Release date: 05/14/2012
New namespaces: 0
Types
Types added in new namespaces: 0
Types added to existing namespaces: 30
Total number of types added (in both new and existing namespaces): 30
Types removed from existing namespaces: 2
Members
Members added on new types: 163
Members added to existing types: 93
Members removed from existing types: 13
Members removed on removed types: 4
Attributes
Attributes added: 127
Attributes added and shown: 127
Attributes removed: 0
Attributes removed and shown: 0
Others
Parameter name changes: 0
MapSuiteCore, Version=6.0.0.0, Culture=neutral, PublicKeyToken=null
namespace ThinkGeo.MapSuite.Core {
[SerializableAttribute]
public class AddedGeoCollectionEventArgs : EventArgs {
public class AddingGeoCollectionEventArgs : EventArgs {
public enum AdornmentLocation {
public enum ApplyUntilZoomLevel {
public enum AreaUnit {
public class BingMapsLayer : Layer {
[ObsoleteAttribute("This constructor is obsolete, please use other constructors instead. This API is obsolete and may be removed in or after Version 7.0.")]
public BingMapsLayer(String applicationId, BingMapsMapType mapType, String cacheDirectory, BingMapsLogoMode logoMode);
[ObsoleteAttribute("This property is obsolete, please use other structors instead. This API is obsolete and may be removed in or after Version 7.0.")]
public BingMapsLogoMode LogoMode { get; set; }
public GeoImage Logo { get; set; }
[ObsoleteAttribute("This event is obsolete, please use SendingWebRequest instead. This API is obsolete and may be removed in or after Version 7.0.")]
public event EventHandler
[ObsoleteAttribute("This event is obsolete, please use SentWebRequest instead. This API is obsolete and may be removed in or after Version 7.0.")]
protected virtual void OnSendingWebRequest(SendingWebRequestEventArgs e);
protected virtual void OnSentWebRequest(SentWebRequestEventArgs e);
protected override void CloseCore();
[ObsoleteAttribute("This enum is obsolete. This API is obsolete and may be removed in or after Version 7.0.")]
public enum BingMapsLogoMode {
public enum BingMapsMapType {
public enum BingMapsPictureFormat {
public enum BreakValueInclusion {
public enum BufferCapType {
public enum BuildIndexMode {
public class BuildingIndexShapeFileFeatureSourceEventArgs : EventArgs {
public enum BuildRecordIdMode {
public class ClearedItemsGeoCollectionEventArgs : EventArgs {
public class ClearingItemsGeoCollectionEventArgs : EventArgs {
public class ClusterPointStyle : PointStyle {
public enum ColorWheelDirection {
public class CreatedMemberNodeGeoObjectModelerEventArgs : EventArgs {
public CreatedMemberNodeGeoObjectModelerEventArgs();
public CreatedMemberNodeGeoObjectModelerEventArgs(String name, Object value, Type type, Object owner, GeoObjectNode node);
public GeoObjectNode Node { get; set; }
public Object Owner { get; set; }
public Object Value { get; set; }
public String Name { get; set; }
public Type Type { get; set; }
public class CreatedMemberObjectGeoObjectModelerEventArgs : EventArgs {
public CreatedMemberObjectGeoObjectModelerEventArgs();
public CreatedMemberObjectGeoObjectModelerEventArgs(String name, Object value, Type type, Object owner);
public class CreatingMemberNodeGeoObjectModelerEventArgs : EventArgs {
public CreatingMemberNodeGeoObjectModelerEventArgs();
public CreatingMemberNodeGeoObjectModelerEventArgs(String name, Object value, Type type, Object owner);
public class CreatingMemberObjectGeoObjectModelerEventArgs : EventArgs {
public CreatingMemberObjectGeoObjectModelerEventArgs();
public CreatingMemberObjectGeoObjectModelerEventArgs(String name, Type type, Object owner, GeoObjectNode node);
public class CSharpGeoCodeFormatter : GeoCodeFormatter {
public CSharpGeoCodeFormatter();
protected override void SaveCore(GeoObjectModel model, Stream stream);
public enum DbfColumnType {
public enum DistanceUnit {
NauticalMile
public class DrawingExceptionLayerEventArgs : EventArgs {
public DrawingExceptionLayerEventArgs();
public DrawingExceptionLayerEventArgs(GeoCanvas canvas, Exception exception, Boolean cancel);
public Boolean Cancel { get; set; }
public Exception Exception { get; set; }
public GeoCanvas Canvas { get; set; }
[FlagsAttribute]
public enum DrawingFontStyles {
public enum DrawingGraphicsUnit {
public enum DrawingLevel {
public enum DrawingLineCap {
public enum DrawingLineJoin {
public enum DrawingPenAlignment {
public class DrawingProgressChangedEventArgs : ProgressChangedEventArgs {
public enum DrawingQuality {
public class DrawnExceptionLayerEventArgs : EventArgs {
public DrawnExceptionLayerEventArgs();
public DrawnExceptionLayerEventArgs(GeoCanvas canvas, Exception exception);
public enum ExecutingSqlStatementType {
GetFeaturesByColumnValue
public struct Feature {
public Byte[] WellKnownBinary { get; set; }
[ObsoleteAttribute("This method is obsolete, please use property WellKnownBinary instead. This API is obsolete and may be removed in or after version 7.0.")]
public Byte[] GetWellKnownBinary();
public abstract class FeatureSource {
protected virtual RectangleShape GetBoundingBoxByIdCore(String id);
public class FormattedPositionStyleEventArgs : EventArgs {
public FormattedPositionStyleEventArgs();
public FormattedPositionStyleEventArgs(String text, BaseShape shape);
public BaseShape Shape { get; set; }
public String Text { get; set; }
public class FormattingPositionStyleEventArgs : EventArgs {
public FormattingPositionStyleEventArgs();
public FormattingPositionStyleEventArgs(String text, BaseShape shape);
public abstract class GeoCodeFormatter {
protected GeoCodeFormatter();
public void Save(GeoObjectModel model, Stream stream);
protected abstract void SaveCore(GeoObjectModel model, Stream stream);
public class GeoCodeGenerator {
public GeoCodeGenerator();
public GeoCodeGenerator(GeoCodeFormatter formatter);
public GeoCodeFormatter Formatter { get; set; }
public String GenerateCode(Object sourceObject);
public void GenerateCode(Object sourceObject, String pathFileName);
public void GenerateCode(Object sourceObject, Stream stream);
public enum GeoDashCap {
public enum GeographyUnit {
public enum GeoHatchStyle {
public enum GeoLinearGradientDirection {
public class GeometryCollectionShape : BaseShape {
protected override Double GetDistanceToCore(BaseShape targetShape, GeographyUnit shapeUnit, DistanceUnit distanceUnit);
public class GeoObjectModel {
public GeoObjectModel();
public GeoObjectModel(String name, GeoObjectNode rootNode);
public GeoObjectNode RootNode { get; set; }
public class GeoObjectModeler {
public GeoObjectModeler();
public GeoObjectModel CreateModel(Object objectToModel, GeoObjectModelerMemberTypes memberTypes, BindingFlags bindingFlags, GeoObjectModelerDefaultValueMode defaultValueMode);
public Object CreateObject(GeoObjectModel model);
protected void CreateMemberNode(String memberName, Object memberValue, Type memberType, Object memberOwner, GeoObjectNode baseMemberNode);
protected virtual void CreateMemberNodeCore(String memberName, Object memberValue, Type memberType, Object memberOwner, GeoObjectNode baseMemberNode);
protected Object CreateMemberObject(String memberName, Type memberType, Object memberOwner, GeoObjectNode memberNode);
protected virtual Object CreateMemberObjectCore(String memberName, Type memberType, Object memberOwner, GeoObjectNode memberNode);
protected Collection
protected virtual Collection
protected virtual void OnCreatedMemberNode(CreatedMemberNodeGeoObjectModelerEventArgs e);
protected virtual void OnCreatedMemberObject(CreatedMemberObjectGeoObjectModelerEventArgs e);
protected virtual void OnCreatingMemberNode(CreatingMemberNodeGeoObjectModelerEventArgs e);
protected virtual void OnCreatingMemberObject(CreatingMemberObjectGeoObjectModelerEventArgs e);
public enum GeoObjectModelerDefaultValueMode {
IncludeDefaultValues,
ExcludeDefaultValues
[FlagsAttribute]
public enum GeoObjectModelerMemberTypes {
Fields,
Properties
public class GeoObjectNode {
public GeoObjectNode();
public GeoObjectNode(String name);
public Boolean IsDefaultValue { get; set; }
public Collection
public Dictionary
public GeoObjectNode Parent { get; set; }
public String Value { get; set; }
public override String ToString();
public abstract class GeoSerializationFormatter {
protected GeoSerializationFormatter();
public GeoObjectModel Load(Stream stream);
protected abstract GeoObjectModel LoadCore(Stream stream);
public class GeoSerializer {
public GeoSerializer();
public GeoSerializer(GeoSerializationFormatter formatter);
public GeoSerializationFormatter Formatter { get; set; }
public Object Deserialize(String sourceString);
public Object Deserialize(Uri sourceUri);
public Object Deserialize(Stream sourceStream);
public Object Deserialize(String sourcePathFileName, FileAccess fileAccess);
public String Serialize(Object objectToSerialize);
public void Serialize(Object objectToSerialize, Stream targetStream);
public void Serialize(Object objectToSerialize, String targetPathFileName);
public enum GeoTiffLibraryType {
public enum GeoWrapMode {
public class GoogleMapsLayer : Layer {
protected WebResponse SendWebRequest(WebRequest webRequest);
protected virtual WebResponse SendWebRequestCore(WebRequest webRequest);
public enum GoogleMapsMapType {
public enum GoogleMapsPictureFormat {
public enum GoogleMapsTileMode {
public class GoogleMapsZoomLevelSet : ZoomLevelSet {
public GoogleMapsZoomLevelSet();
[ObsoleteAttribute("This class is obsoleted, please use GoogleMapsZoomLevelSet instead. This API is obsolete and may be removed in or after Version 7.0.")]
public class GoogleMapZoomLevelSet : ZoomLevelSet {
public class GraticuleAdornmentLayer : AdornmentLayer {
protected override void OpenCore();
public class GridDefinition {
public class GridFeatureSource : FeatureSource {
public static GridCell[,] ReplaceNoDataValue(GridCell[,] gridMatrix, Double noDataValue);
public static GridCell[,] ReplaceNoDataValue(GridCell[,] gridMatrix, Double noDataValue, GridInterpolationModel gridInterpolationModel);
public class GridIsoLineLayer : IsoLineLayer {
protected virtual void OnStreamLoading(StreamLoadingEventArgs e);
public class InMemoryFeatureLayer : FeatureLayer {
public void Clear();
public class InMemoryFeatureSource : FeatureSource {
public class InsertedGeoCollectionEventArgs : EventArgs {
public class InsertingGeoCollectionEventArgs : EventArgs {
public abstract class IsoLineLayer : Layer {
public enum IsoLineType {
public enum LabelDuplicateRule {
public enum LabelOverlappingRule {
public abstract class Layer {
public Boolean IsGrayscale { get; set; }
public Boolean IsNegative { get; set; }
public Single Transparency { get; set; }
protected virtual void OnDrawingException(DrawingExceptionLayerEventArgs e);
protected virtual void OnDrawnException(DrawnExceptionLayerEventArgs e);
public struct LegendDrawingParameters {
public Single XOffset { get; set; }
public Single YOffset { get; set; }
public override Boolean Equals(Object obj);
public override Int32 GetHashCode();
public static Boolean operator==(LegendDrawingParameters param1, LegendDrawingParameters param2);
public static Boolean operator!=(LegendDrawingParameters param1, LegendDrawingParameters param2);
public Single XOffset;
public Single YOffset;
public enum LegendImageJustificationMode {
public enum LineDashStyle {
public class LineShape : LineBaseShape {
[ObsoleteAttribute("This API is obsolete, please use GetLineOnALineCore(StartingPoint startingPoint, double startingDistance, double distance, GeographyUnit shapeUnit, DistanceUnit distanceUnit) instead. This API is obsolete and may be removed in or after Version 7.0.")]
