map_suite_portable_data_format_guide
Map Suite Portable Data Format Guide
Vector Formats
Format Support Type Map Suite Version
ShapeFile1) Read/write 8.0
MapInfo TAB Read/write 8.0
ThinkGeo TinyGeo Read/write 8.0
KML (Keyhole Markup Language) Read/write 8.0
GPX (GPs eXchange format) Read 8.0
ESRI Grid (.grd) Read 8.0
Raster Formats
GeoTIFF Read 3.0
BMP Read/Write 3.0
PNG Read/Write 3.0
GIF Read/Write 3.0
JPG Read/Write 3.0
TIFF Read/Write 3.0
Web Based Datasets
Format/Provider Map Suite Version Description
World Map Kit Online 3.0 ThinkGeo's basemap based on Open Street Map Data that is displayed in most of the sample applications. You can check out what the maps look like at http://maps.thinkgeo.com
WMS (Web Map Service) 6.0 WMS is a open standard set by the OGC to consume maps over the web.
WFS (Web Feature Service) 6.0 WFS is a open standard set by the OGC.
Google Maps 2) 3.0 Google Maps
Bing Maps 3) 3.0 Bing Maps
NOAA Radar 8.0 NEXRAD Radar updated every 15 minutes covering most of the United States.
NOAA Weather Watches & Warnings 8.0 Current weather watches and warnings covering the United States.
NOAA Weather Stations 8.0 Current temperatures and other weather information from NOAA weather stations around the United States.
1) All versions of Map Suite support ShapeFile DBFs in the standard dBASE III format. Additionally, since Map Suite 8.0, DBFs in Visual FoxPro format are also supported.
2) *Use of Google Maps within a Map Suite developer SDK requires a Google Maps API For Business license and is subject to Google's licensing terms. For more information, please visit: https://developers.google.com/maps/licensing
3) *Use of Bing Maps within a Map Suite developer SDK requires a Bing Maps license and is subject to Microsoft's licensing terms. For more information, please visit: http://www.microsoft.com/maps/Licensing/licensing.aspx
map_suite_portable_data_format_guide.1442285351.txt.gz · Last modified: 2015/09/15 02:49 by admin
