View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
Applies To: Web \ Silverlight
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
View Source |
This project shows how to consume data from a WMTS Server using WmtsOverlay. You would find the code pretty straightforward, while behind the scenes we request tiles from the server asynchronously and efficiently, and stitch them into a proper map. <br> This class is introduced from version 6.0.187.0, besides this WmtsOverlay, we also have WmtsLayer available. Here is the WMTSLayer Sample.
Video Overview
Notes from the developer:
Rotating the map:
Displaying the North Arrow:
The purpose of this sample is to show you a quick and easy way to read data from a SQL data source and display it on the map using an InMemoryFeatureLayer
. Since geometric feature data can be stored in a number of different formats such as X and Y coordinates, WKT (Well Known Text), and Geometry data types, this sample shows you how to load, edit and save data to a SQL data source for each different type of format. The sample includes a SQL script you need to run first, in order to create and populate a SQL Server table with sample data. You will also need to change the connection information in the code on lines 71 and 204 so that it points to your SQL Server.
Note: The approach in this sample works best for small amounts of data (less than 10,000 features) since it loads all of the data into memory. For larger datasets, we recommend using the SQL2008FeatureLayer
or the ''OledbFeatureSource'', which only reads the data for the given extent you are working in (much more efficient for larger datasets).
On the web site
