View Source |
The Map Suite Routing Index Generator is a new utility that lets you generate the routing index files (“.rtg” and “.rtx”) for your ESRI shape file, they will be used by Map Suite Routing Extension to calculate routes and driving directions. This utility allows you to specify the one-way information, configure the road speed and the type of routes you would like to calculate. It’s easy for you to add the code for dealing other road situations.
View Source |
