map_suite_vehicle_tracking_starter_kit
Map_Suite_Vehicle_Tracking_Starter_Kit
The Map Suite Vehicle Tracking Starter Kit has been discontinued as a product. Please refer to the Vehicle Tracking Project Template in your ThinkGeo Product Center.
article_rating If you're looking to put together a Web-based vehicle tracking application with Map Suite Web Edition, the Vehicle Tracking Starter Kit is a great place to begin. Designed to be easy to use and filled with common tracking features, the kit demonstrates best practices through fully-commented source code in C# and VB.NET. Kick-start your tracking project now!
Product Guides
Guides Description
Quick Start Guide This guide helps you get you up to speed with integrating the Vehicle Tracking Starter Kit samples into your GIS software.
Installation Guide This guide walks you through installing the starter kit on your system.
Deployment Guide This guide walks you through deploying your GIS software using the starter kit into a production environment.
Frequently Asked Questions
Category Description
General Questions These frequently asked questions cover GIS and Map Suite Vehicle Tracking Starter Kit topics that are not categorized in other areas.
Videos & Screenshots
Topic Attachment Description
Screenshot Gallery N/A The Map Suite Vehicle Tracking Starter Kit screenshots gallery section showcases a wide range of screenshots covering various GIS features of the Map Suite Vehicle Tracking Starter Kit.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_vehicle_tracking_starter_kit.1442565700.txt.gz · Last modified: 2015/09/18 08:41 by admin
