map_suite_mvc_edition_quick_start_guide
Map Suite MVC Edition Quick Start Guide
The Map Suite MVC Edition illustrated QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This edition of the QuickStart Guide supports Map Suite MVC Edition 9.0.0.0 and higher, and will show you how to create an ASP.NET MVC application using Map Suite MVC Edition.
If you want to build a Webforms application using the standard Map Suite Web Edition product, please see the Web Edition QuickStart Guide instead.
Welcome to Map Suite™ MVC Edition from ThinkGeo, a full-featured mapping control that makes it easy for any Microsoft .NET developer to add mapping functionality to a Microsoft .NET application quickly and efficiently. Using the intuitive object model, even developers inexperienced in Geographic Information Systems (GIS) can have fully functional maps working in minutes.
Before we get started, make sure that you have installed the ThinkGeo Product Center and that you have either started an evaluation or activated a full license of Map Suite MVC Edition. By default, this will install the Map Suite MVC Edition 9.0 assemblies to C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite MVC.
Download the Sample
Setting up the Environment
Let's start with a new ASP.NET MVC 4 web application in Visual Studio.NET 2010 IDE and call it “HelloWorld” (see Figure 1). Set the Templates to “.NET Framework 4.0” for the project. And in next wizard page select the “Empty” template; this means that your sample project won't have any built-in pages or functionalities, such as forms authentication. Finally, select “Razor” as the view engine. (NOTE: Map Suite MVC Edition supports both the Razor and ASPX view engines. In this guide we are just using Razor as an example.)
If you are using Visual Studio.NET 2010, you need to install VS2010 SP1, and then create an ASP.NET MVC Web Application.
This Quick Start Guide uses an ASP.NET MVC 4 web application as an example, so you will need to have the ASP.NET MVC framework installed in order to follow along. The MVC 4 framework can be downloaded from ASP.NET MVC 4 Tools Update.
Figure 1. Creating a new project in Visual Studio.NET 2010 IDE.
Adding Map Suite MVC Edition to your MVC Application
We need to add two Map Suite files, “MvcEdition.dll” and “MapSuiteCore.dll”, to the reference. Right-click on “References” in Solution Explorer and select “Add Reference…”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite MVC\Current Version\Managed Assemblies folder and select both “MvcEdition.dll” and “MapSuiteCore.dll”.
Note: Although it is not a ThinkGeo assembly, you also need to add “WindowsBase.dll” to the references. WindowsBase can be found on the .NET tab of the Add Reference dialog. If you don't do this, you will get the following error when you compile the project: “The type 'System.Collections.Specialized.INotifyCollectionChanged' is defined in an assembly that is not referenced. You must add a reference to assembly 'WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'.”
Now that we have the required DLLs referenced, we are ready to add the code needed to display a map.
Creating the Controller and Required View Page
In Solution Explorer, right-click on the “Controller” folder, then navigate to “Add” and select “Controller…” to add a new controller page named “HomeController”. It should look like the screenshot below:
Now move your mouse pointer over the code “return View()” and right-click to add the responding view page. Keep all of the default settings as shown below:
Map Suite MVC "Hello World" Sample
In this section, you'll use Map Suite MVC Edition to display a map that uses your own data.
To begin, in the View page, let's write a few lines of code that will display a simple map. Next, we'll have a look at the data and the important objects that we will use.
Display a Simple map
In creating our “Hello World” sample application, our first step is to set a reference to the Map Suite Core and Map Suite MvcEdition workspaces at the very top of the View page, as we will use many classes within both of these. We do this so that we do not have to use the fully qualified name of the Map Suite classes throughout our code. Set the reference like this:
@using ThinkGeo.MapSuite.MvcEdition
@using ThinkGeo.MapSuite.Core
Then, just add the following code to Index.cshtml:
<div>
        Html.ThinkGeo().Map("Map1", 600, 500)
        .MapBackground(new BackgroundLayer(new GeoSolidBrush(GeoColor.FromHtml("#E5E3DF"))))
        .CurrentExtent(-131.22, 55.05, -54.03, 16.91)
        .MapUnit(GeographyUnit.DecimalDegree)
        .CustomOverlays(overlays => overlays.WorldMapKitWmsWebOverlay())
        .Render();
</div>
Then, add the following xml block into the web.config file.
 <runtime>
    <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
      <dependentAssembly>
        <assemblyIdentity name="System.Web.Mvc" publicKeyToken="31bf3856ad364e35" />
        <bindingRedirect oldVersion="1.0.0.0-3.0.0.0" newVersion="4.0.0.0" />
      </dependentAssembly>
    </assemblyBinding>
  </runtime>
Now press F5 to build and run your application. It should look like this:
Shapefiles
Map Suite MVC Edition supports multiple kinds of data sources, such as Shapefiles, TAB files, SQL Server 2008, PostgreSQL, Oracle, etc. Here we will provide an introduction to Shapefiles, which we will use in the next section of this Quick Start Guide.
