The page was created before Map Suite 10. Map Suite 10.0 organized many classes into new namespaces and assemblies as well as had a few minor breaks in compatibility. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code check out this(http://wiki.thinkgeo.com/wiki/map_suite_10_upgrade_guide).
The Map Suite Source Kit helps developers extend and enhance Map Suite's core features by providing C# source code behind several of its most popular classes. From FeatureSources to GeoStyles, the Source Kit lets you see the “guts” behind many of your favorite classes, making it easier to extend them for your own custom implementation.
This guide helps you get you up to speed with integrating the Map Suite Source Kit map control into your GIS software.
The Map Suite Source Kit screenshots gallery section showcases a wide range of screenshots covering the Map Suite Source Kit.
These frequently asked questions cover GIS and Map Suite Source Kit topics that are not categorized in other areas.
