View Source |
In today’s project, we are looking at the Routing extension of Map Suite. As a reinforcement of what we learned in the samples of “How Do I”, we show how to find the shortest route between the start and the end point. In addition to that, we show how to use the MultiLineShape from the result of the GetRoute function to do a spatial query to get the points of interests (POI) on the route.
For this sample, you would need a reference of either the full or evaluation of MapSuiteCore.dll and MapSuiteRouting.dll.
View Source |
In the project “POI on route”, we learned how to get the points of interests (POI) on the route within a certain buffer distance. In today’s project, we are going to go a step further and we show the technique for finding the POIs according to what side of the route they are located. For example, in the delivery industry, it is far more efficient to deliver to stops on the right side of the road when driving on the right side of the road.
View Source |
In today’s project, we will see how to better leverage the GetRoute function of the RoutingEngine by doing some spatial query. The GetRoute function allows you to pass two PointShapes for the start and end points of the route to build. If a PointShape is not on a line segment of the routable street data, the closet point on the closest segment will be used regardless of how far the PointShape is. Using the Spatial Query function, GetFeaturesWithinDistanceOf, we check if the PointShapes passed as start and end points are within some tolerance before proceeding with building the route.
For this project, you will need MapSuiteCore.dll and MapSuiteRouting.dll references.
View Source |
View Source |
In the sample apps “How Do I” of the Routing product, we have a sample that shows how the route is constructed on a one way street. Today’s project is meant to complement by showing how to set selected streets to be one way and in the desired direction. From this sample, you can create your own utility to handle your data for routing purposes.
