolSetting`2
    Windows
    A setting for MapTool that contains APIs to set properties of MapToolSetting using in MVC view.
  • MeasureMapToolSetting
    Windows
    A setting for MeasureMapTool that contains APIs to set properties of MeasureMapToolSetting using in MVC view.
  • MiniMapMapToolSetting
    Windows
    A setting for MiniMapMapTool that contains APIs to set properties of MiniMapMapToolSetting using in MVC view.
  • MouseCoordinateMapToolSetting
    Windows
    A setting for MouseCoordinateMapTool that contains APIs to set properties of MouseCoordinateMapToolSetting using in MVC view.
  • MouseMapToolSetting
    Windows
    A setting for MouseMapTool that contains APIs to set properties of MouseMapToolSetting using in MVC view.
  • OverlaySwitcherMapToolSetting
    Windows
    A setting for OverlaySwitcherMapTool that contains APIs to set properties of OverlaySwitcherMapToolSetting using in MVC view.
  • PanZoomBarMapToolSetting
    Windows
    A setting for PanZoomBarMapTool that contains APIs to set properties of PanZoomBarMapToolSetting using in MVC view.
  • PanZoomMapToolSetting
    Windows
    A setting for PanZoomMapTool that contains APIs to set properties of PanZoomMapToolSetting using in MVC view.
  • ScaleLineMapToolSetting
    Windows
    A setting for ScaleLineMapTool that contains APIs to set properties of ScaleLineMapToolSetting using in MVC view.
  • TouchMapToolSetting
    Windows
    A setting for TouchMapTool that contains APIs to set properties of TouchMapToolSetting using in MVC view.
  • AdornmentOverlay
    Windows
    This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
  • CloudPopup
    Windows
    Represents the popups that appear in a cloud (a.k.a. balloon) shape.
  • CloudPopupSetting
    Windows
    A setting for CloudPopup that contains APIs to set properties of CloudPopupSetting using in MVC view.
  • CustomPopupSetting
    Windows
    A setting for CustomPopup that contains APIs to set properties of CustomPopupSetting using in MVC view.
  • PopupSetting`2
    Windows
    A setting for Popup that contains APIs to set properties of PopupSetting using in MVC view.
    Windows
    This class represents a style based on class break values.
  • ClientCache
    Windows
    This class controls how the map images are cached by the browser.
    Windows
    A kind of MarkerStyle to filter the markers.
  • ContextMenu
    Windows
    This class represents a right-click shortcut menu used in the map control.
  • ContextMenuItem
    Windows
    This class represents a menu item of the ContextMenu control.
  • CustomPopup
    Windows
    Represents a pop up window whose style and background can be customized.
  • AdornmentOverlaySetting
    Windows
    A setting for AdornmentOverlay that contains APIs to set properties of AdornmentOverlaySetting using in MVC view.
  • ArcGISServerRestOverlaySetting
    Windows
    A setting for ArcGISServerRestOverlay that contains APIs to set properties of ArcGISServerRestOverlaySetting using in MVC view.
  • BingMapsOverlaySetting
    Windows
    A setting for BingMapsOverlay that contains APIs to set properties of BingMapsOverlaySetting using in MVC view.
  • FeatureSourceMarkerOverlaySetting
    Windows
    A setting for FeatureSourceMarkerOverlay that contains APIs to set properties of FeatureSourceMarkerOverlaySetting using in MVC view.
  • InMemoryMarkerOverlaySetting
    Windows
    A setting for InMemoryMarkerOverlay that contains APIs to set properties of InMemoryMarkerOverlaySetting using in MVC view.
  • LayerOverlaySetting
    Windows
    A setting for LayerOverlay that contains APIs to set properties of LayerOverlaySetting using in MVC view.
  • MarkerOverlaySetting`2
    Windows
    A setting for MarkerOverlay that contains APIs to set properties of MarkerOverlaySetting using in MVC view.
  • SimpleMarkerOverlaySetting
    Windows
    A setting for SimpleMarkerOverlay that contains APIs to set properties of SimpleMarkerOverlaySetting using in MVC view.
  • EditFeatureOverlaySetting
    Windows
    A setting for EditFeatureOverlay that contains APIs to set properties of EditFeatureOverlaySetting using in MVC view.
  • FeatureOverlaySetting`2
    Windows
    A setting for FeatureOverlay that contains APIs to set properties of FeatureOverlaySetting using in MVC view.
  • GoogleOverlaySetting
    Windows
    A setting for GoogleOverlay that contains APIs to set properties of GoogleOverlaySetting using in MVC view.
  • HighlightFeatureOverlaySetting
    Windows
    A setting for HighlightFeatureOverlay that contains APIs to set properties of HighlightFeatureOverlaySetting using in MVC view.
  • OpenStreetMapOverlaySetting
    Windows
    A setting for OpenStreetMapOverlay that contains APIs to set properties of OpenStreetMapOverlaySetting using in MVC view.
  • OverlaySetting`2
    Windows
    A setting for Overlay that contains APIs to set properties of OverlaySetting using in MVC view.
  • WmsOverlaySetting
    Windows
  • WorldMapKitWmsWebOverlaySetting
    Windows
    Windows
    Represents a MarkerOverlay that dynamically creates markers from the feature source specified.
  • GoogleMapType
    Windows
    This enumeration specifies the map types available from Google Maps.
  • GoogleOverlay
    Windows
    Represents an overlay object that gets images from the Google Maps server.
    Windows
    Represents a FeatureOverlay that can easily apply a highlight style or hook event to the features in it.
    Windows
    Represents a MarkerOverlay object that dynamically creates markers from the InMemory features.
  • LayerOverlay
    Windows
    Represents an Overlay that contains layers.
