map_suite_services_edition_layers_featuresources_samples
Map Suite Services Edition Layers & FeatureSources Samples
GPS EXchange Format FeatureLayer
Maritime S57 FeatureLayer
This sample demonstrates how to read S57 files (*.000,*.001,*.002…) with Map Suite. The S57 is a numerical map format for nautical maps, it is standard published by the International Hydrographic Organization (IHO), which you can find more information:here. This sample works with Map Suite development branch daily build 7.0.269.0 or later, Map Suite Unmanaged Dependencies Setup 7.0.269.0.msi or later needs to be installed.
NOTE: The current S57 layer doesn't read symbols from S52 file, this part is still under development.
Build Custom Shapefile Indexes
CAD FeatureLayer
TAB FeatureLayer With Embed Style
Compass
File Geodatabase
Video Overview
Hook Up External Data to Shapefile
Isolines
Isolines with Kriging
MapShapes
Notes from the developer:
Mini Map Adornment Layer
Multi Geo Raster Layer
Multi Index
North Arrow
Rotating the map:
Displaying the North Arrow:
Oledb Point FeatureSource
Oledb FeatureSource
Scale Bar
SQLInMemoryLayer
Styles with InMemoryFeatureLayer
Swine Flu
On the web site
Watermark Adornment Layer
WMTS Layer
Zedgraph
LEAD Technologies Inc. V1.01
map_suite_services_edition_layers_featuresources_samples.1442566312.txt.gz · Last modified: 2015/09/18 08:51 (external edit)
