In this Routing sample project, we are looking at the Routing Extension of Map Suite. Here we created a BruteForceRoutingEngine class to deal with complicated TSP (Traveling Salesman Problem) with fixed start and end points, you can get more details at https://en.wikipedia.org/wiki/Travelling_salesman_problem . Compared with built-in TSP algorithm in Routing Extension, it may be a bit slower, but show a better visit sequence and more reasonable route.