  • Marker
    Windows
    Represents a small icon on the map that is used for marking a point.
  • MarkerClassBreak
    Windows
    Represents a break with a value and style defined.
  • MarkerDragMode
    Windows
    This enumeration specifies how the map markers can be dragged.
  • MarkerOverlay
    Windows
    Serves as the base class for the overlay that generates and manages markers.
  • MarkerStyle
    Windows
    This class is the base class for all classes that define the styles applied to the markers.
  • MarkerValueItem
    Windows
    This class represents one value in a ValueMarkerStyle.
  • MarkerZoomLevel
    Windows
    Defines styles of markers and a zoomlevel range. When the current zoomlevel is in that range, the styles will be applied to the markers.
  • MarkerZoomLevelSet
    Windows
    This class represents a collection of MarkerZoomLevels that determines the appearance of markers at different zoomlevels.
  • PointMarkerStyle
    Windows
    Represents the ordinary marker style.
  • Popup
    Windows
    Serves as the base class that defines the methods and properties common to all types of popups.
  • ServerCache
    Windows
    This class controls the cachablity of the map control at the server side.
    Windows
    Represents a MarkerOverlay object to which you can add markers directly.
  • ValueMarkerStyle
    Windows
    This class allows you to match a value with data in the feature to determine how to draw the feature.
  • WebImage
    Windows
    Represents a small image that displays on the map.
  • WebImageFormat
    Windows
  • GeoKeyedCollection`1
    Windows
    Represents a strong-typed collection that can be accessed by index or by the identifier of an item.
  • IRequireId
    Windows
    This interface defines an Id property that is used by the GeoKeyedCollection.
  • JsonMemberAttribute
    Windows
    Indicates that a class can be serialized to a JSON string. This class cannot be inherited.
  • MapBuilder
    Windows
    Defines the fluent interface for configuring the Map control.
  • Map
    Windows
    This class represents the map control.
  • MvcClientScriptManager
    Windows
    This Class defines the utility for managing, registering or adding the client script libraries and script files of Mvc application to the page.
  • MvcClientStyleSheetManager
    Windows
    This Class defines the utility for managing, registering or adding the Css files to the page which included the specified control.
  • MvcControlBuilderBase`2
    Windows
    This class provides a abstract base class to defines the fluent interface for configuring the Mvc control.
  • MvcControlBase
    Windows
    This class defines the base abstract class for creating MVC control.
  • MapTool
    Windows
    Defines the properties and methods that are shared by all controls on the map.
    Windows
    Represents an animation pan tool which allows map pans to the position which users click using the transition effect.
  • KeyboardMapTool
    Windows
    Determines whether the map can be operated by keyboard.
    Windows
    Represents a small image that displays at the center of the map when the map is loading.
  • LogoMapTool
    Windows
    Represents a company logo or other logo-type image that displays in the lower right corner of the map.
  • MapTools
    Windows
    Contains the different map tools as properties and acts as an entrance for setting these map controls.
  • MeasureMapTool
    Windows
    Represents the measure map tool which allows measurements for features.
  • MeasureType
    Windows
    Defines the different types of the MeasureMapTool.
  • MeasureUnitType
    Windows
    The display system units for output measurements. Supported values are ‘english’, ‘metric’, and ‘geographic’. Default is ‘metric’.
  • MiniMapMapTool
    Windows
    Represents a mini map panel in the lower right corner of the map.
    Windows
    Represents the coordinates of the mouse pointer, displayed in the lower right corner of the map.
  • MouseCoordinateType
    Windows
    This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
  • MouseMapTool
    Windows
    Determines whether the map can be operated by mouse.
    Windows
    Represents a panel in the upper right corner of the map, containing a list of overlays in the map.
  • PanZoomBarMapTool
    Windows
    Represents the panning and zooming panel in the upper left corner of the map.
  • PanZoomMapTool
    Windows
    Represents the panning and zooming panel in the upper left corner of the map, by which you can operate the map.
  • ScaleLineMapTool
    Windows
    Represents a graphic line marked with numbers indicating the map's current scale.
  • TrackZoomMaskType
    Windows
    Defines the different zoom box key code of key for the MouseMapTool.
  • EditSettings
    Windows
    Provides editing options when the EditOverlay is in EditShape mode.
    Windows
    Specifies how the features in a FeatureOverlay are drawn at the client side.
  • TrackMode
    Windows
    Defines the different modes of the EditFeatureOverlay.
  • TransitionEffect
    Windows
    This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
  • WrapDatelineMode
    Windows
    Indicates whether the overlay wraps at the date line.
    Windows
    This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html ;specifically, the URL provided to this layer should be an export service URL: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/export.html
  • BingMapsOverlay
    Windows
    Represents an overlay object that gets images from Microsoft's Virtual Earth server.
  • BingMapsStyle
    Windows
    This enumeration specifies the map types available from Bing maps.
  • Overlay
    Windows
    Windows
    Represents a FeatureOverlay whose features can be added or edited at the client side.
  • FeatureOverlay
    Windows
    Serves as the base class for the overlays that contain features and paint the features at client side.
    Windows
    This class is used to display data from OpenStreetMap server.
  • WmsOverlay
    Windows
    Represents an overlay object that gets map images from the WMS server you specify.
    Windows
  • MvcControlCollection
    Windows
    Represents the Mvc control's factory.
  • GoogleMapsMapType
    Windows
  • GoogleMapsPictureFormat
    Windows
    This enumeration specifies the picture formats when getting images back to client from Google Maps.
  • WorldMapKitProjection
    Windows
    This enumeration represents which projection will use for world map kit.
  • WorldStreetsAndImageryProjection
    Windows
map_suite_web_for_mvc_api.1483003584.txt.gz · Last modified: 2016/12/29 09:26 by marklee
