map_suite_services_edition_all_samples
Table of Contents
Map Suite Services Edition All Samples
Map Suite Services Edition How Do I Sample
The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples. Available in both C# and VB.NET, these samples are designed to hit all the highlights of Map Suite, from simply adding a layer to a map to performing spatial queries and applying a thematic style. Consider this collection your “encyclopedia” of all the Map Suite basics and a great starting place for new users.
Decimal Degrees Formatting
LEAD Technologies Inc. V1.01
Label to Show Location
Labeling Based On Columns
Multi Column Labeling
ENC Viewer for displaying S-57 (*.000) File
GPS EXchange Format FeatureLayer
Maritime S57 FeatureLayer
Build Custom Shapefile Indexes
CAD FeatureLayer
TAB FeatureLayer With Embed Style
Compass
File Geodatabase
Video Overview
Hook Up External Data to Shapefile
Isolines
Isolines with Kriging
MapShapes
Notes from the developer:
Mini Map Adornment Layer
Multi Geo Raster Layer
Multi Index
North Arrow
Rotating the map:
Displaying the North Arrow:
Oledb Point FeatureSource
Oledb FeatureSource
Scale Bar
SQLInMemoryLayer
Styles with InMemoryFeatureLayer
Swine Flu
On the web site
Watermark Adornment Layer
WMTS Layer
Zedgraph
Map Suite Explorer (ServiceEdition)
Tile Cache Generator
<div sample_otherlinks> [
screenshot
Datum Transformation
Geodetic to State Plane
Geodetic to UTM on the fly
GeoRaster Projection
Great Circle on Pacific Rim
Measurements Decimal Degrees
Pacific Rim
Polygon across Meridian
Projection Distortion
Projection in Feet
Routing with Projections
Save To Projection
Street Intersection
World Coordinates
Clipping
Clipping On Point Layer
Convex Hull
Correcting Nodes
Create Polygon Programatically
Dissolve on Shapefile
Draw a Pie shape
Dynamic Segmentation
Get Feature Clicked On With Projection
Identify Point with Icon
Inner Ring Containment
Intersecting Multi Polygon
Intersecting Two Layers
Merge Line Layers
Merge Point Layers
Merging Layers
Multi Ring Buffering
Negative Buffering
Offset Point at Right Angle
Register Shape
Remove LineShape
Spatial Join
Split Polygon
Split Polygon Based On Grid
From the Performance Guide:
Split Polygon Dynamically into Grids based on the Area
Sweep Angle
Splitting Polygons with a Line
Adjusted Scaling Image Style
Cached Value Style
ClusterPointStyle
Displaying One-Way Streets
Doughnut Point Style
Feature Centric Style
Flashing Point Style
Hybrid TextStyle
Image Style
Isolines
Rotate Icon
Routing Styles
Scaling Image Style
Scaling TextStyle
Scaling TextStyle for Polygon
Sized Point Style
Start End LineStyle
TextStyle for Multi Line
Time Based Point Style
Time Line
ValueStyle with Countries
WordWrapped TextStyle
World Sized Image Style
World Sized Text Style
Label Point with Circle Symbol and Mask Description
Centering and Rotating
Chemical Plume
Filter Radar Image
Rotated Image Style
Snap GPS to Street
Custom Zoom Levels
Zoom to Full extent
Map Suite License File Generator
map_suite_services_edition_all_samples.1442912563.txt.gz · Last modified: 2015/09/22 09:02 by admin
