The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples. Available in both C# and VB.NET, these samples are designed to hit all the highlights of Map Suite, from simply adding a layer to a map to performing spatial queries and applying a thematic style. Consider this collection your “encyclopedia” of all the Map Suite basics and a great starting place for new users.
You can also check out Part 1 and Part 2 of the video which provides a brief summary of this sample.
We have extended the reach of our Silverlight client to utilize the Out-Of-Browser (OOB) feature. This allows you to launch Silverlight applications either disconnected or connected without the browser as the container.
Important Points:
1. To run application in out-of-browser mode, you have to right-click the project and show the “Project Properties” window, then select “Enable running application out of the browser”. You must also click the button labeled “Out-of-Browser Settings…” and make sure the item “Require elevated trust when running outside the browser” is selected.
2. To make sure the ServerLayerOverlay works properly in out-of-browser mode, the property “ConnectorHost” URL of the ServerLayerOverlay must be set. This represents the URL of the page that is hosting the SilverlightMapConnector.
served as a presentation of the different printing concepts such as page layout, the map element, legends, titles, data grids, logos and the user's interaction with them. Using all of the printing tools we introduced in the first sample, here we will demonstrate a real-world print scenario at a large scale with data for parcels at a county level. By reading the descriptive comments within the sample code itself, you will better understand how to handle your printing needs and follow cartographic standards for map presentation.
From the Performance Guide:
