map_suite_silverlight_edition_faq_spatial_functions
Table of Contents
Map Suite Silverlight Edition FAQ Spatial Functions
How do I clip one polygon layer based on a polygon?
Sample:Clipping
How do I clip one point layer based on a polygon?
Sample:Clipping On Point Layer
How do I create a convex hull around a feature?
Sample:Convex Hull
ConvexHull is a geometric function that returns the smallest ring containing all the points of a shape. Another way to think about it is to imagine a set of points on a plane as nails pounded into a board. If you wrap the entire set with a rubber band snapping it into place, it will form a convex hull, which is the minimum-energy wrapper that encloses all the points. This is the theory, now you may be wondering what the practical use of this is in GIS. In today’s project, we show how to contruct a convex hull polygon from a set of point in a concrete situation of oil rigs offshore. Creating a convex hull could be used to determine the perimeter for constructing a barrier around the oil rigs to help protect from hurricanes. It could also be used for a barrier to keep spilled oil contained within.
How do I snap line based nodes together based on a tolerance?
Sample:Correcting Nodes
As for the projects “Spatial Join” and “Dissolve”, in this project we see how to edit FeatureLayers. In this case, we show some techniques to clean up a line based layer. You may be in a situation where you have to do that on a layer representing a network. Due to a poor digitizing, the end nodes of the lines don’t touch each other showing disconnected when in fact they should be connected. In this project, we show the technique to correct the location of the end vertices (nodes) so that they connect to each other. Keep in mind that the logic for correcting nodes shown here, is very simple and does not take into account various parameters such as tolerance, line order, multi line intersection etc. This logic works in the case of having an ordered sequential network as it is often digitized. The full logic taking into account all the different scenarios is vastly more complicated. We plan to offer this full logic in the future as an API within our core product. Also, notice that we create a custom LineStyle, NodeLineStyle for the purpose of showing the start and end nodes of each line as different color than the body of the line.
How do I create inner rings for track polygon?
Sample:Create Inner Ring
How do I create a polygon programatically?
Sample:Create Polygon Programatically
How do I draw a pie shape with a sweep angle as in radar applications?
Sample:Sweep Angle
Sample:Sweep Angle Desktop
How do I dissolve a shape file based on a common attribute?
Sample:Dissolve on Shapefile
In this small project, you will see the technique to dissolve a shapefile based on a common attribute using some key methods such as Union static method to efficiently union together a large number of shapes. You will also find useful the code for creating a shapefile from scratch. This project will soon be followed by another project on how to apply statistics when dissolving a shapefile. Also, there will be another related project on how to do Dissolve on a generic FeatureSource.
Sample:Dissolve with Statistics
How do I split polygon based on an intersecting line?
Sample:Split Polygon
How do I perform spatial join?
Sample:Spatial Join
This project shows how to perform a Spatial Join on a point Layer based on a Polygon layer. It adds the relevant info to the point layer based on the spatial characteristics of the features of the point layer in comparison to the polygon layer. For example, we have two layers. One is polygon layer of the countries; the other is point layer of the cities. We don’t have any attribute information about what country each city belongs to. We can perform a Spatial Join to add that info to the point layer. A Spatial Join looks at what country of the polygon layer, each city belongs to using a spatial query. Spatial Join requires handling various techniques such as creating, updating layer and spatial queries in one coherent function. In this project, you will also see the technique of displaying a label based on more then one columns. In this example, we show a Spatial Join based on containing rule. Other types of Spatial Joins can be performed based on proximity, or some other topological rules. Later, we will show other projects of Spatial Joins.
How can I draw a pie shape defined by an ellipse?
Sample:Draw a Pie shape
For more information, please see the discussion forum post below: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6963/afv/topic/Default.aspx
How can I perform dynamic segmentation?
Sample:Dynamic Segmentation
The key method used here is GetLineOnLine that offers many parameters to get a segment of an existing line. In our example, we get a line segment based on a distance from the start and the length. You can see how this could be applied for application such closing a segment of a highway after an accident for example. This project will be followed by other more advanced projects related to Dynamic Segmentation.
How do I suppress features from being drawn in a layer?
Sample:FeatureIdsToExclude
How do I find a feature the user clicked on?
Sample:Get Feature Clicked On(Web)
Sample:Get Feature Clicked On(Web)2
How do I remove a LineShape from a MultiLineShape?
Sample:Remove LineShape
How do I register a shape to the ground from a non-geographic coordinate system?
Sample:Register Shape
In this sample, we show a geometric function that allows tying to the ground or registering shapes from some non geographic coordinate to the map (in world coordinates). To better understand how useful this can be for your mapping needs, imagine the following scenario: You have some geometric shapes in a CAD for chemical plume. In a CAD or specialized program generating chemical models, you can do all your scientific manipulation, transformation etc. Once you are finished generating the chemical models with your specialized program, you are ready to put it on the map. Using anchor points, one of origin and one of destination, you can tie to the ground the shapes with the help of the Register function. This operation cannot be confused with Projection. Projecting a shape means going from one geographic projection to another one, for example from Geodetic to Spherical Mercator and some deformation of the shape can occur. Registering is simply placing a shape from a non geographic coordinate to a specific location on the map.
How do I identify a feature when clicking anywhere on its icon?
Sample:Identify Point with Icon
How do I determine if a point is inside an inner ring of a polygon?
Sample:Inner Ring Containment
How do I split a line based on an intersecting line?
Sample:Intersect Line
How do I handle self-intersecting polygons?
Sample:Intersecting Multi Polygon
How do I intersecting two layers?
Sample:Intersecting Two Layers
Let say you have a layer of stratigraphy and a layer of counties and you need to do some analysis based on info from the county layer and info from the stratigraphy layer. You can combine the two layers by intersecting them and get only the common data of the two layers while adding the attributes of both original layers. The resulting layer has geographical extent that is common to both layers (as for clipping) while adding the information from both original layers. As for other geoprocessing techniques, writing the code for Intersecting requires combining layer editing with geometric functions.
How do I merge two line layers?
Sample:Merge Line Layers
From the previous project, on the geoprocessing technique of merging point layers, here we show the same technique applied to line layers. Remember that an alternative approach to merging is to use a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx
How do I merge two point layers?
Sample:Merge Point Layers
An alternative approach to merging is to use a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx Next we will show how to do the same thing for line layers.
How do I treat multiple shape files as one shape file without physically merging them?
Sample:Merging Layers
If you have many files of the same type and representing the same type of features, Map Suite offers an API for building a multi index and treating all the various files as one layer. You can see this Discussion Forum post for more info on that: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5921/afv/topic/Default.aspx
While this is very convenient, you may still want to combine all your files into one for maintenance purpose. This project shows the geoprocessing technique of accomplishing that task with merging. The logic for writing the merging algorithm is simpler than other geoprocessing tasks since no geometric functions are involved. Keep in mind that this project shows how to merge polygon based shapefiles into one. In the future, we will post a more generic project for layer of various format and type.
How do I move a point parallel to a line segment?
Sample:Offset Point at Right Angle
How do I buffer shapes based on multiple distances?
Sample:Multi Ring Buffering
How do I perform a negative buffer?
Sample:Negative Buffering
How to create a MultipolygonShape from various PolygonShapes?
Sample:Polygon Shapes To Multipolygon Shapes
How do I clip one line layer based on a polygon?
Sample:Clipping On Line Layer
map_suite_silverlight_edition_faq_spatial_functions.txt · Last modified: 2015/09/16 06:57 by admin
