map_suite_web_edition_all_samples
Table of Contents
Map Suite Web Edition All Samples
Map Suite Web Edition How Do I Samples
The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples. Available in both C# and VB.NET, these samples are designed to hit all the highlights of Map Suite, from simply adding a layer to a map to performing spatial queries and applying a thematic style. Consider this collection your “encyclopedia” of all the Map Suite basics and a great starting place for new users.
ArcGISServerRestOverlay
In this web-based project, we'll demonstrate the new ArcGISServerRestOverlay released with Map Suite 5.0 WebEdition. This overlay gives developers a simple and powerful tool to access their maps that reside on ArcGIS Server. This new overlay utilizes the ArcGIS Server REST API. You can also check out the sample video to see the ArcGISServerRestOverlay in action.
Custom Map with Google Labels
GPS to Google Map(Web)
Great Circle with Google Map
Mini map with Google Map
OpenStreetMap
Shapefile to Google Map
Street View and Traffic
In this web-based project, we demonstrate using Google's Street View and Traffic overlays. This functionality is new to the WebEdition and is available with any daily build version 5.5.134.0 or higher. Developers can choose to enable this new functionality on either the server side or with client-side javascript.
Custom Track Line
Custom Track Polygon
Dragged Point Style
Dynamic Info On TrackShapes
EditOverlay Styles
Select with Track Shape
Tracked Shapes to WKT
Vertex Tolerance
Draggable Labels
Labeling based on size
MultiLine Labeling
Multiple Labels
Decimal Degrees Formatting
LEAD Technologies Inc. V1.01
Label to Show Location
Labeling Based On Columns
Multi Column Labeling
Combining Overlays
Create GRID
Edit Attribute Of Shapefile
Edit Geometry Of Shapefile
Get Data From Server With WCF
Graphic Logo for Web
Heat Map
Heat Map with earthquakes
Image Stream Loading
KML Extension Web
Latitude Longitude Graticule
Native TAB File Suppport
Numbered Grid
WMTS Overlay
This project shows how to consume data from a WMTS Server using WmtsOverlay. You would find the code pretty straightforward, while behind the scenes we request tiles from the server asynchronously and efficiently, and stitch them into a proper map.
This class is introduced from version 6.0.187.0, besides this WmtsOverlay, we also have WmtsLayer available. Here is the WMTSLayer Sample.
ENC Viewer for displaying S-57 (*.000) File
GPS EXchange Format FeatureLayer
Maritime S57 FeatureLayer
Build Custom Shapefile Indexes
CAD FeatureLayer
TAB FeatureLayer With Embed Style
Compass
File Geodatabase
Video Overview
Hook Up External Data to Shapefile
Isolines
Isolines with Kriging
MapShapes
Notes from the developer:
Mini Map Adornment Layer
Multi Geo Raster Layer
Multi Index
North Arrow
Rotating the map:
Displaying the North Arrow:
Oledb Point FeatureSource
Oledb FeatureSource
Scale Bar
SQLInMemoryLayer
Styles with InMemoryFeatureLayer
Swine Flu
On the web site
Watermark Adornment Layer
WMTS Layer
Zedgraph
Context Menu with Sub Menu
Based on a discussion forum request, today's web project shows you how to add sub menus to ContextMenu. This is a built-in function in all of the most recent daily builds of Map Suite, which you can download from the ThinkGeo Customer Portal. This project also demonstrates how to enable the ContextMenu's auto wrap feature when you click on the edges of the map.
Custom Scale Bar
Draw Custom Exception
Interact with Map Points
In this web-based project, we show you how to do a two-way interaction between the features in an InMemoryFeatureLayer and their information in GridView. If you click on a point on the map, you will see the corresponding item highlighted in the GridView. Or vice-versa; you can click on an item in the GridView and you will see its feature highlighted on the map.
MDI Form
Topology Validation
Use Map with MVC Framework
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
<div sample_otherlinks> [
This WebEdition project shows you how to add robust printing support to your web application, using the code in this sample, you will be able to build a Print Preview Interface that lets your users interactively arrange items (such as a map, scale line, labels, data grid or image) on a virtual page before printing the result to a printer, exporting to a PDF or to a bitmap image. Maps are printed using vector graphics so you can be sure the output will look great on anything from a PDF to a large plotter. The printing system also includes low-level report building classes that make it easy to generate reports in the web environment.
