map_suite_web_edition_faq_interactiveoverlays
Map Suite Web Edition FAQ InteractiveOverlays
How do I override the default behavior of the TrackInteractiveOverlay?
Sample:Custom Track Line
Sample:Custom Track Polygon
How do I prevent a vertex from being dragged within the tolerance of another vertex while editing?
Sample:Vertex Tolerance
How do I save tracked shapes to WKT (Well Known Text)?
Sample:Tracked Shapes to WKT
How do I snap vertices while editing?
Sample:Dragged Point Style
How do I display dynamic information as track shapes are being drawn?
Sample:Dynamic Info On TrackShapes
In this example, you will see displayed in a groupbox, properties such as perimeter and area as the shape is being tracked. In this project, you will learn how to handle events such as TrackStarted, MouseMoved and TrackEnded of TrackOverlay for that purpose. Getting dynamic info of a shape being tracked can be handy in situation where before committing to get the completed shape, you want to know more about the shape. For example, if you are tracking a search zone, you get dynamically info about its area. This project will be followed by other related projects. One will show how to create one’s own inherited TrackOverlay for having the possibility to abort tracking by pressing a key. Another project will show how to display dynamic info inside the shape itself instead of using a separate control.
Sample:EditOverlay Styles
How do I select features from a layer based on a user drawn track shape?
Sample:Select with Track Shape
map_suite_web_edition_faq_interactiveoverlays.txt · Last modified: 2015/09/18 09:41 by admin
