Release date: 1/22/2009
A large number of API changes and improvements have been introduced in this version, including the following breaking changes:
Please see the attached Word document for a complete list of all breaking changes, and examples of how you should migrate your code to comply with the revised API.
| Assembly | Members Added | Members Removed | Breaking Changes | Percent Churn |
| webedition (1142) | 172 added | 0 removed | 89 breaking | 15.1% churn |
This topic discusses the changes made to Map Suite Web Edition between version 3.0.131 (beta 2) and the latest release, version 3.1.0 Final. The changes discussed in this article are those that might cause your older Web Edition applications to fail or behave differently.
Contents:
Description: In version 3.1.0, the Map.GetFullExtent method has been removed. If you really want to know the “full extent” of the map, you can call the LayerOverlay.GetBoundingBox method of each LayerOverlay of the map and merge them.
Description:
In version 3.1.0, the Map.Mode property has been removed. The Map.EditOverlay is responsible for anything related to shape editing. Please use the Map.EditOverlay.TrackMode instead. Note that Mode.Normal is replaced by the TrackMode.None, which means the editing mode is disabled.
In Version 3.0.131:
Map1.Mode = Mode.Normal; Map1.Mode = Mode.TrackPoint; Map1.Mode = Mode.TrackLine; Map1.Mode = Mode.TrackPolygon; Map1.Mode = Mode.TrackRectangle; Map1.Mode = Mode.TrackSquare; Map1.Mode = Mode.TrackCircle; Map1.Mode = Mode.TrackEllipse; Map1.Mode = Mode.EditShape;
In Version 3.1.0:
Map1.EditOverlay.TrackMode = TrackMode.None; Map1.EditOverlay.TrackMode = TrackMode.Point; Map1.EditOverlay.TrackMode = TrackMode.Line; Map1.EditOverlay.TrackMode = TrackMode.Polygon; Map1.EditOverlay.TrackMode = TrackMode.Rectangle; Map1.EditOverlay.TrackMode = TrackMode.Square; Map1.EditOverlay.TrackMode = TrackMode.Circle; Map1.EditOverlay.TrackMode = TrackMode.Ellipse; Map1.EditOverlay.TrackMode = TrackMode.Edit;
Description:
In version 3.1.0, the architecture of the editing system has changed. It is now the Map.EditOverlay that takes responsibility for shape editing. Map.EditOverlay has the Features collection, whose features are serialized to the client and drawn. It has the Style property that determines how those features are drawn. Its TrackMode property determines whether you can draw or edit shapes, and the EditSettings property allows you to control how to edit shapes.
In Version 3.0.131:
Map1.EditLayer.InternalFeatures.Add(feature.Id, feature);
In Version 3.1.0:
Map1.EditOverlay.Features.Add(feature.Id, feature); Map1.EditOverlay.Style.FillColor = GeoColor.StandardColors.LightGreen; Map1.EditOverlay.TrackMode = TrackMode.Edit; Map1.EditOverlay.EditSettings.IsRotatable = false; Map1.EditOverlay.EditSettings.IsDraggable = false; Map1.EditOverlay.EditSettings.IsResizable = false; Map1.EditOverlay.EditSettings.IsReshapable = true;
Description:
In version 3.1.0, the HighlightOverlay class has changed to the HighlightFeatureOverlay class, which is derived from FeatureOverlay. The Map.HighlightOverlay is a real overlay object now. It has some property changes – for example, the HoverStyle is now changed to HighlightStyle.
In Version 3.0.131:
Map1.HighlightOverlay.Style = new FeatureOverlayStyle(); Map1.HighlightOverlay.HoverStyle = new HighlightOverlayStyle(GeoColor.FromArgb(120, GeoColor.StandardColors.OrangeRed), GeoColor.StandardColors.DarkGreen, 1);
In Version 3.1.0:
Map1.HighlightOverlay.Style = new FeatureOverlayStyle(); Map1.HighlightOverlay.HighlightStyle.FillColor = GeoColor.FromArgb(120, GeoColor.StandardColors.OrangeRed); Map1.HighlightOverlay.HighlightStyle.OutlineColor = GeoColor.StandardColors.DarkGreen; Map1.HighlightOverlay.HighlightStyle.OutlineWidth = 1;
Description:
In version 3.1.0, the HighlightOverlayClickEventArgs class has been renamed to HighlightFeatureOverlayClickEventArgs.
