View Source |
C# Download |
Need it in another language? |
Desktop |
Applies To: MVC Desktop Web Silverlight Services Wpf
View Source |
C# Download |
Desktop |
View Source |C# Download |
Desktop |
View Source |
C# Download |
Desktop |
Applies To: MVC Desktop Web Silverlight Wpf
View Source |
C# Download |
Web |
Desktop |
Applies To: MVC\Desktop\Web\Silverlight\Wpf
In today’s Desktop project, we combine the skills we learned in the samples “Spatial Query A Feature Layer” and “Track And Edit Shapes”. You can see how we use the event TrackEnded to get the RectangleShape from the tracked shape of TrackOverlay to do the spatial query. In this example, we use a Rectangle but you could also very easily use another shape such as Polygon, Circle, etc. |
View Source |
C# Download |
Desktop |
View Source |
C# Download |
Desktop |
