map_suite_services_edition_layers_featuresources_samples
Map Suite Services Edition Layers & FeatureSources Samples
GPS EXchange Format FeatureLayer
Maritime S57 FeatureLayer
This sample demonstrates how to read S57 files (*.000,*.001,*.002…) with Map Suite. The S57 is a numerical map format for nautical maps, it is standard published by the International Hydrographic Organization (IHO), which you can find more information:here. This sample works with Map Suite development branch daily build 7.0.269.0 or later, Map Suite Unmanaged Dependencies Setup 7.0.269.0.msi or later needs to be installed.
NOTE: The current S57 layer doesn't read symbols from S52 file, this part is still under development.
Build Custom Shapefile Indexes
CAD FeatureLayer
TAB FeatureLayer With Embed Style
Compass
Hook Up External Data to Shapefile
Isolines
Isolines with Kriging
MapShapes
Notes from the developer:
Mini Map Adornment Layer
Multi Geo Raster Layer
Multi Index
North Arrow
Rotating the map:
Displaying the North Arrow:
Oledb Point FeatureSource
Oledb FeatureSource
Scale Bar
SQLInMemoryLayer
, which only reads the data for the given extent you are working in (much more efficient for larger datasets).
Styles with InMemoryFeatureLayer
Swine Flu
On the web site
Watermark Adornment Layer
WMTS Layer
Zedgraph
LEAD Technologies Inc. V1.01
With Map Suite, you have the whole ZedGraph API available with an easy interface to add the graphs to the map. For this project, in addition to the MapSuiteCore.dll, you will also need the ZedGraph.dll and ZedGraphStyleExtension.dll references. We will have several projects showing how to integrate other types of charts to your map.
map_suite_services_edition_layers_featuresources_samples.1442555288.txt.gz · Last modified: 2015/09/18 05:48 by admin