ShapeFileFeatureLayers
Map
A Map object is the highest level object that encompasses layers and some other objects. For now, you can think of a Map as a set of layers, which can render each layer and present you with a map based on actions performed, such as zooming in and out, or panning across the surface to view another part of the map.
Styles
Shapefiles provide the data, but Styles are the way you color and draw them. You can specify the color of the country, the width of a road, the shape (triangle, circle, cross etc) of a point, and so on.
Map Suite has many preset Styles built in, including predefined Styles for roads, rivers, cities, countries, and more. This makes it easier to create great looking maps without a lot of hassle.
PresetZoomLevels
PresetZoomLevels has a very useful property called ZoomLevel.ApplyUntilZoomLevel, which you can very easily use to extend your ZoomLevels. Let's say you want a particular Style to be visible at ZoomLevel03 through ZoomLevel10. To make that work, we can simply code as follows:
worldLayer.ZoomLevelSet.ZoomLevel03.DefaultAreaStyle = AreaStyles.Country1;
worldLayer.ZoomLevelSet.ZoomLevel03.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level10;
(NOTE: Map Suite MVC Edition provides two places where we can add our code for defining the ShapeFileFeatureLayer. One is in the action of the controller, and the other is in the View page. Here we will use the latter for our example. For examples of the former, please see the sample applications that were installed along with your copy of Map Suite MVC Edition.)
Now let's look at the code needed to bring this concept to fruition. For this example, we'll use a Shapefile containing data of the entire world. We have one such Shapefile available to us:
  • The borders of every country in the world (cntry02.shp)
Our next step is to define and add our Shapefile layers to the map. All of our sample code is placed in the view page “Index.cshtml”.
    @{Html.ThinkGeo().Map("Map1", 600, 500)
        .StaticOverlay(overlay =>
            ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"C:\Program Files (x86)\ThinkGeo\Map Suite Mvc Evaluation Edition 9.0\HowDoISamples\CSharp HowDoISamples Razor\App_Data\cntry02.shp");
            // Set the worldLayer to use a preset Style. Since AreaStyles.Country1 has YellowGreen background and Black border, our worldLayer will have the same render style.
            // We need to add the worldLayer to the map's Static Overlay.
            overlay.Layer(worldLayer);
        .Render();
If you compile and run what you have now, your map should look like the screenshot below. (See Figure 4).
Figure 4. A simple map of World.
NOTE: It is important that the MapUnit property of a Map object be set using the GeographyUnit enumeration. This is because Shapefiles only store binary vector coordinates, which can be in decimal degrees, feet, meters, or numerous other unit systems, and our map has no way to know what the Shapefile's unit of measurement is until we tell it. This information is normally found somewhere in the Shapefile's documentation or within its supplemental data file as discussed in the section on Shapefiles.
  1. The borders of every country in the world (“cntry02.shp”)
  2. The capitals of the world countries (“capital.shp”)
Change the code in your View page following the example below. You don't need to make any changes to the controller.
            // World layer
            ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(Server.MapPath("~/App_Data/cntry02.shp"));
            // Capital layer
            ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(Server.MapPath("~/App_Data/capital.shp"));
            overlay.Layer(capitalLayer);
        .Render();
The result is as follows (Figure 5):
Figure 5. Europe map with 2 layers.
How to Use the TextStyle
The TextStyle is used to label items on map. As every Shapefile has a related .dbf file, which includes descriptions for each record, the most common way to use the TextStyle is for labeling features. For example, the Shapefile containing capitals of the world has a corresponding .dbf file that contains the field “CITY_NAME”. We can use this field to label the cities on our map.
        .MapBackground(new BackgroundLayer(new GeoSolidBrush(GeoColor.GeographicColors.ShallowOcean)))
            // All of this code can alternatively be placed in the controller.
            // Please reference the sample applications that came with your copy of Map Suite MVC Edition for detail.
            // World layer
            // Capital cities layer
            // Label layer
            ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(Server.MapPath("~/App_Data/capital.shp"));
            // We'll use a preset TextStyle. Here we pass in the "CITY_NAME", which is the name of the field we want to label on the map.
            // Since the map is drawn with tiles, the label needs to draw on the margin to make sure the text is complete after joining the tiles together.
            // Change the number below (to 0, for example) and you will be able to see what we mean.
            overlay.Layer(capitalLabelLayer);
        .Render();
Figure 6. Europe map with TextStyle.