Note: Users of this sample will not have access to the interactive drag-and-drop page layout interface here.
Large Scale Map Printing
served as a presentation of the different printing concepts such as page layout, the map element, legends, titles, data grids, logos and the user's interaction with them. Using all of the printing tools we introduced in the first sample, here we will demonstrate a real-world print scenario at a large scale with data for parcels at a county level. By reading the descriptive comments within the sample code itself, you will better understand how to handle your printing needs and follow cartographic standards for map presentation.
screenshot
Custom Parameters Projection
Custom Rotation Projection
Google Map to Geodetic
Graticule with Projection
Local Datum UTM
Projection by Analyzing Prj File
Projection Distance LineStyle
Wrap Dateline Mode With Projection
Datum Transformation
Geodetic to State Plane
Geodetic to UTM on the fly
GeoRaster Projection
Measurements Decimal Degrees
Pacific Rim
Polygon across Meridian
Projection Distortion
Projection in Feet
Routing with Projections
Save To Projection
Street Intersection
World Coordinates
Clipping On Line Layer
Create Inner Ring
FeatureIdsToExclude
Get Feature Clicked On(Web)
Get Feature Clicked On(Web)2
Intersect Line
Polygon Shapes To Multipolygon Shapes
Shortest Line Between Two Features with Split
Sweep Angle Desktop
Clipping
Convex Hull
Correcting Nodes
Create Polygon Programatically
Dissolve on Shapefile
Draw a Pie shape
Dynamic Segmentation
Get Feature Clicked On With Projection
Identify Point with Icon
Inner Ring Containment
Intersecting Multi Polygon
Intersecting Two Layers
Merge Line Layers
Merge Point Layers
Merging Layers
Multi Ring Buffering
LEAD Technologies Inc. V1.01
Negative Buffering
Offset Point at Right Angle
Register Shape
Remove LineShape
Spatial Join
Split Polygon
Split Polygon Based On Grid
From the Performance Guide:
Split Polygon Dynamically into Grids based on the Area
Sweep Angle
Splitting Polygons with a Line
Default ValueStyle
Distance Line Style
EditOverlay Styles
Line Style With Increment
Multiple Dot Density Styles
MultiLine Labeling
Side View Icon
Smooth Transparent Route
Weather Line Style
Adjusted Scaling Image Style
Cached Value Style
ClusterPointStyle
Decimal Degrees Formatting
Displaying One-Way Streets
Doughnut Point Style
Feature Centric Style
Flashing Point Style
Hybrid TextStyle
Image Style
Isolines
Rotate Icon
Routing Styles
Scaling Image Style
Scaling TextStyle
Scaling TextStyle for Polygon
Sized Point Style
Start End LineStyle
TextStyle for Multi Line
Time Based Point Style
Time Line
ValueStyle with Countries
WordWrapped TextStyle
World Sized Image Style
World Sized Text Style
Label Point with Circle Symbol and Mask Description
Centering And Rotating WPF
Centering Map with Tolerance
Callback for Fleet Tracker
Detect GPS
Detect GPS location
Moving Features with Ajax
Moving Vehicle with Label
Traveling Salesman Problem
Vehicle Direction
Chemical Plume
Filter Radar Image
Rotated Image Style
Snap GPS to Street
Center Map Based On Lat/Long
Customize ZoomLevels
This web-based project demonstrates how to customize the ZoomLevels of your Map Suite Web Edition map. There are 20 default ZoomLevels, but sometimes they don’t fit your requirements. In that case, you can specify your own scale which corresponds to a certain ZoomLevel. It’s easy to do and requires just a few lines of code.
GetZoomLevel
Map Scales
Raster Layer with extent
Restricting Extent
Zoom In To Feature
Zoom In To Point
Zoom Levels Partitioning
Zoom to Full extent
Custom Zoom Levels
Zoom to Full extent
Map Suite License File Generator
map_suite_web_edition_all_samples.1443425399.txt.gz · Last modified: 2015/09/28 07:29 by admin
