map_suite_web_edition_layers_featuresources_samples
Map_Suite_Web_Edition_Layers_&_FeatureSources_Samples
Combining Overlays
Screenshot width=78Sample width=66Product Description
map_suite_web_edition_sample_combining_overlays.jpg View Source
C# Download
Need it in another language?
Wpf \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Wpf \\ In today’s Wpf project, we show a technique of using a common FeatureSource for two different Overlays. From a physical shapefile representing cities, a regular LayerOverlay is used for the higher zoom levels while a FeatureSourceMarkerOverlay is used for the lower zoom levels. FeatureSourceMarkerOverlay is a Wpf specific overlay offering features for a better user experience such a Tooltips and ImageSource.
Create GRID
map_suite_desktop_edition_sample_create_grid.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ Today’s sample shows the new feature available in this may release Map Suite 5 for creating GRID files. A GRID is a raster format that defines a geographic space as an array of equally sized squares (cells) arranged in rows and columns. Each cell stores a numeric value that represents an attribute (such as elevation, surface slope, soil pH etc.) for that unit of space. Each GRID cell is referenced by its x, y coordinate location. Typically a GRID file is created based on some sample points with known values. In today’s sample, we take the example of creating a GRID file based on a point based shapefile representing soil pH values of some sample locations in a field. Using the Inverse Weighted Distance algorithm for interpolation, we create the GRID with the pH value for the entire extent of the field. Look at the code and comments for more details on how GRID files get generated and displayed on the map. This sample is a Desktop application but GRID can be used in all the editions of Map Suite.
Edit Attribute Of Shapefile
map_suite_wpf_desktop_edition_sample_edit_attribute_of_shapefile.jpg View Source
C# Download
Wpf \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ The purpose of this Wpf sample is to show how to edit the attribute of a feature of a shapefile. This sample is useful for anyone wanting to actualize the attribute part of its data by simply clicking on the desired feature on the map and updating its attribute in a textbox. You will find the editing part of the code in the KeyDown event of the textbox.
Edit Geometry Of Shapefile
map_suite_desktop_edition_sample_edit_geometry_of_shapefile.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ The purpose of this sample is to show how to update the geometry of a feature of a shapefile in one step. This sample is useful for anyone wanting to actualize the geometry part of its data. You can see how only a few lines of code are necessary for this process and that the spatial index gets automatically updated after calling the committing the change. Notice that this sample does not show all the fanciness for manipulating at user interaction the geometry to be updated. For this purpose, you can see all the samples related to TrackInteractiveOverlay and EditInteractiveOverlay.
Get Data From Server With WCF
View Source
C# Download
Silverlight \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In this Silverlight-based project, we are going to take a look at how to get geometry data from the server side using the WCF service with Map Suite Silverlight Edition, while keeping all map data on the server side. You can click any of the countries on the map to call a WCF service, which will require data from the server, and then a popup will appear with information about that country.
Graphic Logo for Web
map_suite_web_edition_sample_graphic_logo_for_web.jpg View Source
C# Download
Web \\ \\ Applies To: Web \\ Silverlight \\ From a request in a Discussion Forum post, today we decided to have the Web version of a similar project Graphic “Logo Adornment Layer” for Desktop. Here we show how to use the class GraphicLogoAdornmentLayer inheriting AdornmentLayer for the Web edition.
Heat Map
map_suite_web_edition_sample_heat_map.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ Heat maps is a technique increasingly used in various fields such in biology and other fields. See http://en.wikipedia.org/wiki/Heat_map. They are also used for displaying areas of webs page most frequently scanned by users. http://csscreme.com/heat-maps/.
Heat Map with earthquakes
map_suite_web_edition_sample_heat_map_with_earthquakes.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ After the project on displaying swine flu data using the heat map technique, here you learn how to apply parameters other than strictly spatial distribution to affect the coloring of the map.
Image Stream Loading
map_suite_web_edition_sample_image_stream_loading.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ As an alternative to loading an Image with the image file from the file system, you can choose to pass your own stream. This project shows you how to use the event StreamLoading of GdiPlusRasterSource for this purpose. In this project, we show how to do this using a Tiff image but you can also use that event for ShapeFileFeatureSource as we show in a previous project “Shapefile Encryption”. Keep in mind that this technique only works with images besides MrSid, ECW and Jpeg2000. These types of images do not work because the providers do not support streams in their decoding SDKs.
KML Extension Web
map_suite_web_edition_sample_kml_extension_web.jpg View Source
C# Download
Web \\ \\ Applies To: Web \\ Silverlight \\ Upon requests from Map Suite Web developers, we created this project. It is the web version of the Desktop project “KML Extension” where we learned how to display on the map files in the KML format.
Latitude Longitude Graticule
map_suite_web_edition_sample_latitude_longitude_graticule.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ After the projects on North Arrow and Compass, we created another project related to Adornment Layer to have a more stylish map and give more information to the user navigating the map.
Native TAB File Suppport
tabfilesupport.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ One of the most exciting new features in MapSuite 5.0 is native TAB file support. In the past, the FDO extension was used for displaying TAB files in MapSuite. Now with the new TabFeatureLayer, we have a simpler and more stable method of working with TAB files.
Numbered Grid
map_suite_web_edition_sample_numbered_grid.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In many atlases, you can see maps with a numbered grid to give the page reference for a more detailed map. In today’s project, we show how to construct such a grid. Based on the extent of the feature, the number of columns and rows, a grid can be created with the page number in each cell.
no_screenshot.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In today’s project, we are looking at a way to encrypt shapefiles to prevent them from being used outside the application. We show how to encrypt and decrypt shapefiles using streams. You will see that a very simple encryption algorithm is used but by looking at the example, you will be able to implement your own.
WMTS Overlay
{|class=“wikitable” cellpadding=“3” !Screenshot !width=78|Sample !width=66|Product !Description |- | |View Source<br><br>C# Download<br><br>Need it in another language? |Web <br><br>Applies To: Desktop <br> Web <br> Silverlight <br> Services <br> Wpf <br> |This project shows how to consume data from a WMTS Server using WmtsOverlay. You would find the code pretty straightforward, while behind the scenes we request tiles from the server asynchronously and efficiently, and stitch them into a proper map. <br> This class is introduced from version 6.0.187.0, besides this WmtsOverlay, we also have WmtsLayer available. Here is the WMTSLayer Sample. |}
map_suite_services_edition_layers_featuresources_samples
map_suite_web_edition_layers_featuresources_samples.1440040124.txt.gz · Last modified: 2015/09/08 10:46 (external edit)