protected virtual LineBaseShape GetLineOnALineCore(StartingPoint startingPoint, PointShape endPointShape);
protected virtual LineBaseShape GetLineOnALineCore(StartingPoint startingPoint, Single percentageOfLine);
protected virtual LineBaseShape GetLineOnALineCore(PointShape startPointShape, PointShape endPointShape);
[ObsoleteAttribute("This API is obsolete, please use GetPointOnALineCore(StartingPoint startingPoint, double distance, GeographyUnit shapeUnit, DistanceUnit distanceUnit) instead. This API is obsolete and may be removed in or after Version 7.0.")]
protected virtual PointShape GetPointOnALineCore(StartingPoint startingPoint, Single percentageOfLine);
public class ManagedGeoTiffRasterSource : RasterSource {
public enum MapResizeMode {
public enum MatrixReferenceCorner {
public class MultilineShape : LineBaseShape {
[AttributeUsageAttribute(AttributeTargets.Delegate | AttributeTargets.Enum | AttributeTargets.Struct | AttributeTargets.Class, Inherited=false)]
public class NonSerializableBaseTypeAttribute : Attribute {
public NonSerializableBaseTypeAttribute();
[AttributeUsageAttribute(AttributeTargets.Method, Inherited=false)]
public sealed class OnGeodeserializedAttribute : Attribute {
public OnGeodeserializedAttribute();
public sealed class OnGeodeserializingAttribute : Attribute {
public OnGeodeserializingAttribute();
public sealed class OnGeoserializedAttribute : Attribute {
public OnGeoserializedAttribute();
public sealed class OnGeoserializingAttribute : Attribute {
public OnGeoserializingAttribute();
public class OpenStreetMapLayer : Layer {
public Collection
public enum OpenStreetMapLayerPictureFormat {
public enum OverwriteMode {
public enum PanDirection {
public enum PenBrushDrawingOrder {
public enum PointPlacement {
public enum PointSymbolType {
public enum PointType {
public enum PolygonLabelingLocationMode {
public abstract class PositionStyle : Style {
protected String Format(String text, BaseShape labeledShape);
protected virtual String FormatCore(String text, BaseShape labeledShape);
protected virtual void OnFormatted(FormattedPositionStyleEventArgs e);
protected virtual void OnFormatting(FormattingPositionStyleEventArgs e);
public enum PrinterDragMode {
Dragable,
Draggable
public abstract class PrinterLayer : Layer {
protected public PrinterLayer();
public enum PrinterOrientation {
public enum PrinterPageSize {
public enum PrinterResizeMode {
public enum PrinterWrapMode {
public enum PrintingUnit {
public enum QueryType {
public enum RandomColorType {
public enum RegexMatching {
public class RemovedGeoCollectionEventArgs : EventArgs {
public class RemovingGeoCollectionEventArgs : EventArgs {
public enum RestrictionMode {
public enum RestrictionStyle {
public enum ReturningColumnsType {
public struct RowColumnRange {
[ObsoleteAttribute("This class is obsolete, please use SendingWebRequestEventArgs instead. This API is obsolete and may be removed in or after Version 7.0.")]
public class SendingRequestBingMapsLayerEventArgs : EventArgs {
[ObsoleteAttribute("This property is obsolete, please use property WebRequest instead. This API is obsolete and may be removed on or after May 1st 2012.")]
public SendingRequestBingMapsLayerEventArgs(String requestUri);
public String RequestUri { get; set; }
public class SendingRequestWmsRasterSourceEventArgs : EventArgs {
[ObsoleteAttribute("This property is obsolete, please use SendingRequestWmsRasterSourceEventArgs(WebRequest webRequest) instead. This API is obsolete and may be removed on or after May 1st 2012.")]
public SendingRequestWmsRasterSourceEventArgs(Uri requestUri);
public Uri RequestUri { get; set; }
public class SendingWebRequestEventArgs : EventArgs {
public SendingWebRequestEventArgs();
public SendingWebRequestEventArgs(WebRequest webRequest);
public WebRequest WebRequest { get; set; }
[ObsoleteAttribute("This class is obsolete, please use SentWebRequestEventArgs instead. This API is obsolete and may be removed in or after Version 7.0.")]
public class SentRequestBingMapsLayerEventArgs : EventArgs {
[ObsoleteAttribute("This constructor is obsolete, please use the one using HttpWebResponse as parameter instead. This API is obsolete and may be removed on or after May 1st 2012.")]
public SentRequestBingMapsLayerEventArgs(String requestUri);
public class SentRequestWmsRasterSourceEventArgs : EventArgs {
public class SentWebRequestEventArgs : EventArgs {
public SentWebRequestEventArgs();
public SentWebRequestEventArgs(WebResponse response);
public WebResponse Response { get; set; }
[ObsoleteAttribute("This class is obsolete, it's just used for BinaryFormatter now and we strongly recommend using GeoSerializer instead.")]
public static class SerializationHelper {
public class ShapeFileFeatureLayer : FeatureLayer {
public Int32 ProgressiveDrawingRecordsCount { get; set; }
public Int32 SimplificationAreaInPixel { get; set; }
protected override void DrawCore(GeoCanvas canvas, Collection
public class ShapeFileFeatureSource : FeatureSource {
public Collection
public Collection
protected override RectangleShape GetBoundingBoxByIdCore(String id);
protected override Collection
public enum ShapeFileReadWriteMode {
public enum ShapeFileType {
public enum ShapeValidationMode {
public enum SimplificationType {
public enum SpatialDataType {
public enum SplineType {
public enum StartingPoint {
public class TabFeatureSource : FeatureSource {
public enum TabFileReadWriteMode {
public enum TextHorizontalAlignment {
public enum ThreadSafetyLevel {
public enum TileAccessMode {
public class TiledWmsLayer : Layer {
[ObsoleteAttribute("This method is obsoleted. This API is only used internally and will be replaced by a new API in the near future. Please do not call this API.")]
protected override ThreadSafetyLevel GetThreadSafetyLevelCore();
[ObsoleteAttribute("This method is obsolete, please use OnSendingWebRequest instead. This API is obsolete and may be removed in or after Version 7.0.")]
protected virtual void OnSendingRequest(SendingRequestTiledWmsLayerEventArgs e);
[ObsoleteAttribute("This method is obsolete, please use OnSentWebRequest instead. This API is obsolete and may be removed in or after Version 7.0.")]
protected virtual void OnSentRequest(SentRequestTiledWmsLayerEventArgs e);
[ObsoleteAttribute("This method is obsolete, please use OnSendingRequest instead. This API is obsolete and may be removed on or after May 1st 2012.")]
protected virtual void OnSendingTile(SendingTiledWmsLayerEventArgs e);
[ObsoleteAttribute("This method is obsolete, please use OnSentRequest instead. This API is obsolete and may be removed on or after May 1st 2012.")]
protected virtual void OnSentTile(SentTiledWmsLayerEventArgs e);
[ObsoleteAttribute("This event is obsolete, please use SendingRequest instead. This API is obsolete and may be removed on or after May 1st 2012.")]
[ObsoleteAttribute("This event is obsolete, please use SentRequest instead. This API is obsolete and may be removed on or after May 1st 2012.")]
public enum TileImageFormat {
public abstract class TileMatrix : Matrix {
protected TileMatrix(String id, Double scale, Int32 tileWidth, Int32 tileHeight, GeographyUnit boundingBoxUnit, MatrixReferenceCorner referenceCorner);
public class TileMatrixSet {
public class TinyGeoFeatureLayer : FeatureLayer {
public TinyGeoFeatureLayer();
public TinyGeoFeatureLayer(String tinyGeoPathFileName);
public TinyGeoFeatureLayer(String tinyGeoPathFileName, String password);
public override Boolean HasBoundingBox { get; }
public String Password { get; set; }
public String TinyGeoPathFileName { get; set; }
public static void CreateTinyGeoFile(String tinyGeoPathFileName, String shapePathFileName, GeographyUnit unitOfData, ReturningColumnsType returningColumnType);
public static void CreateTinyGeoFile(String tinyGeoPathFileName, String shapePathFileName, GeographyUnit unitOfData, IEnumerable
public static void CreateTinyGeoFile(String tinyGeoPathFileName, String shapePathFileName, GeographyUnit unitOfData, ReturningColumnsType returningColumnType, String password);
public static void CreateTinyGeoFile(String tinyGeoPathFileName, String shapePathFileName, GeographyUnit unitOfData, ReturningColumnsType returningColumnType, Double precisionInMeter);
public static void CreateTinyGeoFile(String tinyGeoPathFileName, String shapePathFileName, GeographyUnit unitOfData, ReturningColumnsType returningColumnType, String password, Double precisionInMeter);
public static void DecryptTinyGeoFile(String encryptedTinyGeoPathFileName, String decryptedTinyGeoPathFileName, String password);
public static void EncryptTinyGeoFile(String unencryptedTinyGeoPathFileName, String encryptedTinyGeoPathFileName, String password);
public static Double GetOptimalPrecision(String shapePathFileName, GeographyUnit unitOfData, DistanceUnit returningDistanceUnit, TinyGeoPrecisionMode precisionMode);
public class TinyGeoFeatureSource : FeatureSource {
public TinyGeoFeatureSource();
public TinyGeoFeatureSource(String tinyGeoPathFileName);
public TinyGeoFeatureSource(String tinyGeoPathFileName, String password);
protected override RectangleShape GetBoundingBoxCore();
public enum TinyGeoPrecisionMode {
AllowSplitting,
PreventSplitting
public enum TransactionResultStatus {
public enum UnitSystem {
NauticalMile
public static class UnsafeHelper {
[ObsoleteAttribute("This class is obsoleted, please use BingMapsZoomLevelSet instead. This API is obsolete and may be removed in or after Version 7.0.")]
public class VirtualEarthZoomLevelSet : ZoomLevelSet {
public enum WellKnownType {
public class WfsFeatureLayer : FeatureLayer {
public class WfsFeatureSource : FeatureSource {
public enum WkbByteOrder {
public class WmsRasterLayer : RasterLayer {
public class WmsRasterSource : RasterSource {
protected virtual void OnSendingRequest(SendingRequestWmsRasterSourceEventArgs e);
protected virtual void OnSentRequest(SentRequestWmsRasterSourceEventArgs e);
public class WorldMapKitLayer : Layer {
public enum WorldMapKitProjection {
public enum WrappingMode {
public class XmlGeoSerializationFormatter : GeoSerializationFormatter {
public XmlGeoSerializationFormatter();
protected override GeoObjectModel LoadCore(Stream stream);
[ObsoleteAttribute("This class is obsolete, for Yahoo has shut down this service on September 13,2011. This API is obsolete and may be removed in or after Version 7.0.")]
public class YahooMapsLayer : Layer, IDisposable {
public enum YahooMapsPictureFormat {
public class YahooMapZoomLevelSet : ZoomLevelSet {
public class SendingTiledWmsLayerEventArgs;
public class SentTiledWmsLayerEventArgs;
Release date: 12/31/2011
No API changes in this version.
