map_suite_server_for_routing_all_samples
Routing Samples
Routing Sample for WinForms
[Sample Data Download](http://wiki.thinkgeo.com/wiki/_media/routing/routing_howdoi_samples_data.zip)
Screenshot
View this sample on Github
Routing Data Explorer Sample for Wpf
How to use this tool:
1. Load rtg data:  Click menu “File→Load” browse to a rtg file. You also require a shapefile for the routing source file in the same folder, otherwise it display message “Could not find shp file in the same folder where you seleted”. 2. Start routing:
Screenshot
Routing Sample For iOS
The Map Suite Routing “How Do I?” solution offers a series of useful how-to examples for using the Map Suite Routing extension. The bundled solution comes with a small set of routable street data from Dallas, TX and demonstrates simple routing, avoiding specific areas, getting turn-by-turn directions, optimizing for the Traveling Salesman Problem, and much more. Full source code is included in both C# and VB.NET languages; simply select your preferred language to download the associated solution.
Please refer to [Wiki](http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_iOS) for the details.
Screenshot
RoutingSample For Android
Screenshot
RoutingSample-ForWebForms
[Sample Data Download](http://wiki.thinkgeo.com/wiki/_media/routing/routingdata_3857.zip)
Screenshot
The Map Suite Routing Index Generator is a utility that will allow you to generate routing index files (“.rtg” and “.rtx”) from World Streets .sqlite database. These routing index files will be used by the Map Suite Routing Extension in order to calculate routes and driving directions. This utility allows you to specify things that one-way road information, as well as configuring the road speed and type of routes you would like to calculate. It is easily extendable to allow you to add code to deal with other routing situations.
Screenshot
Adjacent Road Search Sample for Wpf
This WPF project shows how to get a route between two adjacent roads, even if they don't intersect within an allowable tolerance.
It’s based on Map Suite Geometry Topology module and does not require the Map Suite Routing Extension.
Screenshot
Elevation Grade Of Line Sample for Wpf
In this sample, we show how you can use Map Suite [Elevation SDK](https://thinkgeo.com/gisserver#feature) to get the elevation values of a specific line for your .NET application. It allows you to customize your query to get data as detailed as you need it to be. Draw elevation profiles for your hiking or biking trip, contral the granularity of the response, sample elevation values at controllable intervals along a route should be shown up.
Screenshot
GPS Exchange Format Feature Layer Sample for Wpf
Screenshot
map_suite_server_for_routing_all_samples.txt · Last modified: 2020/03/08 06:46 (external edit)
