map_suite_mvc_edition_interactiveoverlays_samples
Map Suite MVC Edition InteractiveOverlays Samples
Custom Track Line
View Source | C# Download | Need it in another language? | Desktop |
Applies To: MVC Desktop Web Silverlight Services Wpf
Custom Track Polygon
Dragged Point Style
View Source |C# Download | Need it in another language? | Desktop |
Dynamic Info On TrackShapes
Applies To: MVC Desktop Web Silverlight Wpf This project is for the Desktop version and it shows how to handle TrackOverlay to obtain dynamic information about the shape being tracked.
EditOverlay Styles
View Source | C# Download | Need it in another language? | Web |
Select with Track Shape
Applies To: MVC\Desktop\Web\Silverlight\Wpf
In today’s Desktop project, we combine the skills we learned in the samples “Spatial Query A Feature Layer” and “Track And Edit Shapes”. You can see how we use the event TrackEnded to get the RectangleShape from the tracked shape of TrackOverlay to do the spatial query. In this example, we use a Rectangle but you could also very easily use another shape such as Polygon, Circle, etc. |
Tracked Shapes to WKT
Vertex Tolerance
map_suite_mvc_edition_interactiveoverlays_samples.1441103207.txt.gz · Last modified: 2015/09/01 10:26 by admin
