View Source |
C# Download |
Need it in another language? |
Web
Applies To: MVC \Web
Based on a discussion forum request, today's web project shows you how to add sub menus to ContextMenu. This is a built-in function in all of the most recent daily builds of Map Suite, which you can download from the ThinkGeo Customer Portal. This project also demonstrates how to enable the ContextMenu's auto wrap feature when you click on the edges of the map.
View Source |
C# Download |
Web
View Source |
C# Download |
Desktop
View Source |
C# Download |
Web
Applies To: MVC \ Web
In this web-based project, we show you how to do a two-way interaction between the features in an InMemoryFeatureLayer and their information in GridView. If you click on a point on the map, you will see the corresponding item highlighted in the GridView. Or vice-versa; you can click on an item in the GridView and you will see its feature highlighted on the map.
View Source |
C# Download |
Desktop
View Source |
C# Download |
Desktop
For more details including a list of topology cases that you can test, see this article or watch the [[http://youtu.be/IuLGTRsVtQc|video overview]]
View Source |
C# Download |
Desktop
