map_suite_silverlight_edition_all_samples
Table of Contents
Map Suite Silverlight Edition All Samples
Map Suite Silverlight Edition How Do I Samples
The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples. Available in both C# and VB.NET, these samples are designed to hit all the highlights of Map Suite, from simply adding a layer to a map to performing spatial queries and applying a thematic style. Consider this collection your “encyclopedia” of all the Map Suite basics and a great starting place for new users.
GPS to Google Map(Web)
Great Circle with Google Map
Mini map with Google Map
OpenStreetMap
Shapefile to Google Map
Custom Track Line
Custom Track Polygon
Dragged Point Style
Dynamic Info On TrackShapes
EditOverlay Styles
Select with Track Shape
Tracked Shapes to WKT
Vertex Tolerance
Labeling based on size
MultiLine Labeling
Multiple Labels
Decimal Degrees Formatting
LEAD Technologies Inc. V1.01
Label to Show Location
Labeling Based On Columns
Multi Column Labeling
Best Practices - Silverlight Edition
You can also check out Part 1 and Part 2 of the video which provides a brief summary of this sample.
Out of Browser Support
We have extended the reach of our Silverlight client to utilize the Out-Of-Browser (OOB) feature. This allows you to launch Silverlight applications either disconnected or connected without the browser as the container.
Important Points:
1. To run application in out-of-browser mode, you have to right-click the project and show the “Project Properties” window, then select “Enable running application out of the browser”. You must also click the button labeled “Out-of-Browser Settings…” and make sure the item “Require elevated trust when running outside the browser” is selected.
2. To make sure the ServerLayerOverlay works properly in out-of-browser mode, the property “ConnectorHost” URL of the ServerLayerOverlay must be set. This represents the URL of the page that is hosting the SilverlightMapConnector.
Custom Scale Bar
Draw Custom Exception
MDI Form
Topology Validation
Use Map with MVC Framework
Use Progress Bar
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
<div sample_otherlinks> [
Large Scale Map Printing
served as a presentation of the different printing concepts such as page layout, the map element, legends, titles, data grids, logos and the user's interaction with them. Using all of the printing tools we introduced in the first sample, here we will demonstrate a real-world print scenario at a large scale with data for parcels at a county level. By reading the descriptive comments within the sample code itself, you will better understand how to handle your printing needs and follow cartographic standards for map presentation.
screenshot
Custom Parameters Projection
Custom Rotation Projection
Google Map to Geodetic
Graticule with Projection
Local Datum UTM
Projection by Analyzing Prj File
Projection Distance LineStyle
Wrap Dateline Mode With Projection
Datum Transformation
Geodetic to State Plane
Geodetic to UTM on the fly
GeoRaster Projection
Measurements Decimal Degrees
Pacific Rim
Polygon across Meridian
Projection Distortion
Projection in Feet
Routing with Projections
Save To Projection
Street Intersection
World Coordinates
Clipping On Line Layer
Create Inner Ring
FeatureIdsToExclude
Get Feature Clicked On(Web)
Get Feature Clicked On(Web)2
Intersect Line
Polygon Shapes To Multipolygon Shapes
Shortest Line Between Two Features with Split
Sweep Angle Desktop
Clipping
Convex Hull
Correcting Nodes
Create Polygon Programatically
Dissolve on Shapefile
Draw a Pie shape
Dynamic Segmentation
Get Feature Clicked On With Projection
Identify Point with Icon
Inner Ring Containment
Intersecting Multi Polygon
Intersecting Two Layers
Merge Line Layers
Merge Point Layers
Merging Layers
Multi Ring Buffering
Negative Buffering
Offset Point at Right Angle
Register Shape
Remove LineShape
Spatial Join
Split Polygon
Split Polygon Based On Grid
From the Performance Guide:
Split Polygon Dynamically into Grids based on the Area
Sweep Angle
Splitting Polygons with a Line
Default ValueStyle
Distance Line Style
EditOverlay Styles
Line Style With Increment
Multiple Dot Density Styles
MultiLine Labeling
Side View Icon
Smooth Transparent Route
Weather Line Style
Adjusted Scaling Image Style
Cached Value Style
ClusterPointStyle
Displaying One-Way Streets
Doughnut Point Style
Feature Centric Style
Flashing Point Style
Hybrid TextStyle
Image Style
Isolines
Rotate Icon
Routing Styles
Scaling Image Style
Scaling TextStyle
Scaling TextStyle for Polygon
Sized Point Style
Start End LineStyle
TextStyle for Multi Line
Time Based Point Style
Time Line
ValueStyle with Countries
WordWrapped TextStyle
World Sized Image Style
World Sized Text Style
Label Point with Circle Symbol and Mask Description
Callback for Fleet Tracker
Centering And Rotating WPF
Centering Map with Tolerance
Detect GPS
Detect GPS location
Moving Vehicle with Label
Traveling Salesman Problem
Vehicle Direction
Chemical Plume
Filter Radar Image
Rotated Image Style
Snap GPS to Street
Center Map Based On Lat/Long
GetZoomLevel
Map Scales
Raster Layer with extent
Restricting Extent
Zoom In To Feature
Zoom In To Point
Zoom Levels Partitioning
Zoom to Full extent
Custom Zoom Levels
Zoom to Full extent
Map Suite License File Generator
map_suite_silverlight_edition_all_samples.txt · Last modified: 2017/03/17 05:07 by tgwikiupdate
