This sample demonstrates how to read S57 files (*.000,*.001,*.002…) with Map Suite. The S57 is a numerical map format for nautical maps, it is standard published by the International Hydrographic Organization (IHO), which you can find more information:here. This sample works with Map Suite development branch daily build 7.0.269.0 or later, Map Suite Unmanaged Dependencies Setup 7.0.269.0.msi or later needs to be installed.
NOTE: The current S57 layer doesn't read symbols from S52 file, this part is still under development.
Video Overview
Notes from the developer:
Rotating the map:
Displaying the North Arrow:
On the web site
