map_suite_routing_styles_samples
Map Suite Routing Styles Samples
Displaying One-Way Streets
LEAD Technologies Inc. V1.01
Routing Styles
Smooth Transparent Route
Smart Brute Force TSP Routing Algorithm
In this Routing sample project, we are looking at the Routing Extension of Map Suite. Here we created a BruteForceRoutingEngine class to deal with complicated TSP (Traveling Salesman Problem) with fixed start and end points, you can get more details at https://en.wikipedia.org/wiki/Travelling_salesman_problem . Compared with built-in TSP algorithm in Routing Extension, it may be a bit slower, but show a better visit sequence and more reasonable route.
map_suite_routing_styles_samples.1473849558.txt.gz · Last modified: 2016/09/14 10:39 by tgwikiupdate