        .CurrentExtent(5, 78, 30, 26)
            // World layer
            // Capital layer
            // The Style we set here is applied from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, this particular style will not be visible anymore.
            // The Style we set here is applied from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, this particular style will not be visible anymore.
            // Label layer
            // We can customize our own TextStyle. Here we pass in the font, the size, the style and the color.
            // The TextStyle we set here is applied from ZoomLevel01 to ZoomLevel05.
            // The TextStyle we set here is applied from ZoomLevel06 to ZoomLevel20.
        .Render();
Can you imagine what the map will look like now? Figure 7 below is the result. At first it looks the same as it did in Figure 6. Now zoom in, and watch the map change to resemble Figure 8 as you do.
Figure 7. European cities with two ZoomLevels, before zooming in.
Figure 8. European cities with two ZoomLevels, after zooming in.
Perform an AJAX HTTP request to the Action of the Controller
Map Suite MVC Edition provides a large number of client APIs that allow us to easily operate the map on client side, just as we have done on the server side in the above example code. For complete details on the available client APIs, please reference the “JavaScript API Documentation” link in your Map Suite MVC Edition program group, or see this page.
Here we will show you how to perform an AJAX request to update the DynamicOverlay of the map according to the different parameters passed in from the client.
Client APIs used
ajaxCallAction: function (controller, action, params, callback)
  • controller {String} - The name of the controller
  • action {String} - The name of the action
  • params {object} - The parameters in JSON format
  • callback {function} - The callback function which is used to process the data sent from the server
We will need to access the parameters passed from here in the action, and apply the MapActionFilterAttribute to the specified action of the controller.
The code in your View page should look like this:
[JavaScript]
   function UpdateDynamicOverlay(layerName) {
        Map1.ajaxCallAction("Home", "UpdateOverlay", { layer: layerName }, function (result) {
            // Refresh overlay after callback
            Map1.redrawLayer("ShapeOverlay");
[JavaScript]
<div>
            overlays.WorldMapKitWmsWebOverlay();
            overlays.LayerOverlay("ShapeOverlay", false, TileType.MultipleTile);
        .Render();
</div>
<div>
    <input id="chKAddUs" name="group1" type="radio" value="Show US States" onclick="UpdateDynamicOverlay('US')" />
    Show US States
    <br />
    <input id="chKAddCounty" name="group1" type="radio" value="Show US Counties" onclick="UpdateDynamicOverlay('City')" />
    Show US Cities
    <br />
</div>
Now copy and paste the code below about the accessed action into your “HomeController” page:
        // Here we set the MapActionFilterAttribute, for which two input parameters are required.
        [MapActionFilter]
        public void UpdateOverlay(Map map, GeoCollection<object> args)
            var layerName = args[["layer"]].ToString();
            LayerOverlay overlay = map.CustomOverlays[["ShapeOverlay"]] as LayerOverlay;
            overlay.Layers.Clear();
            if (layerName.ToLowerInvariant() == "us")
                // States layer
                ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(Server.MapPath("~/App_Data/STATES.SHP"));
                worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.State1;
                overlay.Layers.Add(worldLayer);
            else
                // Cities layer
                ShapeFileFeatureLayer countyLayer = new ShapeFileFeatureLayer(Server.MapPath("~/App_Data/cities_a.shp"));
                countyLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital3;
                countyLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.Capital3("AREANAME");
                countyLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                overlay.Layers.Add(countyLayer);
You can click the checkboxes for “Show US States” or “Show US Cities” to load different layers to the map. For example, if you check the “Show US States” box, the map should look like this:
Summary
You now know the basics of using Map Suite MVC Edition and are able to start adding this functionality into your own applications. Let's recap what we have learned about the object relationships and how the pieces of Map Suite work together:
  1. It is of the utmost importance that the unit of measurement (feet, meters, decimal degrees, etc.) be set properly for the map, based on the requirements of your data.
  2. Shapefiles (and other data sources like Oracle, Postgre, SQL 2008, etc.) provide the data used by Map Suite to render a map.
  3. A Map is the basic class that contains all of the other objects that are used to define how the map will be rendered.
  4. A Map has one-to-many Layers. A Layer contains the data (from shapefile or other data sources) for drawing.
  5. A layer can have one-to-many ZoomLevels. ZoomLevels help to define ranges of when a layer should be shown or hidden.
  6. Compared to Map Suite Web Edition, MVC Edition provides many more client APIs which are used to operate the map and easily communicate with the server side.
Download Sample Code From This Exercise (12.4 MB)
map_suite_mvc_edition_quick_start_guide.1442459152.txt.gz · Last modified: 2015/09/17 03:05 (external edit)