Release date: 11/14/2011
New namespaces: 0
Types
Types removed from existing namespaces: 0
Members
Members added on new types: 212
Members added to existing types: 35
Members removed from existing types: 44
Members removed on removed types: 0
Attributes
Attributes removed: 1
Attributes removed and shown: 1
Others
MapSuiteCore, Version=5.5.0.0, Culture=neutral, PublicKeyToken=null
public class AreaStyle : Style {
[ObsoleteAttribute("This method is obsolete, please use the method: DrawSampleCore(GeoCanvas canvas, DrawingRectangleF drawingExtent). This API is obsolete and may be removed on or after November 1st 2011.", false)]
protected override void DrawSampleCore(GeoCanvas canvas);
public Uri GetImageryUri(Int32 rowIndex, Int32 columnIndex, Int32 zoomLevelIndex);
Clockwise,
CounterClockwise
public class DataGridPrinterLayer : PrinterLayer {
public DataGridPrinterLayer();
public DataGridPrinterLayer(DataTable dataTable, GeoFont textFont);
public DataTable DataTable { get; set; }
public GeoBrush TextBrush { get; set; }
public GeoFont TextFont { get; set; }
public GeoPen CellBorderPen { get; set; }
public TextHorizontalAlignment TextHorizontalAlignment { get; set; }
public class DynamicIsoLineLayer : IsoLineLayer {
public DynamicIsoLineLayer();
public DynamicIsoLineLayer(Dictionary
public Dictionary
public Double NoDataValue { get; set; }
public GridInterpolationModel DynamicGridInterpolationModel { get; set; }
public Int32 CellHeightInPixel { get; set; }
public Int32 CellWidthInPixel { get; set; }
public Collection
public abstract class FeatureLayer : Layer {
public Int32 MaxRecordsToDraw { get; set; }
public class FileBitmapTileCache : BitmapTileCache {
public String GetTileImageFileName(Int64 row, Int64 column);
public abstract class GeoCanvas {
public void DrawTextWithScreenCoordinate(String text, GeoFont font, GeoBrush fillBrush, GeoPen haloPen, Single upperLeftXInScreen, Single upperLeftYInScreen, DrawingLevel drawingLevel);
public void DrawTextWithWorldCoordinate(String text, GeoFont font, GeoBrush fillBrush, GeoPen haloPen, Double upperLeftXInWorld, Double upperLeftYInWorld, DrawingLevel drawingLevel);
public struct GeoColor {
public static Collection
public class GeoFont {
public Int64 Id { get; }
public class GridCell {
public GridCell();
public GridCell(Double centerX, Double centerY, Double value);
public Double CenterX { get; set; }
public Double CenterY { get; set; }
public Double Value { get; set; }
public class GridFeatureLayer : FeatureLayer {
public String DataValueColumnName { get; }
public GridCell[,] GenerateGridMatrix();
public static GridCell[,] GenerateGridMatrix(GridDefinition gridDefinition, GridInterpolationModel gridInterpolationModel);
public GridIsoLineLayer();
public GridIsoLineLayer(String gridPathFilename);
public GridIsoLineLayer(String gridPathFilename, IEnumerable
public String GridPathFilename { get; set; }
public Collection
public class ImagePrinterLayer : PrinterLayer {
public ImagePrinterLayer();
public ImagePrinterLayer(GeoImage image);
public ImagePrinterLayer(GeoImage image, Double centerX, Double centerY, PrintingUnit unit);
public GeoImage Image { get; set; }
public PrintingUnit Unit { get; set; }
protected override RectangleShape SetPositionCore(Double width, Double height, Double centerPointX, Double centerPointY, PrintingUnit unit);
public class InMemoryGridFeatureLayer : FeatureLayer {
public InMemoryGridFeatureLayer();
public InMemoryGridFeatureLayer(GridCell[,] gridMatrix);
public Double CellSize { get; }
public Double NoDataValue { get; }
public GridCell[,] GridMatrix { get; set; }
public Int32 ColumnCount { get; }
public Int32 RowCount { get; }
public static void GenerateGrid(GridDefinition gridDefinition, GridInterpolationModel gridInterpolationModel, Stream outputStream);
public class InMemoryGridFeatureSource : FeatureSource {
public InMemoryGridFeatureSource();
public InMemoryGridFeatureSource(GridCell[,] gridMatrix);
public override Boolean IsEditable { get; }
public PointShape LowerLeftPoint { get; }
protected override TransactionResult CommitTransactionCore(TransactionBuffer transactions);
protected override Int32 GetCountCore();
public class InMemoryGridIsoLineLayer : IsoLineLayer {
public InMemoryGridIsoLineLayer();
public InMemoryGridIsoLineLayer(GridCell[,] gridMatrix);
public InMemoryGridIsoLineLayer(GridCell[,] gridMatrix, IEnumerable
public Collection
protected IsoLineLayer();
protected IsoLineLayer(IEnumerable
public Collection
public Collection CustomStyles { get; }
public Double LowerScale { get; set; }
public Double UpperScale { get; set; }
public String DataValueColumnName { get; set; }
protected abstract Collection
LinesOnly,
ClosedLinesAsPolygons
public class LabelPrinterLayer : PrinterLayer {
public LabelPrinterLayer();
public LabelPrinterLayer(String text, GeoFont font, GeoBrush textBrush);
public GeoFont Font { get; set; }
public PrinterWrapMode PrinterWrapMode { get; set; }
public ThreadSafetyLevel GetThreadSafetyLevel();
protected virtual ThreadSafetyLevel GetThreadSafetyLevelCore();
public class LegendPrinterLayer : PrinterLayer {
public LegendPrinterLayer();
public LegendPrinterLayer(LegendAdornmentLayer legendAdormentLayer);
public GeoCollection
public LegendItem Footer { get; set; }
public LegendItem Title { get; set; }
public Single Height { get; set; }
public Single Width { get; set; }
public Single XOffsetInPixel { get; set; }
public Single YOffsetInPixel { get; set; }
public class LineStyle : Style {
public class ManagedProj4Projection : Projection {
[ObsoleteAttribute("This property is obsolete, please use property: ExternalProjectionParametersString. This API is obsolete and may be removed on or after November 1st 2011.", false)]
public String ExternalProjectionParameters { get; set; }
[ObsoleteAttribute("This method is obsolete, please use static method: GetBingMapParametersString. This API is obsolete and may be removed on or after November 1st 2011.", false)]
public static String GetBingMapParameter();
[ObsoleteAttribute("This method is obsolete, please use static method: GetEpsgParametersString. This API is obsolete and may be removed on or after November 1st 2011.", false)]
public static String GetEpsgParameters(Int32 srid);
[ObsoleteAttribute("This method is obsolete, please use GetEpsgParametersString(int srid) or GetEsriParametersString(int srid) instead. This API is obsolete and may be removed on or after November 1st 2011.", false)]
public static String GetEsriExtraParameters(Int32 srid);
public static String GetEsriExtraParametersString(Int32 srid);
[ObsoleteAttribute("This method is obsolete, please use static method: GetEsriParametersString. This API is obsolete and may be removed on or after November 1st 2011.", false)]
public static String GetEsriParameters(Int32 srid);
public static String GetGL27Parameters(Int32 srid);
public static String GetGL27ParametersString(Int32 srid);
[ObsoleteAttribute("This method is obsolete, please use static method: GetGoogleMapParametersString. This API is obsolete and may be removed on or after November 1st 2011.", false)]
public static String GetGoogleMapParameters();
public static String GetNad27Parameters(Int32 srid);
public static String GetNad27ParametersString(Int32 srid);
public static String GetNad83Parameters(Int32 srid);
public static String GetNad83ParametersString(Int32 srid);
public static String GetOtherExtraParameters(Int32 srid);
public static String GetOtherExtraParametersString(Int32 srid);
[ObsoleteAttribute("This method is obsolete, please use static method: GetSphericalMercatorParametersString. This API is obsolete and may be removed on or after November 1st 2011.", false)]
public static String GetSphericalMercatorParameter();
public static String GetVirtualEarthParameters();
public static String GetWorldParameters(Int32 srid);
public static String GetWorldParametersString(Int32 srid);
[ObsoleteAttribute("This property is obsolete, please use property: InternalProjectionParametersString. This API is obsolete and may be removed on or after November 1st 2011.", false)]
public String InternalProjectionParameters { get; set; }
public class MapPrinterLayer : PrinterLayer {
public MapPrinterLayer();
public MapPrinterLayer(IEnumerable
public Collection
public GeographyUnit MapUnit { get; set; }
public RectangleShape MapExtent { get; set; }
public class MultipolygonShape : AreaBaseShape {
protected override Boolean ContainsCore(BaseShape targetShape);
public class PagePrinterLayer : PrinterLayer {
public PagePrinterLayer();
public PagePrinterLayer(PrinterPageSize pageSize, PrinterOrientation orientation);
public PrinterOrientation Orientation { get; set; }
public PrinterPageSize PageSize { get; set; }
public Single CustomHeight { get; set; }
public Single CustomWidth { get; set; }
protected override RectangleShape GetPositionCore(PrintingUnit unit);
public class PointStyle : Style {
Fixed,
Dragable
public static class PrinterHelper {
public static Double ConvertLength(Double length, PrintingUnit fromUnit, PrintingUnit toUnit);
public static Double GetPointsPerGeographyUnit(GeographyUnit mapUnit);
public AreaStyle BackgroundMask { get; set; }
public Boolean IsDrawing { get; set; }
public PrinterDragMode DragMode { get; set; }
public PrinterResizeMode ResizeMode { get; set; }
public RectangleShape GetPosition();
public RectangleShape GetPosition(PrintingUnit unit);
public void SetPosition(RectangleShape boundingBox);
public void SetPosition(RectangleShape boundingBox, PrintingUnit unit);
public void SetPosition(Double width, Double height, PointShape centerPoint, PrintingUnit unit);
public void SetPosition(Double width, Double height, Double centerPointX, Double centerPointY, PrintingUnit unit);
protected virtual RectangleShape GetPositionCore(PrintingUnit unit);
protected virtual RectangleShape SetPositionCore(Double width, Double height, Double centerPointX, Double centerPointY, PrintingUnit unit);
Portrait,
Landscape
AnsiA,
AnsiB,
AnsiC,
AnsiD,
AnsiE,
Custom
Fixed,
MaintainAspectRatio,
Resizable
AutoSizeText,
WrapText
public class PrinterZoomLevelSet : ZoomLevelSet {
public PrinterZoomLevelSet();
public PrinterZoomLevelSet(GeographyUnit pageBaseUnit, Double pageBaseUnitToPageUnitRatio);
public Double PageBaseUnitToPageUnitRatio { get; set; }
public GeographyUnit PageBaseUnit { get; set; }
public Double GetZoomPercentage(ZoomLevel ZoomLevel);
Millimeter,
Inch,
Meter,
Centimeter,
Point
public class Proj4Projection : Projection, IDisposable {
public static String GetGL27ParametersString(String srid);
public static String GetWorldParametersString(String srid);
public abstract class RasterLayer : Layer {
[ObsoleteAttribute("This property is obsolete, please use property: KeyColors. This API is obsolete and may be removed on or after November 1st 2011.", false)]
public GeoColor KeyColor { get; set; }
public class RectangleShape : AreaBaseShape {
public class ScaleBarPrinterLayer : PrinterLayer {
public ScaleBarPrinterLayer(MapPrinterLayer mapPrinterLayer);
public Boolean HasMask { get; set; }
public Dictionary
public GeoBrush AlternateBarBrush { get; set; }
public GeoBrush BarBrush { get; set; }
public GeoBrush MaskBrush { get; set; }
public GeoColor TextColor { get; set; }
public GeoPen MaskOuterPen { get; set; }
public Int32 Height { get; set; }
public Int32 MaxWidth { get; set; }
public MapPrinterLayer MapPrinterLayer { get; set; }
public String NumberFormat { get; set; }
public UnitSystem UnitFamily { get; set; }
public class ScaleLinePrinterLayer : PrinterLayer {
public ScaleLinePrinterLayer(MapPrinterLayer mapPrinterLayer);
public SendingRequestBingMapsLayerEventArgs(WebRequest webRequest);
public class SendingRequestTiledWmsLayerEventArgs : EventArgs {
public SendingRequestTiledWmsLayerEventArgs();
public SendingRequestTiledWmsLayerEventArgs(WebRequest webRequest);
public SendingRequestWmsRasterSourceEventArgs();
public SendingRequestWmsRasterSourceEventArgs(WebRequest webRequest);
[ObsoleteAttribute("This class is obsolete, please use SendingRequestWmsLayerEventArgs instead. This API is obsolete and may be removed on or after May 1st 2012.")]
