MapSuite contains many predefined styles, including the WorldMapKit Predifined Styles outlined below.
This code snippet will retrieve all of the AreaStyles returned by the methods in the WorldMapKitAreaStyles class using Reflection, and saves them as images.
MethodInfo[] methodInfos = typeof(WorldMapKitAreaStyles).GetMethods(BindingFlags.Public | BindingFlags.Static);
PropertyInfo[] propertyInfos;
propertyInfos = typeof(WorldMapKitAreaStyles).GetProperties(BindingFlags.Public |
AreaStyle areaStyle;
foreach (MethodInfo methodInfo in methodInfos)
ParameterInfo[] parameterInfos = methodInfo.GetParameters();
if (parameterInfos.Length > 1)
int parmLength = parameterInfos.Length;
List<object> parmList = new List<object>();
foreach (ParameterInfo parameterInfo in parameterInfos)
if (parameterInfo.ParameterType == typeof(Single) || parameterInfo.ParameterType == typeof(int) || parameterInfo.ParameterType == typeof(float))
parmList.Add(25);
else if (parameterInfo.ParameterType == typeof(String))
parmList.Add("Test");
object[] parms = new object[] { };
if (parmList.Count > 0)
parms = parmList.ToArray();
areaStyle = (AreaStyle)methodInfo.Invoke(null, parms);
Bitmap bitmap = new Bitmap(128, 128);
GdiPlusGeoCanvas gdiPlusGeoCanvas = new GdiPlusGeoCanvas();
gdiPlusGeoCanvas.BeginDrawing(bitmap, new RectangleShape(-180, 90, 180, -90), GeographyUnit.DecimalDegree);
areaStyle.DrawSample(gdiPlusGeoCanvas);
gdiPlusGeoCanvas.EndDrawing();
bitmap.Save(@"c:\temp\AreaStyles\" + methodInfo.Name + ".png", ImageFormat.Png);
The previous code can modified to produce these images, by changing WorldMapKitAreaStyles to WorldMapKitLineStyles, and AreaStyle to LineStyle.
And by changing WorldMapKitAreaStyles to WorldMapKitTextStyles and AreaStyle to TextStyle, you can produce the images below.
Map Suite integrates 186 well points styles in the component. Here the following code will print out each of those style to a standalone bitmap.
for (int i = 1; i <= 186; i++)
WellPointStyle pointStyle = new WellPointStyle(i, GeoBrushes.Black, GeoPens.Black, 30);
pointStyle.DrawSample(gdiPlusGeoCanvas);
bitmap.Save(@"C:\WellStyles\Number_" + i.ToString() + ".png", ImageFormat.Png);