In Version 3.0.131:
Map1.HighlightOverlay.Click += new EventHandler<HighlightOverlayClickEventArgs>(HighlightOverlay_Click);
In Version 3.1.0:
Map1.HighlightOverlay.Click += new EventHandler<HighlightFeatureOverlayClickEventArgs>(HighlightOverlay_Click);
Description:
In version 3.1.0, the HighlightOverlayStyle has been renamed to FeatureOverlayStyle, which determines how the features are drawn at the client side. The FeatureOverlayStyle is used by both EditFeatureOverlay and HighlightFeatureOverlay classes.
In Version 3.0.131:
HighlightOverlayStyle style = new HighlightOverlayStyle(); HighlightOverlayStyle hoverStyle = new HighlightOverlayStyle();
In Version 3.1.0:
FeatureOverlayStyle style = new FeatureOverlayStyle(); FeatureOverlayStyle hoverStyle = new FeatureOverlayStyle();
Description: In version 3.1.0, the Map.ZoomPercentage has been removed. Now the Map.ZoomIn and Map.ZoomOut methods will zoom the map by one zoomlevel, instead of by percentage.
Description: In version 3.1.0, the FeatureMarkerOverlay has been renamed to the FeatureSourceMarkerOverlay, which makes more sense.
In Version 3.0.131:
FeatureMarkerOverlay markerOverlay = new FeatureMarkerOverlay("Markers"); markerOverlay.FeatureSource = new ShapeFileFeatureSource(MapPath("~/SampleData/USA/cities_a.shp"));
In Version 3.1.0:
FeatureSourceMarkerOverlay markerOverlay = new FeatureSourceMarkerOverlay("Markers"); markerOverlay.FeatureSource = new ShapeFileFeatureSource(MapPath("~/SampleData/USA/cities_a.shp"));
Description:
In version 3.1.0, the InMemoryMarkerOverlay.Features has been changed from Dictionary to GeoCollection. Now you can use foreach to loop through the features directly.
In Version 3.0.131:
foreach (string key in Map1.MarkerOverlay.Features.Keys) { Feature feature = Map1.MarkerOverlay.Features[[key]]; }
In Version 3.1.0:
foreach (Feature feature in Map1.MarkerOverlay.Features) { }
Description:
In version 3.1.0, the WmsOverlay.Projection property has been replaced by the WmsOverlay.GetBaseEpsgProjection and WmsOverlay.SetBaseEpsgProjection methods.
In Version 3.0.131:
WmsOverlay wms = new WmsOverlay("WMS Layer"); wms.Projection = "EPSG:900913";
In Version 3.1.0:
WmsOverlay wms = new WmsOverlay("WMS Layer"); wms.SetBaseEpsgProjection("EPSG:900913");
Description:
In version 3.1.0, the ScreenOffsetX and ScreenOffsetY properties on the CloudPopup and CustomPopup classes has been renamed to OffsetXInPixels and OffsetYInPixels.
In Version 3.0.131:
CloudPopup samplePopup = new CloudPopup("samplePopup", position, contentHtml.ToString(), 400, 290); samplePopup.ScreenOffsetX = 10; samplePopup.ScreenOffsetY = 10; Map1.Popups.Add(samplePopup);
In Version 3.1.0:
CloudPopup samplePopup = new CloudPopup("samplePopup", position, contentHtml.ToString(), 400, 290); samplePopup.OffsetXInPixels = 10; samplePopup.OffsetYInPixels = 10; Map1.Popups.Add(samplePopup);
Description:
In version 3.1.0, the ClickTarget property on the ContextMenuItemClickEventArgs class has been removed.