public class SendingTiledWmsLayerEventArgs : EventArgs {
public SentRequestBingMapsLayerEventArgs(HttpWebResponse response);
public HttpWebResponse Response { get; set; }
public class SentRequestTiledWmsLayerEventArgs : EventArgs {
public SentRequestTiledWmsLayerEventArgs();
public SentRequestTiledWmsLayerEventArgs(HttpWebResponse response);
[ObsoleteAttribute("This class is obsolete, please use SentRequestWmsLayerEventArgs instead. This API is obsolete and may be removed on or after May 1st 2012.")]
public class SentTiledWmsLayerEventArgs : EventArgs {
public class SimpleColors {
public GeoColor White { get; }
public abstract class Style {
[ObsoleteAttribute("This method is obsolete, please use the method: DrawSample(GeoCanvas canvas, DrawingRectangleF drawingExtent). This API is obsolete and may be removed on or after November 1st 2011.", false)]
public void DrawSample(GeoCanvas canvas);
protected virtual void DrawSampleCore(GeoCanvas canvas);
Left,
Center,
Right
public class TextStyle : PositionStyle {
Unsafe,
Safe
public ZoomLevelSet ZoomLevelSet { get; set; }
[ObsoleteAttribute("This constructor is obsolete, please use TiledWmsLayer(IEnumerable
public TiledWmsLayer(Uri serverUri, WebProxy webProxy, String clientId, String privateKey);
public TiledWmsLayer(Uri serverUri);
public TiledWmsLayer(Uri serverUri, String clientId, String privateKey);
public TiledWmsLayer(Uri serverUri, WebProxy webProxy);
public class UnmanagedProj4Projection : Projection, IDisposable {
Release date: 07/07/2011
| Assembly | Members Added | Members Removed | Breaking Changes |
| ServicesEdition | 14 added | 0 removed | 0 breaking |
API Changes
New namespaces: 0
Types
Types added to existing namespaces: 1
Total number of types added (in both new and existing namespaces): 1
Members
Members added on new types: 3
Members added to existing types: 11
Members removed from existing types: 0
Attributes
Attributes added: 2
Attributes added and shown: 2
Others
MapSuiteCore, Version=5.0.0.55, Culture=neutral, PublicKeyToken=null
public DrawingLevel DrawingLevel { get; set; }
Default,
NoLogo,
DisplayLogo
public BuildingIndexShapeFileFeatureSourceEventArgs(Int32 recordCount, Int32 currentRecordIndex, Feature currentFeature, DateTime startProcessTime, Boolean cancel, String shapePathFileName);
public String ShapePathFileName { get; }
public RectangleShape WrappingExtent { get; set; }
public WrappingMode WrappingMode { get; set; }
public abstract class GridInterpolationModel {
public class InverseDistanceWeightedGridInterpolationModel : GridInterpolationModel {
public DrawingLevel CenterPenDrawingLevel { get; set; }
public DrawingLevel InnerPenDrawingLevel { get; set; }
public DrawingLevel OuterPenDrawingLevel { get; set; }
Release date: 05/16/2011
| ServicesEdition | 182 added | 32 removed | 50 breaking |
API Changes
New namespaces: 0
Types
Types added to existing namespaces: 23
Total number of types added (in both new and existing namespaces): 24
Members
Members added on new types: 139
Members added to existing types: 116
Members removed from existing types: 32
Attributes
Attributes added: 42
Attributes added and shown: 42
Others
Parameter name changes: 18
MapSuiteCore, Version=5.0.0.0, Culture=neutral, PublicKeyToken=null
public abstract class AdornmentLayer : Layer {
public protected virtual ScreenPointF GetDrawingLocation(GeoCanvas canvas, Single adornmentWidth, Single adornmentHeight);
protected override void DrawSampleCore(GeoCanvas canvas, DrawingRectangleF drawingExtent);
public BingMapsLayer();
public BingMapsLayer(String applicationId);
public BingMapsLayer(String applicationId, BingMapsMapType mapType);
public BingMapsLayer(String applicationId, BingMapsMapType mapType, String cacheDirectory);
public BingMapsMapType MapType { get; set; }
public BingMapsPictureFormat CachePictureFormat { get; set; }
public Int32 TimeoutInSeconds { get; set; }
public String ApplicationId { get; set; }
public String CacheDirectory { get; set; }
public WebProxy Proxy { get; set; }
Road,
BirdseyeWithLabels,
Birdseye,
AerialWithLabels,
Aerial
Default,
Gif,
Jpeg,
Png
public class BingMapsZoomLevelSet : ZoomLevelSet {
public BingMapsZoomLevelSet();
public class CreatingRequestGoogleMapsLayerEventArgs : EventArgs {
public CreatingRequestGoogleMapsLayerEventArgs();
public CreatingRequestGoogleMapsLayerEventArgs(Uri requestUri);
public class DrawingWrappingFeaturesFeatureLayerEventArgs : EventArgs {
public DrawingWrappingFeaturesFeatureLayerEventArgs();
public DrawingWrappingFeaturesFeatureLayerEventArgs(Collection
public Collection
public Feature(String wellKnownText, String id, IEnumerable
public class FeatureCache {
[ObsoleteAttribute("We have marked this property into obsolete to remind it is no use any more. This API is obsolete and may be removed on or after May 1st 2011.")]
protected Dictionary
protected virtual void OnDrawingWrappingFeatures(DrawingWrappingFeaturesFeatureLayerEventArgs e);
public Collection
protected virtual RectangleShape ConvertToInternalProjection(RectangleShape rectangle);
[ObsoleteAttribute("This API is obsolete and will be removed from next release, we recommend you use GetFeaturesByColumnValueCore(string columnName, string columnValue, IEnumerable
public class GdiPlusGeoCanvas : GeoCanvas {
public InterpolationMode InterpolationMode { get; set; }
public class GdiPlusRasterLayer : RasterLayer {
public class GdiPlusRasterSource : RasterSource {
[ObsoleteAttribute("This property is obsolete, please use property: Transparency. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public Single AlphaComponent { get; set; }
[ObsoleteAttribute("This property is obsolete, please use property: BlueTranslation. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public Single BlueComponent { get; set; }
[ObsoleteAttribute("This property is obsolete, please use property: GreenTranslation. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public Single GreenComponent { get; set; }
[ObsoleteAttribute("This property is obsolete, please use property: RedTranslation. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public Single RedComponent { get; set; }
public Boolean EnableCliping { get; set; }
public RectangleShape ClipingArea { get; set; }
[ObsoleteAttribute("This property is obsolete, please use property: KeyColors. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public class GeoTiffRasterLayer : RasterLayer {
public DrawingQuality DrawingQuality { get; set; }
protected virtual void OnCreatingRequest(CreatingRequestGoogleMapsLayerEventArgs e);
[ObsoleteAttribute("License key is not required for GoogleMap free edition anymore. This API is obsolete and may be removed on or after May 1st 2011.")]
public GoogleMapsLayer(String licenseKey, String cacheDirectory);
public GoogleMapsLayer(String licenseKey);
[ObsoleteAttribute("This API is obsolete and will be removed from next release, we recommend you use GetGoogleMapsImage(double longitude, double latitude, int zoomLevelNumber, double tileScreenWidth, double tileScreenHeight). This API is obsolete and may be removed on or after May 1st 2011.")]
public void FetchImageInThread(Object obj);
public String LicenseKey { get; set; }
public GridDefinition();
public GridDefinition(RectangleShape gridExtent, Double cellSize, Double noDataValue, Dictionary
public Dictionary
protected GridInterpolationModel();
public Double Interpolate(RectangleShape cellExtent, GridDefinition gridDefinition);
protected abstract Double InterpolateCore(RectangleShape cellExtent, GridDefinition gridDefinition);
public class HeatLayer : Layer {
public class HeatStyle : Style {
public class IconValueStyle : PositionStyle {
public Boolean LabelAllLineParts { get; set; }
public PolygonLabelingLocationMode PolygonLabelingLocationMode { get; set; }
public InverseDistanceWeightedGridInterpolationModel();
public InverseDistanceWeightedGridInterpolationModel(Double power, Double searchRadius);
public Double Power { get; set; }
public Double SearchRadius { get; set; }
protected override Double InterpolateCore(RectangleShape cellExtent, GridDefinition gridDefinition);
public class LegendAdornmentLayer : AdornmentLayer {
public LegendAdornmentLayer();
Default,
JustifyImageLeft,
JustifyImageRight
public class LegendItem {
public LegendItem();
public LegendItem(Int32 width, Int32 height, Single imageWidth, Single imageHeight, Style imageStyle, TextStyle textStyle);
public AreaStyle ImageMask { get; set; }
public AreaStyle TextMask { get; set; }
public LegendImageJustificationMode ImageJustificationMode { get; set; }
public Single BottomPadding { get; set; }
public Single ImageBottomPadding { get; set; }
public Single ImageHeight { get; set; }
public Single ImageLeftPadding { get; set; }
public Single ImageRightPadding { get; set; }
public Single ImageTopPadding { get; set; }
public Single ImageWidth { get; set; }
public Single LeftPadding { get; set; }
public Single RightPadding { get; set; }
public Single TextBottomPadding { get; set; }
public Single TextLeftPadding { get; set; }
public Single TextRightPadding { get; set; }
public Single TextTopPadding { get; set; }
public Single TopPadding { get; set; }
public Style ImageStyle { get; set; }
public TextStyle TextStyle { get; set; }
public void Draw(GeoCanvas adornmentGeoCanvas, Collection
protected virtual Int32 CustomWarpLength();
protected virtual void DrawCore(GeoCanvas adornmentGeoCanvas, Collection
public abstract class LineBaseShape : BaseShape {
public MultilineShape GetIntersection(Feature targetFeature);
public MultilineShape GetIntersection(AreaBaseShape targetShape);
protected virtual MultilineShape GetIntersectionCore(AreaBaseShape targetShape);
public class LogoAdornmentLayer : AdornmentLayer {
public LogoAdornmentLayer(GeoImage image);
public String ExternalProjectionParametersString { get; set; }
public String InternalProjectionParametersString { get; set; }
protected override GeographyUnit GetExternalGeographyUnitCore();
protected override GeographyUnit GetInternalGeographyUnitCore();
public static String ConvertEpsgToPrj(Int32 srid);
public static String ConvertPrjToProj4(String prjString);
public static String ConvertProj4ToPrj(String proj4String);
public static String GetBingMapParametersString();
public static String GetDecimalDegreesParametersString();
public static String GetEpsgParametersString(Int32 srid);
public static String GetEsriParametersString(Int32 srid);
public static String GetGoogleMapParametersString();
public static String GetLatLongParametersString();
public static String GetSphericalMercatorParametersString();
public static String GetWgs84ParametersString();
public class MsSql2008FeatureLayer : FeatureLayer {
public String CustomGeometryColumnName { get; set; }
public static void CreateTable(String connectionString, String tableName, SpatialDataType spatialDataType);
public static void CreateTable(String connectionString, String tableName, SpatialDataType spatialDataType, IEnumerable
public class MsSql2008FeatureSource : FeatureSource {
public class MultipleFeatureSource : FeatureSource {
public class MultipleShapeFileFeatureLayer : FeatureLayer {
public MultipleShapeFileFeatureLayer(IEnumerable
public Collection
public MultipleShapeFileFeatureLayer(String[] multipleShapeFiles, String[] multipleShapeFileIndexes);
public class MultipleShapeFileFeatureSource : FeatureSource {
public MultipleShapeFileFeatureSource(IEnumerable
public Collection
public MultipleShapeFileFeatureSource(String[] multipleShapeFiles, String[] multipleShapeFileIndexes);
public class OpenStreetMapsZoomLevelSet : ZoomLevelSet {
public OpenStreetMapsZoomLevelSet();
Default,
Centroid,
BoundingBoxCenter
protected Boolean LabelAllLineParts { get; set; }
protected PolygonLabelingLocationMode PolygonLabelingLocationMode { get; set; }
[ObsoleteAttribute("This property is obsolete, please use property: TextFormat. This API is obsolete and may be removed on or after May 1st 2011.", false)]
protected String Format { get; set; }
protected override Projection CloneDeepCore();
