View Source |
C# Download |
Need it in another language? |
Desktop |
Applies To: MVC Desktop Web Silverlight Services Wpf
View Source |
C# Download |
Desktop |
View Source |C# Download |
Desktop |
View Source |
C# Download |
Desktop |
Applies To: MVC Desktop Web Silverlight Wpf
View Source |
C# Download |
Web |
| View Source C# Download Need it in another language? | Desktop \\ \\ Applies To: MVC \\ Desktop \\ Web \\ Silverlight \\ Wpf \\ | In today’s Desktop project, we combine the skills we learned in the samples “Spatial Query A Feature Layer” and “Track And Edit Shapes”. You can see how we use the event TrackEnded to get the RectangleShape from the tracked shape of TrackOverlay to do the spatial query. In this example, we use a Rectangle but you could also very easily use another shape such as Polygon, Circle, etc. |
| View Source C# Download Need it in another language? | Desktop \\ \\ Applies To: MVC \\ Desktop \\ Web \\ Silverlight \\ Wpf \\ | In today’s project, we show how to save a tracked shape to WKT (Well Known Text). You will notice that we make the distinction between the shape being tracked and the finished tracked shape thanks to two different events of TrackOverlay, TrackEnding and TrackEnded. |
| View Source C# Download Need it in another language? | Desktop \\ \\ Applies To: MVC \\ Desktop \\ Web \\ Silverlight \\ Services \\ Wpf \\ | Basically, this project shows the opposite of yesterday’s project “Snap To Layer”. Instead of having the dragged control point snapping to a vertex if within a tolerance, we show how to not allow a control point get within a set tolerance. This technique can be handy to implement if you have a requirement to have vertices of a shape being no less than a certain distance between each others. To implement that technique, again we use the power and flexibility of the EditInteractiveOverlay of the Desktop edition. |
