This sample demonstrates how to read S57 files (*.000,*.001,*.002…) with Map Suite. The S57 is a numerical map format for nautical maps, it is standard published by the International Hydrographic Organization (IHO), which you can find more information:here. This sample works with Map Suite development branch daily build 7.0.269.0 or later, Map Suite Unmanaged Dependencies Setup 7.0.269.0.msi or later needs to be installed.
NOTE: The current S57 layer doesn't read symbols from S52 file, this part is still under development.
Video Overview
Notes from the developer:
Rotating the map:
Displaying the North Arrow:
, which only reads the data for the given extent you are working in (much more efficient for larger datasets).
On the web site
With Map Suite, you have the whole ZedGraph API available with an easy interface to add the graphs to the map. For this project, in addition to the MapSuiteCore.dll, you will also need the ZedGraph.dll and ZedGraphStyleExtension.dll references. We will have several projects showing how to integrate other types of charts to your map.