[ObsoleteAttribute("This method is obsolete, please use static method: GetEpsgParametersString. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public String GetEpsgParameters(Int32 srid);
[ObsoleteAttribute("This method is obsolete, please use static method: GetEsriExtraParametersString. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public String GetEsriExtraParameters(Int32 srid);
[ObsoleteAttribute("This method is obsolete, please use static method: GetEsriParametersString. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public String GetEsriParameters(Int32 srid);
[ObsoleteAttribute("This method is obsolete, please use static method: GetGL27ParametersString. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public String GetGL27Parameters(String srid);
[ObsoleteAttribute("This method is obsolete, please use static method: GetGoogleMapParametersString. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public String GetGoogleMapParameters();
[ObsoleteAttribute("This method is obsolete, please use static method: GetNad27ParametersString. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public String GetNad27Parameters(Int32 srid);
[ObsoleteAttribute("This method is obsolete, please use static method: GetNad83ParametersString. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public String GetNad83Parameters(Int32 srid);
[ObsoleteAttribute("This method is obsolete, please use static method: GetOtherExtraParametersString. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public String GetOtherExtraParameters(Int32 srid);
[ObsoleteAttribute("This method is obsolete, please use static method: GetWorldParametersString. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public String GetWorldParameters(String srid);
public abstract class Projection {
public GeographyUnit GetExternalGeographyUnit();
public GeographyUnit GetInternalGeographyUnit();
protected virtual GeographyUnit GetExternalGeographyUnitCore();
protected virtual GeographyUnit GetInternalGeographyUnitCore();
public class QueryTools {
public Collection
public class RotationProjection : Projection {
public RotationProjection(GeographyUnit sourceUnit);
public RotationProjection(Double angle, GeographyUnit sourceUnit);
public GeographyUnit SourceUnit { get; set; }
public class ScaleBarAdornmentLayer : AdornmentLayer {
public SendingRequestBingMapsLayerEventArgs();
public SentRequestBingMapsLayerEventArgs();
public static Object Deserialize(Byte[] serializedObject);
public ShapeFileReadWriteMode ReadWriteMode { get; set; }
public class StreamLoadingEventArgs : EventArgs {
public StreamLoadingEventArgs(String alternateStreamName, String streamType);
public StreamLoadingEventArgs(String alternateStreamName, String streamType, Stream alternateStream, FileMode fileMode, FileAccess fileAccess);
public String StreamType { get; }
public void DrawSample(GeoCanvas canvas, DrawingRectangleF drawingExtent);
protected virtual void DrawSampleCore(GeoCanvas canvas, DrawingRectangleF drawingExtent);
public class TabDbfColumn : DbfColumn {
public TabDbfColumn();
public TabDbfColumn(String columnName, DbfColumnType columnType, Int32 length, Int32 decimalLength, Boolean buildIndex, Boolean uniqueIndexColumnValues);
public Boolean BuildIndex { get; set; }
public Boolean UniqueIndexColumnValues { get; set; }
public class TabFeatureLayer : FeatureLayer {
public TabFeatureLayer();
public TabFeatureLayer(String tabPathFilename);
public TabFeatureLayer(String tabPathFilename, TabFileReadWriteMode readWriteMode);
public Boolean RequireIndex { get; set; }
public Encoding Encoding { get; set; }
public String TabPathFilename { get; set; }
public TabFileReadWriteMode ReadWriteMode { get; set; }
protected override Layer CloneDeepCore();
public static void BuildIndexFile(String tabPathFilename);
public static void BuildIndexFile(String tabPathFilename, BuildIndexMode buildIndexMode);
public static void CreateTabFile(String tabPathFilename, IEnumerable
public TabFeatureSource();
public TabFeatureSource(String tabPathFilename);
public TabFeatureSource(String tabPathFilename, TabFileReadWriteMode readWriteMode);
ReadOnly,
ReadWrite
[ObsoleteAttribute("This property is obsolete, please use property: SplineType. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public Boolean AllowSpline { get; set; }
[ObsoleteAttribute("This method is obsolete, please use static method: TextFormat. This API is obsolete and may be removed on or after May 1st 2011.", false)]
public String Format { get; set; }
public abstract class TileCache {
[ObsoleteAttribute("This property is obsolete, please use property: TileAccessMode. And you need set ReadOnly to false if you want the TileAccessMode to take effect. This API is obsolete and may be removed on or after May 1st 2011.")]
public Boolean ReadOnly { get; set; }
public TiledWmsLayer(IEnumerable
public Collection
[ObsoleteAttribute("This constructor is obsolete, please use TiledWmsLayer(Uri serverUri) instead. This API is obsolete and may be removed on or after May 1st 2011.")]
public TiledWmsLayer(String serverUri);
[ObsoleteAttribute("This method is obsolete, please use GetRequestUris instead. This API is obsolete and may be removed on or after May 1st 2011.")]
public Collection
public class WorldFile {
public RectangleShape GetBoundingBox(Single width, Single height);
Default,
None,
WrapDateline
Release date: 11/01/2010
| ServicesEdition | 122 added | 28 removed | 28 breaking |
API Changes
New namespaces: 0
Types
Types added to existing namespaces: 14
Total number of types added (in both new and existing namespaces): 14
Members
Members added on new types: 93
Members added to existing types: 77
Members removed on removed types: 33
Attributes
Attributes added: 31
Attributes added and shown: 31
Attributes removed: 26
Attributes removed and shown: 26
Others
MapSuiteCore, Version=4.5.0.0, Culture=neutral, PublicKeyToken=null
public ClusterPointStyle();
public ClusterPointStyle(GeoImage image);
public ClusterPointStyle(PointSymbolType symbolType, GeoSolidBrush symbolSolidBrush, Int32 symbolSize);
public ClusterPointStyle(GeoFont characterFont, Int32 characterIndex, GeoSolidBrush characterSolidBrush);
public ClusterPointStyle(PointSymbolType symbolType, GeoSolidBrush symbolSolidBrush, GeoPen symbolPen, Int32 symbolSize);
public Int32 CellSize { get; set; }
protected override void DrawCore(IEnumerable
public static class DecimalDegreesHelper {
public static PointShape ConvertFromMgrs(String mgrs);
public static String ConvertToMgrs(Double longitude, Double latitude);
public DrawingProgressChangedEventArgs();
public DrawingProgressChangedEventArgs(Int32 progressPercentage, Object userState);
public DrawingProgressChangedEventArgs(Int32 progressPercentage, Object userState, Int32 featuresToDraw, Int32 featuresDrawn);
public Int32 FeaturesDrawn { get; }
public Int32 FeaturesToDraw { get; }
Unknow,
CommitTransaction,
GetFeaturesInsideBoundingBox
[ObsoleteAttribute("We have marked this property into obsolete to remind it is no use any more.")]
protected virtual void OnDrawingProgressChanged(DrawingProgressChangedEventArgs e);
[ObsoleteAttribute("This property is obsolete, please use property: Transparency", false)]
[ObsoleteAttribute("This property is obsolete, please use property: BlueTranslation", false)]
[ObsoleteAttribute("This property is obsolete, please use property: GreenTranslation", false)]
[ObsoleteAttribute("This property is obsolete, please use property: RedTranslation", false)]
[ObsoleteAttribute("This property is obsolete, please use property: KeyColors", false)]
[DefaultMemberAttribute("Item")]
public class GeoCollection
public event NotifyCollectionChangedEventHandler CollectionChanged;
public event PropertyChangedEventHandler PropertyChanged;
protected override void InsertItem(Int32 index, T item);
protected virtual void OnCollectionChanged(NotifyCollectionChangedEventArgs e);
protected virtual void OnPropertyChanged(PropertyChangedEventArgs e);
public GeometryCollectionShape();
public GeometryCollectionShape(String wellKnownText);
public GeometryCollectionShape(Byte[] wellKnownBinary);
public GeometryCollectionShape(IEnumerable
public Collection
protected override MultipointShape GetCrossingCore(BaseShape targetShape);
protected override Byte[] GetWellKnownBinaryCore(WkbByteOrder byteOrder);
protected override String GetWellKnownTextCore();
protected override WellKnownType GetWellKnownTypeCore();
protected override void LoadFromWellKnownDataCore(String wellKnownText);
protected override ShapeValidationResult ValidateCore(ShapeValidationMode validationMode);
Default,
ManagedLibTiff,
UnmanagedLibTiff
public GeoTiffLibraryType LibraryType { get; set; }
public class GeoTiffRasterSource : RasterSource {
protected override RasterSource CloneDeepCore();
[ObsoleteAttribute("License key is not required for GoogleMap free edition anymore.")]
public GoogleMapsLayer(String cacheDirectory, String clientId, String privateKey, WebProxy webProxy);
public Bitmap GetGoogleMapsImage(Double longitude, Double latitude, Int32 zoomLevelNumber, Double tileWidth, Double tileHeight);
protected virtual Dictionary
protected virtual Bitmap GetGoogleMapsImageCore(Double longitude, Double latitude, Int32 zoomLevelNumber, Double tileWidth, Double tileHeight);
public MultilineShape Union(Feature targetFeature);
public MultilineShape Union(LineBaseShape targetShape);
protected virtual MultilineShape UnionCore(IEnumerable
public static MultilineShape Union(IEnumerable
public ManagedGeoTiffRasterSource(String imagePathFileName);
public ManagedGeoTiffRasterSource(String imagePathFileName, RectangleShape imageExtent);
public ManagedGeoTiffRasterSource(String imagePathFileName, String worldFilePathFileName);
protected override GeoImage GetImageCore(RectangleShape worldExtent, Int32 canvasWidth, Int32 canvasHeight);
protected override Int32 GetImageHeightCore();
protected override Int32 GetImageWidthCore();
protected override Boolean CanReproject { get; }
public class MapShape {
public class MapShapeLayer : Layer {
public String WhereClause { get; set; }
public OpenStreetMapLayer();
public OpenStreetMapLayer(WebProxy webProxy);
public OpenStreetMapLayerPictureFormat CachePictureFormat { get; set; }
public WebProxy WebProxy { get; set; }
Jpeg,
Gif,
Png8,
Png32
public class PointShape : PointBaseShape {
protected override Boolean IsWithinCore(BaseShape targetShape);
[ObsoleteAttribute("This property is obsolete, please use property: TextFormat", false)]
public enum Proj4MemoryMode {
Default,
Managed,
Unmanaged
public Proj4MemoryMode MemoryMode { get; set; }
[ObsoleteAttribute("This method is obsolete, please use static method: GetEpsgParametersString", false)]
[ObsoleteAttribute("This method is obsolete, please use static method: GetEsriExtraParametersString", false)]
[ObsoleteAttribute("This method is obsolete, please use static method: GetEsriParametersString", false)]
[ObsoleteAttribute("This method is obsolete, please use static method: GetGL27ParametersString", false)]
[ObsoleteAttribute("This method is obsolete, please use static method: GetGoogleMapParametersString", false)]
[ObsoleteAttribute("This method is obsolete, please use static method: GetNad27ParametersString", false)]
[ObsoleteAttribute("This method is obsolete, please use static method: GetNad83ParametersString", false)]
[ObsoleteAttribute("This method is obsolete, please use static method: GetOtherExtraParametersString", false)]
[ObsoleteAttribute("This method is obsolete, please use static method: GetWorldParametersString", false)]
protected virtual Boolean CanReproject { get; }
public SendingTiledWmsLayerEventArgs(Uri requestUri);
public SentRequestWmsRasterSourceEventArgs(HttpWebResponse response);
public SentTiledWmsLayerEventArgs(HttpWebResponse response);
[ObsoleteAttribute("This property is obsolete, please use property: SplineType", false)]
[ObsoleteAttribute("This method is obsolete, please use static method: TextFormat", false)]
[ObsoleteAttribute("This property is obsolete, please use property: TileAccessMode. And you need set ReadOnly to false if you want the TileAccessMode to take effect.")]
