map_suite_web_edition_faq_labeling
Map Suite Web Edition FAQ Labeling
How can I display decimal degrees as degrees, minutes and seconds?
How do I control how labels are displayed based on fields in the data?
Sample:Labeling Based On Columns
How do I adjust the size of the labels based on feature column data?
Sample:Labeling based on size
How do I use multiple columns in one label?
Sample:Multi Column Labeling
How do I display multi labels for a given feature?
Sample:Multiple Labels
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “[ColumnName1][ColumnName2]” and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
For more information you can see the discussion forum post below: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6955/afv/topic/Default.aspx
How do I drag the labels to place them at the desired location?
Sample:Draggable Labels
How do I display multi line labeling?
Sample:MultiLine Labeling
map_suite_web_edition_faq_labeling.txt · Last modified: 2015/09/09 05:53 by admin
