map_suite_routing_styles_samples
Map Suite Routing Styles Samples
Displaying One-Way Streets
Screenshot width=78Sample width=66Product Description
map_suite_routing_sample_display_one_way_streets.jpg View Source
C# Download
Need it in another language?
Services \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the Discussion Forum Post “Drawing one-way streets in the map”, we have a question on how to display an arrow on a street that is one way as Google Map does. In this project, we show the solution by creating a LineStyle specifically for that purpose. We take the shapefile “AustinWithOneWayRoad.shp” from the sample app “Route On One-Way Roads” of Map Suite Routing Extension to display the arrow according to the traffic direction on the one-way streets
Routing Styles
map_suite_routing_sample_routing_styles.jpg View Source
C# Download
Services \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ The API for the Routing extension product provides a class RoutingLayer. RoutingLayer is basically a convenient layer to have the features for routing being displayed in a default way. You can add the start, end point, the routes and it is going to display that nicely for you without much work on your side. While this is convenient, you may be in the situation when you want more control on the styles and have the whole flexibility that an InMemoryFeatureLayer gives you. In this project, we show how to display in InMemoryFeaturesLayers the start and end points, as well as the resulting route using the full power of InMemoryFeatureLayer such as zoom levels and custom styles.
Smooth Transparent Route
map_suite_routing_sample_smooth_transparent_route.jpg View Source
C# Download
Desktop \\ \\ Applies To: Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ In the Routing extension, the API GetRoute of the RoutingEngine returns a MultilineShape made of a collection of LineShape. By default, the MultilineShape has LineShapes for each two vertex line segment. The result in the displaying of the route using some transparency is a route that looks dotted and irregular. In this project, we show the trick to get one continuous LineShape which will show as smooth and regular. We recognized that the default result is not the most adequate in most cases and we will correct that for the next major release of the Routing extension. In the meantime, you can use that project to get the result that you want to display your routes.
map_suite_routing_styles_samples.1441944070.txt.gz · Last modified: 2015/09/11 04:01 by admin