public ICredentials Credentials { get; set; }
public String ClientId { get; set; }
public String PrivateKey { get; set; }
public Dictionary
public Dictionary
public Dictionary
public Dictionary
public Collection
public Collection
public String GetServerCapabilitiesXml();
public Collection
public class UnmanagedGeoTiffRasterSource : RasterSource {
public UnmanagedGeoTiffRasterSource();
public UnmanagedGeoTiffRasterSource(String imagePathFilename);
public UnmanagedGeoTiffRasterSource(String imagePathFilename, RectangleShape imageExtent);
public UnmanagedGeoTiffRasterSource(String imagePathFilename, String worldfilePathFilename);
public String PathFilename { get; set; }
public UnmanagedProj4Projection();
public UnmanagedProj4Projection(Int32 internalEpsgSrid, Int32 externalEpsgSrid);
public UnmanagedProj4Projection(String internalProjectionParametersString, String externalProjectionParametersString);
public RectangleShape DecimalDegreeBoundary { get; set; }
public void Dispose();
protected override Vertex[] ConvertToExternalProjectionCore(Double[] x, Double[] y);
protected override Vertex[] ConvertToInternalProjectionCore(Double[] x, Double[] y);
protected override void Finalize();
GeometryCollection
public Dictionary
public Dictionary
public Dictionary
public Dictionary
public Collection
protected virtual String GetRequestUrlCore(RectangleShape worldExtent, Int32 canvasWidth, Int32 canvasHeight);
public Dictionary
public Dictionary
public Dictionary
public Dictionary
public Collection
protected virtual Uri BuildWmsGetFeatureInfoUri(ScreenPointF screenPointF, String infoFormat, Int32 maxFeatures);
public WorldMapKitLayer(String clientId, String privateKey);
public YahooMapsLayer(String licenseKey, WebProxy webProxy);
public class OracleFeatureLayer;
public class OracleFeatureSource;
Release date: 6/15/2010
Minor API additions, no breaking changes. Please see the attached HTML document for a complete enumeration.
| ServicesEdition | 24 added | 0 removed | 0 breaking |
API Changes
New namespaces: 0
Types
Types added in new namespaces: 0
Types added to existing namespaces: 8
Total number of types added (in both new and existing namespaces): 8
Members
Members added on new types: 20
Members added to existing types: 16
Attributes
Attributes added: 0
Attributes added and shown: 0
Attributes removed: 0
Attributes removed and shown: 0
Others
Parameter name changes: 0
MapSuiteCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null
namespace ThinkGeo.MapSuite.Core {
public class AddedGeoCollectionEventArgs> EventArgs {
public AddedGeoCollectionEventArgs();
public AddedGeoCollectionEventArgs(Object item);
public Object Item { get; set; }
public class AddingGeoCollectionEventArgs> EventArgs {
public AddingGeoCollectionEventArgs();
public AddingGeoCollectionEventArgs(Object item);
public classClearedItemsGeoCollectionEventArgs : EventArgs {
public ClearedItemsGeoCollectionEventArgs();
public classClearingItemsGeoCollectionEventArgs : EventArgs {
public ClearingItemsGeoCollectionEventArgs();
[SerializableAttribute]
public class GeoCollection<T> : Collection<T>, IList<T>, ICollection<T>, IEnumerable<T>, IList, ICollection, IEnumerable {
public event EventHandler<AddedGeoCollectionEventArgs> Added;
public event EventHandler<AddingGeoCollectionEventArgs> Adding;
public event EventHandler<ClearedItemsGeoCollectionEventArgs> ClearedItems;
public event EventHandler<ClearingItemsGeoCollectionEventArgs> ClearingItems;
public event EventHandler<InsertedGeoCollectionEventArgs> Inserted;
public event EventHandler<InsertingGeoCollectionEventArgs> Inserting;
public event EventHandler<RemovedGeoCollectionEventArgs> Removed;
public event EventHandler<RemovingGeoCollectionEventArgs> Removing;
protected virtual void OnAdded(AddedGeoCollectionEventArgs e);
protected virtual void OnAdding(AddingGeoCollectionEventArgs e);
protected virtual void OnClearedItems(ClearedItemsGeoCollectionEventArgs e);
protected virtual void OnClearingItems(ClearingItemsGeoCollectionEventArgs e);
protected virtual void OnInserted(InsertedGeoCollectionEventArgs e);
protected virtual void OnInserting(InsertingGeoCollectionEventArgs e);
protected virtual void OnRemoved(RemovedGeoCollectionEventArgs e);
protected virtual void OnRemoving(RemovingGeoCollectionEventArgs e);
public InsertedGeoCollectionEventArgs();
public InsertedGeoCollectionEventArgs(Object item);
public InsertingGeoCollectionEventArgs();
public InsertingGeoCollectionEventArgs(Object item);
public RemovedGeoCollectionEventArgs();
public RemovedGeoCollectionEventArgs(Object item);
public RemovingGeoCollectionEventArgs();
public RemovingGeoCollectionEventArgs(Object item);
Release date: 5/1/2010
Introduced Map Suite 4.0. There are many API additions in this release, but no breaking changes. Please see the attached Word document for a complete enumeration of the API changes and additions.
| Assembly | Members Added | Members Removed | Breaking Changes | Percent Churn |
| mapsuitecore (7450) | 525 added | 8 removed | 0 breaking | 7.0% churn |
Changes in mapsuitecore from 3.1.299 (Version 2.0.50727.3603) to 4.0.0.0 (Version 2.0.50727.3603)
Removed |
Added |
DbfReadWriteMode () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.DbfReadWriteMode
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.FeatureCache () |
public class ThinkGeo.MapSuite.Core.GeoCollection`1 () |
--> NONE <-- |
public sealed struct ThinkGeo.MapSuite.Core.GeoColor () |
--> NONE <-- |
ThinkGeo.MapSuite.Core GeoDbf () |
n/a |
public class ThinkGeo.MapSuite.Core.GeoDbf |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.GoogleMapsLayer () |
GoogleMapsTileMode () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.GoogleMapsTileMode
--> NONE <-- |
--> NONE <-- |
ThinkGeo.MapSuite.Core GraticuleAdornmentLayer () |
n/a |
public class ThinkGeo.MapSuite.Core.GraticuleAdornmentLayer |
--> NONE <-- |
ThinkGeo.MapSuite.Core HeatLayer () |
n/a |
public class ThinkGeo.MapSuite.Core.HeatLayer |
--> NONE <-- |
ThinkGeo.MapSuite.Core HeatStyle () |
n/a |
public class ThinkGeo.MapSuite.Core.HeatStyle |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.LineShape () |
--> NONE <-- |
ThinkGeo.MapSuite.Core ManagedProj4Projection () |
n/a |
public class ThinkGeo.MapSuite.Core.ManagedProj4Projection |
--> NONE <-- |
ThinkGeo.MapSuite.Core MapShape () |
n/a |
public class ThinkGeo.MapSuite.Core.MapShape |
--> NONE <-- |
ThinkGeo.MapSuite.Core MapShapeLayer () |
n/a |
public class ThinkGeo.MapSuite.Core.MapShapeLayer |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.MultilineShape () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.MultipleShapeFileFeatureLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.MultipleShapeFileFeatureSource () |
--> NONE <-- |
ThinkGeo.MapSuite.Core PrinterGeoCanvas () |
n/a |
public class ThinkGeo.MapSuite.Core.PrinterGeoCanvas |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.RectangleShape () |
--> NONE <-- |
ThinkGeo.MapSuite.Core RtreeSpatialIndex () |
n/a |
public class ThinkGeo.MapSuite.Core.RtreeSpatialIndex |
--> NONE <-- |
RtreeSpatialIndexDataFormat () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.RtreeSpatialIndexDataFormat
--> NONE <-- |
--> NONE <-- |
RtreeSpatialIndexPageSize () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.RtreeSpatialIndexPageSize
--> NONE <-- |
--> NONE <-- |
RtreeSpatialIndexReadWriteMode () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.RtreeSpatialIndexReadWriteMode
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.ShapeFileFeatureLayer () |
public class ThinkGeo.MapSuite.Core.ShapeFileFeatureSource () |
ThinkGeo.MapSuite.Core SpatialIndex () |
n/a |
public abstract class ThinkGeo.MapSuite.Core.SpatialIndex |
--> NONE <-- |
SplineType () |
public sealed enum ThinkGeo.MapSuite.Core.SplineType
--> NONE <-- |
--> NONE <-- |
ThinkGeo.MapSuite.Core TiledWmsLayer () |
n/a |
public class ThinkGeo.MapSuite.Core.TiledWmsLayer |
--> NONE <-- |
public abstract sealed class ThinkGeo.MapSuite.Core.UnsafeHelper () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.WfsFeatureLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.WfsFeatureSource () |
WfsNamespace () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.WfsNamespace
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.WorldMapKitLayer () |
ThinkGeo.MapSuite.Core YahooMapsLayer () |
n/a |
public class ThinkGeo.MapSuite.Core.YahooMapsLayer |
--> NONE <-- |
YahooMapsPictureFormat () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.YahooMapsPictureFormat
--> NONE <-- |
--> NONE <-- |
Release date: 11/16/2009
18 new APIs have been added (and 10 removed) in this version, but there are no breaking changes. Please see the attached Word document for a complete enumeration of the changes.
| mapsuitecore(6926) | 18 added | 10 removed | 0 breaking | 0.3% churn |
Changes in mapsuitecore from 3.1.273 (Version 2.0.50727.3082) to 3.1.299 (Version 2.0.50727.3082)
Removed |
Added |
public abstract class ThinkGeo.MapSuite.Core.BitmapTileCache () |
public class ThinkGeo.MapSuite.Core.FileBitmapTileCache () |
public class ThinkGeo.MapSuite.Core.FileNativeImageTileCache () |
public class ThinkGeo.MapSuite.Core.GdiPlusGeoCanvas () |
--> NONE <-- |
public abstract class ThinkGeo.MapSuite.Core.GeoCanvas () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.GradientStyle () |
public class ThinkGeo.MapSuite.Core.InMemoryBitmapTileCache () |
public class ThinkGeo.MapSuite.Core.InMemoryFeatureLayer () |
public abstract class ThinkGeo.MapSuite.Core.NativeImageTileCache () |
public sealed struct ThinkGeo.MapSuite.Core.RowColumnRange () |
TileAccessMode () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.TileAccessMode
--> NONE <-- |
--> NONE <-- |
public abstract class ThinkGeo.MapSuite.Core.TileCache () |
Release date: 10/22/2009
Many new APIs have been added (and 12 removed) in this version, but there are no breaking changes. Please see the attached Word document for a complete enumeration of the changes.
| mapsuitecore(6917) | 232 added | 12 removed | 0 breaking | 3.4% churn |
Changes in mapsuitecore from 3.1.182 (Version 2.0.50727.3082) to 3.1.273 (Version 2.0.50727.3082)
Removed |
Added |
public abstract class ThinkGeo.MapSuite.Core.AdornmentLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.BackgroundLayer () |
--> NONE <-- |
ThinkGeo.MapSuite.Core BuildingIndexShapeFileFeatureSourceEventArgs () |
n/a |
public class ThinkGeo.MapSuite.Core.BuildingIndexShapeFileFeatureSourceEventArgs |
--> NONE <-- |
DrawingExceptionMode () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.DrawingExceptionMode
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.EcwRasterLayer () |
--> NONE <-- |
ExecutingSqlStatementType () |
public sealed enum ThinkGeo.MapSuite.Core.ExecutingSqlStatementType
--> NONE <-- |
--> NONE <-- |
public abstract class ThinkGeo.MapSuite.Core.FeatureLayer () |
--> NONE <-- |
public abstract class ThinkGeo.MapSuite.Core.FeatureSource () |
public class ThinkGeo.MapSuite.Core.GdiPlusRasterLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.GeoTiffRasterLayer () |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.GridFeatureLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.GridFeatureSource () |
public class ThinkGeo.MapSuite.Core.GroupLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.IconStyle () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.IconValueStyle () |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.InMemoryFeatureSource () |
public class ThinkGeo.MapSuite.Core.Jpeg2000RasterLayer () |
--> NONE <-- |
public abstract class ThinkGeo.MapSuite.Core.Layer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.LogoAdornmentLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.MrSidRasterLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.MsSql2008FeatureLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.MsSql2008FeatureSource () |
public class ThinkGeo.MapSuite.Core.MultipleFeatureLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.MultipleFeatureSource () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.OracleFeatureLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.OracleFeatureSource () |
public abstract class ThinkGeo.MapSuite.Core.PositionStyle () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.QueryTools () |
--> NONE <-- |
public abstract class ThinkGeo.MapSuite.Core.RasterLayer () |
--> NONE <-- |
ThinkGeo.MapSuite.Core RequestedDataWfsFeatureSourceEventArgs () |
n/a |
public class ThinkGeo.MapSuite.Core.RequestedDataWfsFeatureSourceEventArgs |
--> NONE <-- |
ThinkGeo.MapSuite.Core RequestingDataWfsFeatureSourceEventArgs () |
n/a |
public class ThinkGeo.MapSuite.Core.RequestingDataWfsFeatureSourceEventArgs |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.RestrictionLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.ScaleBarAdornmentLayer () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.ScaleLineAdornmentLayer () |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.TextStyle () |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.WmsRasterLayer () |
--> NONE <-- |
ThinkGeo.MapSuite.Core WorldMapKitLayer () |
n/a |
public class ThinkGeo.MapSuite.Core.WorldMapKitLayer |
--> NONE <-- |
WorldMapKitProjection () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.WorldMapKitProjection
--> NONE <-- |
--> NONE <-- |
Release date: 7/23/2009
Many new APIs have been added (and 3 removed) in this version, but there are no breaking changes. Please see the attached Word document for a complete enumeration of the changes.
| mapsuitecore (6695) | 389 added | 3 removed | 0 breaking | 5.8% churn |
Changes in mapsuitecore from 3.1.124 (Version 2.0.50727.3053) to 3.1.182 (Version 2.0.50727.3053)
Removed |
Added |
ThinkGeo.MapSuite.Core BitmapTile () |
n/a |
public class ThinkGeo.MapSuite.Core.BitmapTile |
--> NONE <-- |
ThinkGeo.MapSuite.Core BitmapTileCache () |
n/a |
public abstract class ThinkGeo.MapSuite.Core.BitmapTileCache |
--> NONE <-- |
ThinkGeo.MapSuite.Core ExecutingSqlStatementMsSql2008FeatureSourceEventArgs () |
n/a |
public class ThinkGeo.MapSuite.Core.ExecutingSqlStatementMsSql2008FeatureSourceEventArgs |
--> NONE <-- |
ThinkGeo.MapSuite.Core ExecutingSqlStatementOracleFeatureSourceEventArgs () |
n/a |
public class ThinkGeo.MapSuite.Core.ExecutingSqlStatementOracleFeatureSourceEventArgs |
--> NONE <-- |
n/a |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.FeatureSourceColumn () |
ThinkGeo.MapSuite.Core FileBitmapTileCache () |
n/a |
public class ThinkGeo.MapSuite.Core.FileBitmapTileCache |
--> NONE <-- |
ThinkGeo.MapSuite.Core FileNativeImageTileCache () |
n/a |
public class ThinkGeo.MapSuite.Core.FileNativeImageTileCache |
--> NONE <-- |
--> NONE <-- |
--> NONE <-- |
--> NONE <-- |
ThinkGeo.MapSuite.Core InMemoryBitmapTileCache () |
n/a |
public class ThinkGeo.MapSuite.Core.InMemoryBitmapTileCache |
--> NONE <-- |
ThinkGeo.MapSuite.Core MapSuiteTileMatrix () |
n/a |
public class ThinkGeo.MapSuite.Core.MapSuiteTileMatrix |
--> NONE <-- |
ThinkGeo.MapSuite.Core Matrix () |
n/a |
public abstract class ThinkGeo.MapSuite.Core.Matrix |
--> NONE <-- |
MatrixReferenceCorner () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.MatrixReferenceCorner
--> NONE <-- |
--> NONE <-- |
--> NONE <-- |
ThinkGeo.MapSuite.Core NativeImageTile () |
n/a |
public class ThinkGeo.MapSuite.Core.NativeImageTile |
--> NONE <-- |
ThinkGeo.MapSuite.Core NativeImageTileCache () |
n/a |
public abstract class ThinkGeo.MapSuite.Core.NativeImageTileCache |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.PointShape () |
--> NONE <-- |
ThinkGeo.MapSuite.Core RowColumnRange () |
n/a |
public sealed struct ThinkGeo.MapSuite.Core.RowColumnRange |
--> NONE <-- |
--> NONE <-- |
--> NONE <-- |
ThinkGeo.MapSuite.Core Tile () |
n/a |
public abstract class ThinkGeo.MapSuite.Core.Tile |
--> NONE <-- |
ThinkGeo.MapSuite.Core TileCache () |
n/a |
public abstract class ThinkGeo.MapSuite.Core.TileCache |
--> NONE <-- |
TileImageFormat () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.TileImageFormat
--> NONE <-- |
--> NONE <-- |
ThinkGeo.MapSuite.Core TileMatrix () |
n/a |
public abstract class ThinkGeo.MapSuite.Core.TileMatrix |
--> NONE <-- |
ThinkGeo.MapSuite.Core TileMatrixCell () |
n/a |
public sealed struct ThinkGeo.MapSuite.Core.TileMatrixCell |
--> NONE <-- |
ThinkGeo.MapSuite.Core TileMatrixSet () |
n/a |
public class ThinkGeo.MapSuite.Core.TileMatrixSet |
--> NONE <-- |
--> NONE <-- |
--> NONE <-- |
ThinkGeo.MapSuite.Core WorldLabelingCandidate () |
n/a |
public class ThinkGeo.MapSuite.Core.WorldLabelingCandidate |
--> NONE <-- |
Release date: 5/26/2009
Many new APIs have been added (and some removed) in this version, but there are no breaking changes. Please see the attached Word document for a complete enumeration of the changes.
| mapsuitecore (6306) | 483 added | 46 removed | 0 breaking | 7.7% churn |
Changes in mapsuitecore from 3.1.16 (Version 2.0.50727.3053) to 3.1.124 (Version 2.0.50727.3053)
Removed |
Added |
public abstract class ThinkGeo.MapSuite.Core.AreaBaseShape () |
--> NONE <-- |
public abstract class ThinkGeo.MapSuite.Core.BaseShape () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.DotDensityStyle () |
--> NONE <-- |
DrawingLevel () |
public sealed enum ThinkGeo.MapSuite.Core.DrawingLevel
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.EcwRasterSource () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.EllipseShape () |
--> NONE <-- |
public abstract sealed class ThinkGeo.MapSuite.Core.ExtentHelper () |
--> NONE <-- |
public sealed struct ThinkGeo.MapSuite.Core.Feature () |
--> NONE <-- |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.GdiPlusRasterSource () |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.GeoTiffRasterSource () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.GoogleMapZoomLevelSet () |
--> NONE <-- |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.Jpeg2000RasterSource () |
--> NONE <-- |
public abstract class ThinkGeo.MapSuite.Core.LineBaseShape () |
--> NONE <-- |
--> NONE <-- |
ThinkGeo.MapSuite.Core LogoAdornmentLayer () |
n/a |
public class ThinkGeo.MapSuite.Core.LogoAdornmentLayer |
--> NONE <-- |
MapResizeMode () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.MapResizeMode
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.MrSidRasterSource () |
--> NONE <-- |
--> NONE <-- |
--> NONE <-- |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.MultipointShape () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.MultipolygonShape () |
--> NONE <-- |
--> NONE <-- |
public abstract class ThinkGeo.MapSuite.Core.PointBaseShape () |
--> NONE <-- |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.PolygonShape () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.Proj4Projection () |
RandomColorType () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.RandomColorType
--> NONE <-- |
--> NONE <-- |
public abstract class ThinkGeo.MapSuite.Core.RasterSource () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.RingShape () |
--> NONE <-- |
--> NONE <-- |
SimplificationType () |
n/a |
public sealed enum ThinkGeo.MapSuite.Core.SimplificationType
--> NONE <-- |
--> NONE <-- |
SplineType () |
n/a |
--> NONE <-- |
--> NONE <-- |
ThinkGeo.MapSuite.Core UnsafeHelper () |
n/a |
public abstract sealed class ThinkGeo.MapSuite.Core.UnsafeHelper |
--> NONE <-- |
public sealed struct ThinkGeo.MapSuite.Core.Vertex () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.VirtualEarthZoomLevelSet () |
--> NONE <-- |
ThinkGeo.MapSuite.Core WfsFeatureLayer () |
n/a |
public class ThinkGeo.MapSuite.Core.WfsFeatureLayer |
--> NONE <-- |
ThinkGeo.MapSuite.Core WfsFeatureSource () |
n/a |
public class ThinkGeo.MapSuite.Core.WfsFeatureSource |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.WmsRasterSource () |
public class ThinkGeo.MapSuite.Core.YahooMapZoomLevelSet () |
--> NONE <-- |
public class ThinkGeo.MapSuite.Core.ZoomLevelSet () |
--> NONE <-- |
Release date: 2/6/2009
Several new APIs have been added in this version, but there are no breaking changes. Please see the attached Word document for a complete enumeration of the changes.
| mapsuitecore (5865) | 36 added | 3 removed | 0 breaking | 0.6% churn |
ServicesEdition API changes since version 3.1.0 (Namespace ThinkGeo.MapSuite.Core)
Class Name |
Removed |
Added |
Is Breaking Change |
ExtentHelper |
[Public | Method] ZoomIntoOffsetPoint () |
NO |
[Public | Method] ZoomOutToOffsetPoint () |
NO |
[Public | Method] ZoomToScale () |
NO |
FeatureSource |
[Public | Method] RefreshColumns () |
NO |
[Protected | property] FeatureSourceColumns |
NO |
ShapeFileFeatureLayer |
[Public | static Method] SaveToProjection () |
NO |
[Public | Method] Validate () |
NO |
ShapeFileFeatureSource |
NO |
NO |
MsSql2008FeatureLayer |
[Constructor] MsSql2008FeatureSource (string connectionString, string tableName, string featureIdColumn, int srid) |
NO |
[Public | Method] BuildIndex () |
NO |
[Public | Method] MakeAllGeometriesValid () |
NO |
NO |
[Public | property] Srid |
NO |
MsSql2008FeatureSource |
NO |
NO |
NO |
NO |
NO |
Release date: 1/22/2009
A large number of API changes and improvements have been introduced in this version of Map Suite Services Edition, including a number of breaking changes, compared to version 3.0.131 (beta 2).
ServicesEdition API changes since version 3.0.131
Class Name |
Removed |
Added |
Comments |
BaseShape |
[Public | Method] GetCrossing() |
NO |
[Protected | Method] GetCrossingCore() |
[Public | Method] FromWellKnownBinary() |
Use LoadFromWellKnownData() instead. |
Yes |
[Protected | Method] FromWellKnownBinaryCore() |
Use LoadFromWellKnownDataCore() instead. |
[Public | Method] FromWellKnownText() |
Yes |
[Protected | Method] FromWellKnownTextCore () |
[Public | Method] GetShapeFromWellKnownBinary() |
Use CreateShapeFromWellKnownData() instead. |
Yes |
[Protected | Method] GetShapeFromWellKnownBinaryCore() |
Use CreateShapeFromWellKnownDataCore() instead. |
[Public | Method] GetShapeFromWellKnownText() |
Yes |
AreaBaseShape |
[Public | Method] Union() |
Add an overload for this method. |
NO |
[Public | Method] ConvexHull() |
Use GetConvexHull() instead. |
Yes |
[Protected|Method] ConvexHullCore() |
Use GetConvexHullCore() instead. |
[Public | Method] Difference() |
Use GetDifference() instead. |
Yes |
[Protected | Method] DifferenceCore() |
Use GetDifferenceCore() instead. |
[Public | Method] Intersection() |
Use GetIntersection() instead. |
Yes |
[Protected | Method] IntersectionCore() |
Use GetIntersectionCore() instead. |
[Public | Method] SymmetricalDifference() |
Use GetSymmetricalDifference() instead. |
Yes |
[Protected | Method] SymmetricalDifferenceCore() |
Use GetSymmetricalDifferenceCore() instead. |
LineShape |
[Constructor] public LineShape(Feature lineFeature) |
This constructor has been Removed. |
Yes |
MultilineShape |
[Public | Method] GetLineOnALine() |
NO |
[Protected | Method] GetLineOnALineCore() |
[Constructor] public MultilineShape(Feature multilineFeature) |
Yes |
[Constructor] public MultilineShape( IEnumerable lineShapeFeatures ) |
Yes |
PolygonShape |
[Constructor]public PolygonShape(Feature polygonFeature) |
Yes |
MultipolygonShape |
[Constructor] public MultipolygonShape(Feature multipolygonFeature) |
Yes |
[Constructor] public MultipolygonShape(IEnumerable polygonFeatures) |
Yes |
PointShape |
[Constructor]public PointShape(Feature pointFeature) |
Yes |
RectangleShape |
[Constructor] public RectangleShape(Feature feature) |
Yes |
RingShape |
[Constructor] public RingShape(Feature polygonFeature) |
Yes |
EllipseShape |
[Constructor] public EllipseShape(Feature feature) |
Yes |
AreaStyles |
[Public | Method] CreateSimpleAreaStyle(GeoColor fillBrushColor, GeoColor outlinePenColor, int outlinePenWidth, LineDashStyle borderStyle) |
NO |
[Public | Method] CreateSimpleAreaStyle(GeoColor fillBrushColor, GeoColor outlinePenColor, int outlinePenWidth, LineDashStyle borderStyle, float xOffsetInPixel, float yOffsetInPixel) |
NO |
[Public | Method] CreateLinearGradientStyle(GeoColor fromColor, GeoColor toColor, float angle, GeoWrapMode wrapMode) |
This method has been Removed. |
Yes |
[Public | Method] CreateLinearGradientStyle(GeoColor fromColor, GeoColor toColor, float angle, GeoWrapMode wrapMode, GeoColor outlinePenColor) |
Yes |
[Public | Method] GetHatchStyle() |
Use CreateHatchStyle() instead. |
Yes |
[Public | Method] GetHueFamilyAreaStyle() |
Use CreateHueFamilyAreaStyle() instead. |
Yes |
[Public | Method] GetHueFamilyLinearGradientAreaStyle() |
Use CreateHueFamilyLinearGradientAreaStyle() instead. |
Yes |
[Public | Method] GetLinearGradientStyle() |
Use CreateLinearGradientStyle() instead. |
Yes |
[Public | Method] GetQualityFamilyAreaStyle() |
Use CreateQualityFamilyAreaStyle() instead. |
Yes |
[Public | Method] GetQualityFamilyLinearGradientAreaStyle() |
Use CreateQualityFamilyLinearGradientAreaStyle() instead. |
Yes |
[Public | Method] GetSimpleAreaStyle() |
Use CreateSimpleAreaStyle() instead. |
Yes |
PointStyles |
[Public | Method] GetCompoundCircleStyle() |
Use CreateCompoundCircleStyle() instead. |
Yes |
[Public | Method] GetSimpleCircleStyle() |
Use CreateSimpleCircleStyle() instead. |
Yes |
[Public | Method] GetSimplePointStyle() |
use CreateSimplePointStyle() instead. |
Yes |
[Public | Method] GetSimpleSquareStyle() |
Use CreateSimpleSquareStyle() instead. |
Yes |
[Public | Method] GetSimpleStarStyle() |
Use CreateSimpleStarStyle() instead. |
Yes |
[Public | Method] GetSimpleTriangleStyle() |
Use CreateSimpleTriangleStyle() instead. |
Yes |
AreaStyle |
[Public | Property] StyleStacks |
Use CustomAreaStyles instead. |
Yes |
HueFamilyAreaStyle |
Yes |
IconStyle |
Yes |
IconValueStyle |
[Public|Property] StyleStacks |
Yes |
LineStyle |
Yes |
PointStyle |
Yes |
PositionStyle |
Yes |
QualityFamilyAreaStyle |
Yes |
TextStyle |
Yes |
BufferCapStyle (Renamed> BufferCapType.) |
Yes |
ClosedImageSourceEventArgs (Renamed> ClosedRasterSourceEventArgs.) |
Yes |
ClosingImageSourceEventArgs (Renamed> ClosingRasterSourceEventArgs) |
Yes |
OpenedImageSourceEventArgs (Renamed> OpenedRasterSourceEventArgs) |
Yes |
OpeningImageSourceEventArgs (Renamed> OpeningRasterSourceEventArgs) |
Yes |
MapEngine |
[Public | Method] Draw(IEnumerable adornmentLayers, GeoImage image, GeographyUnit mapUnit) |
Use Draw(IEnumerable layers, GeoImage image,GeographyUnit mapunit) instead. |
Yes |
[Public | Method] FindDynamicImageLayer() |
Use FindDynamicRasterLayer instead. |
Yes |
[Public | Method] FindDynamicVectorLayer() |
Use FindSDynamicFeatureLayer instead. |
Yes |
[Public | Method] FindStaticImageLayer() |
Use FindStaticFeatureLayer instead. |
Yes |
[Public | Method] FindStaticVectorLayer() |
Yes |
[Public | Method] GetFullExtent() |
This method has been removed. |
Yes |
Method: public static ScreenPointF ToScreenCoordinate(RectangleShape worldExtent, Feature worldPointFeature, float screenWidth, float screenHeight) |
NO |
Layer |
[Public | Method] Draw(GeoCanvas canvas, GeographyUnit mapUnit, Collection<SimpleCandidate> labelsInAllLayers) [Protected | Method] DrawCore(GeoCanvas canvas, GeographyUnit mapUnit, Collection<SimpleCandidate> labelsInAllLayers) |
Use Draw (GeoCanvas canvas, Collection<SimpleCandidate> labelsInAllLayers) instead. Uuse DrawCore (GeoCanvas canvas, Collection<SimpleCandidate> labelsInAllLayers) instead |
ScaleLineAdornmentLayer |
[Constructor] ScaleLineAdornmentLayer(GeographyUnit mapUnit) |
Use ScaleLineAdornmentLayer () instead. |
Yes |
[Constructor] ScaleLineAdornmentLayer(GeographyUnit mapUnit, AdornmentLocation location) |
Use ScaleLineAdornmentLayer(AdornmentLocation location) instead. |
Yes |
[Public | Method] BuildRecordIdColumn() |
NO |
[Public | Method] CloneShapeFileStructure() |
NO |
[Public | Method] GetShapeFileType() |
NO |
[Public | Property] Encoding |
NO |
NO |
NO |
NO |
ImageLayer (Renamed> RasterLayer.) |
[Public | Method] GetSrid() |
Yes |
[Public | Property] HasProjectionText |
NO |
[Public | Method] GetProjectionText() |
NO |
GeoTiffRasterLayer |
This is the new class to support Tiff image. |
NO |
GeoTiffRasterSource |
NO |
EcwImageLayer (Renamed> EcwRasterLayer) |
[Public | Property] PathFileName |
Use PathFilename instead. |
Yes |
EcwImageSource (Renamed> EcwRasterSource) |
Yes |
Yes |
GridFeatureLayer |
[Public | Property] ColumnNumber |
Use NumberOfColumns instead. |
Yes |
Yes |
[Public | Property] RowNumber |
Use NumberOfRows instead. |
Yes |
GridFeatureSource |
Yes |
InMemoryFeatureLayer |
[Public | Property] Dictionary<string, Feature> InternalFeatures |
Change the return type from Dictionary to GeoCollection |
Yes |
Jpeg2000RasterLayer |
This is the new class to support JGPE2000 file |
NO |
Jpeg2000RasterSource |
NO |
MrSidRasterLayer |
Yes |
MrSidRasterSource |
Yes |
GdiPlusRasterSource |
Yes |
Feature |
public Feature(BaseShape baseShape, string id) |
Use Feature(Baseshape baseShape) instead. |
Yes |
public Feature(BaseShape baseShape, string id, IDictionary<string,string> columnValues) |
Use Feature(BaseShape baseShape, IDictionary<string,string> columnValues) instead. |
Yes |
[Public | Method] DeepClone() |
Use CloneDeep() instead. |
Yes |
FeatureSource |
[Public | Method] CombineFieldValue() |
Use CombineFieldValues() instead. |
Yes |
[Public | Method] FromProjection() |
Use ConvertToInternalProjection() instead. |
Yes |
[Public | Method] ToProjection() |
Use ConvertToExternalProjection() instead. |
Yes |
This property has been removed. |
Yes |
[Public | Method] ExecuteNonQuery() [Protected | Method] ExecuteNonQueryCore() |
NO |
[Public | Method] ExecuteQuery() [Protected | Method] ExecuteQueryCore() |
NO |
[Public | Method] ExecuteScalar() [Protected | Method] ExecuteScalarCore() |
NO |
[Public | Method] GetFeaturesByColumnValue() [Protected | Method] GetFeaturesByColumnValueCore() |
NO |
[Public | Property] CanExecuteSqlQuery [Protected | Method] CanExecuteSqlQueryCore |
NO |
GeoCanvas |
[Public | Property] MapUnit |
NO |
GdiPlusGeoCanvas |
[Public | Method] DrawScreenImageWithoutScaling() |
NO |
[Public | Property] CanvasHeight |
Use Height instead. |
Yes |
[Public | Property] CanvasWidth |
Use Width instead. |
Yes |
